  1. Mar 23, 2022 at 5:31 PM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    How hard is it to mess up the splines while using a soft mallet to wack the front axles in? I'm having a really hard time getting my front axles to go in...
    I've tried to align the splines up and feel for it... but it seems impossible
    I'm making sure the cv axle is straight
  2. Mar 23, 2022 at 5:39 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I could feel the extra resistance from engaging the differential. Then used a long mechanics prybar to tap the axle in from the groove on the CV collar. This is why the groove is cut into the collar.
    I would not pound directly on the splined end with any material hammer.
  3. Mar 23, 2022 at 5:45 PM
    AstroDude
    Eddie
    Sorry I'm just trying to make sure. Like this?
  4. Mar 23, 2022 at 5:49 PM
    COTundie
    Trey
    Pretty things
    This is the groove. Opposite the hose clamp holding the rubber boot.
    Long mechanics prybar:
  5. Mar 23, 2022 at 5:50 PM
    COTundie
    Trey
    Pretty things
    Just to the right of where you're at. The 3-4" wide steel collar
    Pry bar should be protruding straight out of the wheel well and tap on the end of the prybar to gently drive the axle into the diff
  6. Mar 23, 2022 at 5:52 PM
    AstroDude
    Eddie
    Awesome thanks guys!! I'll give it a shot.
    But there's no chance of messing up the splines right? They pretty much align themselves?
  7. Mar 23, 2022 at 5:54 PM
    COTundie
    Trey
    Pretty things
    I was able to feel the extra resistance (rotating the axle) when it was engaging the splines in the diff
  8. Mar 23, 2022 at 6:05 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Having that c-clip in the grove with the open end facing down should help significantly.
  9. Mar 23, 2022 at 6:05 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    Here ya go:
    Nickel Plated Pin Switch w/Polycarb Plunger and Rubber Boot https://www.amazon.com/dp/B001TQPM6Q
    I like the dummy light idea! Having a rearview camera makes it pretty obvious when I backup, but I've forgotten the tailgate when driving forward. I'd probably need a buzzer.
    Unrelated, I finally replaced the accelerator so hopefully it won't surge going over bumps. I hate that.
    Also I finally fixed the last knocking sound I had while driving... I had replaced spark plugs, run seafoam through, tightened the skid plate, etc but I finally discovered that one of the heat Shields above the muffler had rusted out around a screw so it was just boucing off the remaining screw. I put on a bigger washer which should hold it for a couple of years.
    I guess I didn't take a picture but I did the same thing for the cover below the fuel tank.
  10. Mar 23, 2022 at 6:36 PM
    AstroDude
    Eddie
    It's almost in...damn. Yall are awesome, couldn't have done it without your input.
  11. Mar 23, 2022 at 7:15 PM
    bdogg76
    bdogg76 New Member
    Brandon
    2008 Slate Tundra Crewmax TRD
    Falken Wildpeak 265/70/18s. Leveling Kit. Bedrug XLT Bed Mat.
    What did you use to paint the emblems?
    Ah too bad, thanks for the response.
  12. Mar 23, 2022 at 7:18 PM
    bdogg76
    bdogg76 New Member
    Brandon
    Tell me about the accelerator. Do you have a link or just OEM replacement? I have the same problem, there are some really bad bumps at a certain intersection and it surges also, I hate it!
  13. Mar 23, 2022 at 7:41 PM
    AstroDude
    Eddie
    I read something about the dust boot being flush with the differential.
    Do those look about right or does that metal ring go all the way in? Just trying to make sure before I start to put the knuckle on
  14. Mar 23, 2022 at 7:47 PM
    COTundie
    Trey
    Pretty things
    Looks like success to me!
    Excellent to see
    AstroDude[QUOTED] likes this.
  15. Mar 23, 2022 at 7:49 PM
    AstroDude
    Eddie
    Thanks brother, couldn't have done it without you!!
    Mountun Goat likes this.
  16. Mar 23, 2022 at 7:53 PM
    COTundie
    Trey
    Pretty things
    Happy I could help a bit.
    :cheers:
    Here's to a smooth button-up
    Mountun Goat and AstroDude like this.
  17. Mar 24, 2022 at 5:43 AM
    MPG_LOL
    MPG_LOL New Member
    Paul
    2012 Black Toyota Tundra
    Leveling Kit, 20" Wheels, KO2 Tires
    Looks good!
  18. Mar 24, 2022 at 8:30 AM
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    Finally got my Victory cab-over rack out of the box and put together, now to wait for warm weather to drill some holes in my roof... My $99 harbor freight hoist finally got used to make the install part easy, no stressing about scratching the truck when I lift it on top and position it...
  19. Mar 24, 2022 at 2:05 PM
    AstroDude
    Eddie
    My power steering pump keeps destroying my serpentine belt...I adjust the belt to make sure all the teeth are in but it keeps happening. This is a new belt that I just picked up...
    This is also a new power steering pump that I installed installed
    avssuc likes this.
  20. Mar 24, 2022 at 2:15 PM
    PhotoNerd
    Tony
    Waterford, CT
    I got my info from this thread: https://www.tundras.com/threads/touchy-gas-pedal.29361/
    Here's the pedal I ordered: Genuine Toyota (04000-0440C)... https://www.amazon.com/dp/B00OW341XS?ref=ppx_pop_mob_ap_share
    The reviews are relevant!
  21. Mar 24, 2022 at 2:25 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I ordered the 04000-0440C pedal from Cool Spring Toyota earlier this week. $30.46 plus shipping. I could have picked it up but with gas prices the shipping was worth it.
    joseph_womack likes this.
  22. Mar 24, 2022 at 2:26 PM
    AstroDude
    Eddie
  23. Mar 24, 2022 at 4:44 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    When you got the new pump did you check it to make sure the offset from bolts to pulley where the same? Also double check belt routing while your at it. Something seems off if I recall right are belts shouldn't have a forward or back adjustment so misalignment adjustment arn't built in. I've seen chevys that did that due to a pulley not being pressed in all the way onto the shaft which could be the issue. They make a pulley laser alignment tool that might be some help here. I believe the video was from "SouthMain Auto"
  24. Mar 24, 2022 at 5:04 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Not sure , but doesn't look like the belt is seated properly in pulley , never seen one with a dip in the middle like that , and looks like it is setting way up on 1 side of pulley. Did you check belt fit before installing the pump?
  25. Mar 24, 2022 at 5:14 PM
    20GR8 Super
    20GR8 Super -
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Finally put an overlay on the steering wheel emblem. The only chrome I have left is the back bumper.
  26. Mar 24, 2022 at 5:37 PM
    Patmaui
    Patmaui New Member
    Pat
    2012 Tundra 4.6L 4x4 work package
    285 65 18 RG 18 x 9 fuel vectors Icon stage 1 Outlaw exhaust S&B intake 10" Head unit
    2020 Sequoia grill and next up alpharex pros :spam:
  27. Mar 24, 2022 at 5:45 PM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    SEM trim black
  28. Mar 24, 2022 at 6:46 PM
    AstroDude
    Eddie
    So what I've done to fix this, I called toyota and gave them my vin number. Ordered another ps pump.
    I think the offset is different and that's why this is happening. Lesson from this: Don't order from Rockauto.
  29. Mar 24, 2022 at 7:04 PM
    bdogg76
    bdogg76 New Member
    Brandon
    PhotoNerd[QUOTED] likes this.
  30. Mar 24, 2022 at 7:11 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Recently decided to do some upgrades to the tundra to keep myself from wanted to buy another truck.
    Installed front mounted camera, replica pro grill, paint matched mirror caps and door handles, under hood lighting, 1” seat risers, and the 3wliners auto up/down window module. Also added Toyota GBS to factory alarm, a voltmeter, got rid of the annoying tpms light by the bypass mod I saw on here, added the auto dim headlight feature,and the info buttons, and added vled puddle lights to side mirrors.
    Optitron gauge is on order and tackling adding steering wheel controls is on the list of things to do as well!!
    60933BD7-C742-4ABB-87C4-07BAA18F33E9.jpgFBFC80A6-679C-475D-88F3-F65FD849ACE0.jpgC2BF327C-E5AA-4EF6-B475-C896DFFAE524.jpg74A7A245-C0C1-4BAB-B04A-F397A54A588E.jpg6BCABAC0-58E8-4E32-8A11-D730B6B570D0.jpgAB212AFB-08D5-4042-BFBC-6E730B8E589E.jpg461DF2C1-A0D8-4545-B4EA-3DB7724107C8.jpg8733A977-2051-40AE-B6D9-48399ECD07D2.jpgBD7E04DF-DD74-4E75-9252-0F59E4C74B55.jpgEAA9A7D4-3CB5-4A57-ACDD-96CFA9715428.jpg
