Rebuilding a 5.7? Ever done it?
Discussion in 'Performance and Tuning' started by Jbjb2630, Jun 14, 2017.
  1. Jun 14, 2017 at 6:54 AM
    Jbjb2630
    Jbjb2630 [OP] New Member
    2008 Tundra 4x4 SR5 Double Cab
    Leveling kit, cab marker lights, custom entertainment
    Just curious about rebuilding the 5.7. I saw an engine for cheap that had broken valve springs. I'm sure if the valve springs are broken this engine was probably ran long and hard in its short lifetime and probably due a rebuild. I'm curious as to what specialty tools would be needed and if its even recommended?
  2. Jun 14, 2017 at 11:40 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I thought I read that there was a TSB on defective valve springs on some 2007s.
  3. Jun 14, 2017 at 11:42 AM
    Jbjb2630
    I guess this 1 got away. From my old hot rod days I remember broken valve springs come from my lead foot.
  4. Jun 14, 2017 at 11:43 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    valve springs are a common things on 5.7s. we see them all the time. around 150k or so..
    ColoradoTJ likes this.
  5. Jun 14, 2017 at 11:45 AM
    Jbjb2630
    How much work is involved to replace?
  6. Jun 14, 2017 at 3:20 PM
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    I'm at 130k hope I don't have this problem at 150
