Matching wood stairs and laminate flooring
Discussion in 'Home Improvement' started by TheBeast, Jun 15, 2017.
  1. Jun 15, 2017 at 9:54 AM
    TheBeast
    TheBeast [OP] The Beach
  2. Jun 15, 2017 at 9:58 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I'm a custom Home Builder and this is always challenging to match existing to new floors. Are they Pre engineered or Real wood floors? How old are the existing floors?
    Rock 4x4 likes this.
  3. Jun 15, 2017 at 9:59 AM
    1UPPER
    TEXAS
    Flux capacitor!
    Just for future reference engineers floors & tile often have die lots numbers. So if you buy the same brand floor several months later from the same place they can still look different.
  4. Jun 15, 2017 at 10:05 AM
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    When I did mine, I took a piece of the hardwood into Sherwin Williams along with the wood I was using and they color matched the stain. That was just oak so I'm sure it was easier, but take it to a paint store and see if they can match it.
  5. Jun 15, 2017 at 10:07 AM
    Newm
    Newm New Member
    KC
    Just my opinion but I wouldn't try to match the stains but look to find an accent color/stain for the stairs. Matching is a PIA.
    I like the colors in the floor and if it were mine I would try and pull some of the darker color out of the floor for the stairs.
    15whtrd likes this.
  6. Jun 15, 2017 at 10:07 AM
    TheBeast
    engineered wood. 14mm laminate
    brand new and we can get the same lot if needed.
  7. Jun 15, 2017 at 10:13 AM
    15whtrd
    15whtrd Mr. Blonde
    Exactly what I was thinking. When it's two different surfaces and material it's hard to get a proper match. So instead go with a color or shade completely different to accent. Like with what you said grab one of the darker colors in the hardwood floor laminate and accent the steps with that.
    Plus it'll really make those stairs pop!
  8. Jun 15, 2017 at 10:28 AM
    1UPPER
    TEXAS
    Flux capacitor!
    How long ago did you do the original floors?
  9. Jun 15, 2017 at 10:36 AM
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    Blunt answer: it won't ever "match".
    Some already great suggestions on making it work though. Could you post pics of the stairs?
    Depends on the treads vs the riser color which will impact just the way the stairs look on their own. White risers will accentuate / showcase the darker grain of the stain. If the treads and risers are the same stain it will really bring out the red tone of the stains when looked at with your floor.
    The best way to match would be to replace the treads with the same lot engineered wood. That is if that's your goal. Engineered "same lot" treads with white risers would also look nice.
  10. Jun 15, 2017 at 10:43 AM
    TheBeast
    2 weeks ago
  11. Jun 15, 2017 at 10:47 AM
    TheBeast
    the way it is right now. Let me know what you guys think:
  12. Jun 15, 2017 at 10:49 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Are you talking about the stairs and the landing not matching?
  13. Jun 15, 2017 at 10:51 AM
    TheBeast
    Yes. stairs are original wood stairs from the house .Landings and upstairs flooring are new 14mm laminate.
  14. Jun 15, 2017 at 12:06 PM
    GoHuskers
    GoHuskers New Member
    Lam
    Nebraska
    '16 Limited CM 5.7L 4x4, '15 GX460 premium
    I used the EXACT same wood stains (Cabernet) for my Stairs, base trims, and wood floors. Everything seems great BUT the floors color is so DARK. 6 months later I re-sanded and stained the floor with Cherry Red. Much better.
  15. Jun 15, 2017 at 2:10 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Looks good to me.
  16. Jun 15, 2017 at 2:38 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    I don't think that looks bad at all, I would roll with it.:thumbsup:
  17. Jun 15, 2017 at 2:40 PM
    TheBeast
    yeah. It's very close but I guess we were hoping for perfect match but then we are working with 2 different materials: laminate and real wood.
  18. Jun 15, 2017 at 2:43 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Different wood species will take the exact same stain color and look different. So trying to get even two samples of the same wood the same stain can look different. It's never a simple process unfortunately.
    JH5370 and csuviper like this.
  19. Jun 15, 2017 at 2:50 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Maybe a carpet runner up the stairs and landing so you only show maybe 2-3 inches of wood on the edge? I've done it a lot with good results, additionally, the systems for putting the laminate on the stairs are pretty lame, and make the stairs really noisy. I also use runners on stairs for noise and my dogs, no slipping.
    OBXTundra likes this.
  20. Dec 31, 2018 at 3:00 AM
    qanddstairs
    qanddstairs New Member
    Quality
    Ontario
    Match the colors with paint
