Would like to buy 4 shims...do i need bolts? quickest way to get these?
Discussion in 'Ekstrom Design' started by Berettafan, Jun 1, 2017.
  1. Jun 1, 2017 at 5:42 AM
    Berettafan
    Berettafan [OP] New Member
    2017 CM
    A bit frustrating there appears to be no website for Coachbuilder. Looking to buy shims for my otherwise stock '17 Limited CM. Would I need longer bolts as well? If so do you sell these?
    Thanks-
  2. Jun 1, 2017 at 6:55 AM
    PMG
    PMG New Member
    Web search and you'll find vendors like dirtydeeds. The bolts are good for 2 shims a side without issue.
    Coachbuilder1 likes this.
  3. Jun 1, 2017 at 6:57 AM
    Berettafan
    2017 CM
    Tried that. Couldn't find the shims on dirty deeds site.
  4. Jun 1, 2017 at 7:17 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    GNTundra likes this.
  5. Jun 1, 2017 at 7:33 AM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    Toyota Tundra 1" Front Leveling Lift Kit 4WD 2WD Billet aluminum Tundra 1.0T
    https://www.ebay.com/itm/121514406540
    Best deal around for 1/2" spacer. I'm running these. High quality and look great! Can't beat $25 shipped.
  6. Jun 1, 2017 at 7:39 AM
    Voyagermike
    Voyagermike New Member
    California
  7. Jun 1, 2017 at 8:59 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thanks for the post and PM Erik, Just replied and have everything ready to go. Please let me know if you have any other questions. Thanks!
    https://www.shopcoachbuilder.com/products/coachbuilder-strut-coilover-shim-provides-50-of-lift
  8. Jun 1, 2017 at 9:03 AM
    Berettafan
    2017 CM
    Responded. Thanks David.
    Glad to have found a simple solution for getting an inch of lift!
  9. Jun 1, 2017 at 11:05 AM
    Coachbuilder1
    Salt Lake City UT
    Shipped, thank you!
    Voyagermike likes this.
  10. Jun 5, 2017 at 1:30 PM
    Berettafan
    2017 CM
    Received!
    4wheelparts needs to hire you to manage inventory and shipping.
  11. Jun 5, 2017 at 3:03 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    why?
  12. Jun 2, 2019 at 11:17 AM
    the mailman
    the mailman New Member
    2014 Tundra Gun Metal Gray
    Just starting
    Is there enough space to add two CB shims and tighten safely on a 2014 Trd
  13. Jun 3, 2019 at 2:51 PM
    Coachbuilder1
    Salt Lake City UT
  14. Jun 4, 2019 at 4:38 PM
    the mailman
    Just starting
    Just ordered 3 from you Thx
  15. Jun 4, 2019 at 5:51 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Why the recommendation to use 2 on driver side and one on passenger side? Wouldn't you just need one on the driver side to eliminate lean?
  16. Jun 4, 2019 at 6:09 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The average lean is driver side low...
  17. Jun 4, 2019 at 6:14 PM
    the mailman
    Just starting
    Im going to run the Billy 5100 on the middle setting so two on the driver and one the passenger should make it level ...Fingers crossed
  18. Jun 4, 2019 at 6:26 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I get that, but if the intent is to even it out, adding two on driver side and one on passenger side would be the same as just adding one on driver side and leaving passenger, alone right?
  19. Jun 4, 2019 at 6:44 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    correct. I cant read.
    But i think the main goal is to get the 1 inch of lift. Correcting the lean is just a lucky side effect
    Darkness likes this.
  20. Jun 4, 2019 at 7:16 PM
    the mailman
    Just starting
    What i understand Is that the 5100's has three settings. .87 1.57 2.28 the middle setting gives you the best ride and the extra shim Kicks you up 1/2 inch to about 2 lift level with rear the second shim on driver side fixes the lean of 1/2 inch
  21. Jun 5, 2019 at 3:04 PM
    Coachbuilder1
    Salt Lake City UT
    Thank you!!! tracking sent.
  22. Jun 5, 2019 at 3:06 PM
    Coachbuilder1
    Salt Lake City UT
    This is usually how we set the Bilsteins up, Adding the extra shim on the driver side corrects the lean and then bumps you up to 3".
