2022 Tundra Overhead console removal
Discussion in '3rd Gen Tundras (2022+)' started by Duttch, Feb 7, 2022.
  1. Feb 7, 2022 at 8:27 AM
    Duttch
    Duttch [OP] New Member
    2022 Toyota Tundra Limited
    Hello,
    I just acquired a new 2022 Tundra. Is there a specific procedure for removing the overhead console. In looking behind / next to the sunglass holder I see 2 clips on the side and 4 behind the case (not sure if these are just for connecting the bezel). Or is it merely pulling it down with force.
    I'm looking to tap into 12v wiring in the overhead console for hotwiring my valentine one.
    Thanks
  2. Feb 7, 2022 at 8:45 AM
    Taco-Spike
    Two Trucks
    Previous gen has torx screws and clips. Might want to check for those. It 'could' be a just pull like the Tacoma but haven't anything seen anyone doing it for a 3rd gen Tundra.
    Looks up some videos on YT for previous year trucks, might give you an idea of things to look for.
  3. Feb 7, 2022 at 8:49 AM
    Duttch
    @Taco-Spike , Thanks. I looked, no torx or any other screws unfortunately. Had a Ram 1500 before and that was with 2 screws and 2 pinch clips and then pull down.
  4. Feb 7, 2022 at 9:01 AM
    Duttch
    Some additional pics of the overhead console, no screws in the sunglass area and clips to be seen behind the sunglass holder
    Taco-Spike likes this.
  5. Feb 7, 2022 at 9:15 AM
    Taco-Spike
    Two Trucks
    If it were me, I'd give it a yank to see if it comes down. Again, just me.
  6. Feb 7, 2022 at 10:26 AM
    Duttch
    How to remove the overhead console on a 2022 Toyota Tundra:
    use both hands evenly spaced, grab the back edge (edge closest to the windshield / mirror) of the overhead console, pull down firmly (its very tight) the console will snap lose on the back side, the front has 2 lips holding it in the headliner.
  7. Feb 4, 2023 at 11:33 AM
    Andgar001
    Andgar001 New Member
    Hi, thanks for the post. Were you able to tap into the OHC, which wires did you tap into? Thnx.
  8. Jul 17, 2023 at 7:25 AM
    THOMASTAN
    THOMASTAN New Member
    THOMAS
    2023 TUNDRA TRD PRO
    Hi, do you know which wire you tap into?
