Home DI water treatment system
Discussion in 'Detailing' started by mdavis, May 7, 2017.
  1. May 7, 2017 at 9:05 AM
    mdavis
    mdavis [OP] I need a beer.
    Michael
    Rock Hill, SC
    Since moving into my new home, I have found that I have hard water. I have installed a whole home water softener and though it feels soft I'm still getting water spots on my truck when I wash it. I remember seeing someone on here talk about home DI systems but can't remember who or where.
    So, is anyone else running a DI system to wash their cars? If so, what are you using?
    SouthBoundSteve likes this.
  2. May 7, 2017 at 9:14 AM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2015 MGM TRD 4x4 Crewmax
    Toyota spray in bed liner/ 30" LED Lightbar/ Pro Comp Pro Runner SS @ 2.5"/ Husky Xact fronts/ Weathertech rear/ NFAB steps/ 275/70R18 BFG KO2's/ LED interior from GTR lighting/ Tekonsha Prodigy Trailer brake Controller
    You would just need some sort of demin bottles to pass through before use. Like a worker and polisher. We clean very large quantitiies at work. We have 2 tanks that each hold 650,000 gallons on di water!
    mdavis[OP] likes this.
  3. May 7, 2017 at 9:16 AM
    nowayout
    nowayout New Member
    NY
    17 CM
  4. May 7, 2017 at 9:22 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Are you sure your outside hose bib goes through your softener? Most do not since they typically connect up to the line going into the house.
    Bear likes this.
  5. May 7, 2017 at 9:24 AM
    Tacotundra
    Tacotundra New Member
    Vegas
    2017 Tundra
    What he said.
    Bear likes this.
  6. May 7, 2017 at 9:48 AM
    mdavis
    Michael
    Rock Hill, SC
    Yep, I plumbed in the softener myself. Did it right after the pressure tank. I did plumb the spicket on the other side of the house before the softener so I can water plants and such but the car wash spicket is definitely plumbed after.
  7. May 7, 2017 at 11:55 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I had a whole home RO system in my old house, cost was about $2500 and I installed myself. I only did an under the sink unit in the new place and we get water spots on EVERYTHING. I am considering springing for the whole home unit again.
    I don't like water softeners, adding more mineral to the water might change pH but it seems to me that it will still leave deposits when surfaces dry. Particularly surfaces that heat up in the sun and dry fast.
    Because I don't want to add salts, I am also considering the NuvoH2O system. I know a guy who actually installs RO systems in large scale operations and he uses the Nuvo system...
    mdavis[OP] and SouthBoundSteve like this.
  8. May 7, 2017 at 2:16 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I was looking at website and looks like filters are about $100 to replace. The housings are pretty generic. If anyone uses the cr system, does it REALLY work? If so, thinking of making my own, other than the electronic media replacement. IMG_1052.jpg
    mdavis[OP] and NewImprovedRon like this.
  9. May 7, 2017 at 5:22 PM
    mdavis
    Michael
    Rock Hill, SC
    Just washed the wife's car. :annoyed:These spots are killing me! Need a solution.
    NewImprovedRon likes this.
  10. May 7, 2017 at 5:25 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Me too!
  11. May 7, 2017 at 6:49 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
  12. May 8, 2017 at 7:35 AM
    mdavis
    Michael
    Rock Hill, SC
  13. May 8, 2017 at 5:01 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Question Mike, is your system a salt system or just a resin / carbon system. The only true way to remove the hard water calcium deposits is with a salt water system. Companies will make lots of claims about a whole house water softener system, and not be using salt. The salt water systems today have a separate brine tank and send very little salt into the home. The salt systems of yesterday that we grew up with had a one tank system and gave that very slimy shower feel. I have talked with numerous companies that sell both systems, and salt is the true water softener. I am also installing a drinking water RO system under the kitchen sink to remove all the chlorine, fluoride etc added to our water today. I am in So Cal and we have some of the hardest water in the country. I guess my speech is null and void if you already have a salt system. Good luck with all.
  14. May 8, 2017 at 5:51 PM
    mdavis
    Michael
    Rock Hill, SC
    Yep, mine is a salt softener. Read a lot of bad reviews about non salt systems.
  15. May 8, 2017 at 6:09 PM
    CM-LENNY
    San Diego, CA
    To much salt can cause issues. Try to keep the tank around half full. Filling it all the way up is kinda a no no.
  16. May 8, 2017 at 6:17 PM
    CM-LENNY
    San Diego, CA
    No worries. I just push those things off as age related........:eek:
  17. May 8, 2017 at 6:17 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Sediment filter to carbon filter to softener to r/o. R/o goes to fridge and sink faucet. Ice cubes are almost clear.
    If the car wash system really works I was thinking about just buying the double filter housing and just buying the filter cartridges from the cr spotless website.
    It would be about $200.
    1UPPER and SouthBoundSteve like this.
  18. May 8, 2017 at 6:21 PM
    CM-LENNY
    San Diego, CA
    Nice set-up. Did you plumb the sediment and carbon prior to the salt system or after ? What brand of components ? Hope we aren't jacking your thread Mike.
  19. May 8, 2017 at 6:26 PM
    mdavis
    Michael
    Rock Hill, SC
    Dang! Nice setup! If I would have known about this issue while I was building, I would have a room dedicated just for water treatment just like this.
  20. May 8, 2017 at 6:26 PM
    mdavis
    Michael
    Rock Hill, SC
    No problem here. Glad people are showing their setups!
    CM-LENNY[QUOTED] likes this.
  21. May 8, 2017 at 7:27 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Little corner of garage, right next to water heater. Got the softener and r/o as add ons w house when built. I added the pre filters. Plumbing is pretty straight forward. Got the filter housings off Amazon. Not too expensive. Search big blue filters, they'll pop up. 4x20".
    If you're gonna do something similar remember to put shut off valves before and after the filters to depressurize when changing filter cartridges. I do em at 6 mo intervals. R/o same schedule.
    CM. I'm from SD. Never did the filtration stuff. Now, I'd never not do it. No BS, my ice cubes are almost see through. Only time they're not is about 2 out from changing filters.
  22. Jun 4, 2017 at 4:14 PM
    CM-LENNY
    San Diego, CA
    Installed my home water softener and drinking water RO system. Water softener consists of a large canister with a media bed in it and a separate brine tank. Does auto back-flush based on water usage, not day of week.
    I'm not a plumber, but think my copper plumbing and solder joints came out OK.
    Also have an Electric tankless water heater that's about the size of a VCR. I was just getting past my cancer battle when we did a slight remodel and had a plumber install the tankless. He did not install the flushing valves and the So Cal hard water ate through the heater element. Now with the softener, that will be a thing of the past..
    SouthBoundSteve and T-Rex266 like this.
  23. Jun 4, 2017 at 4:19 PM
    CM-LENNY
    San Diego, CA
    Appreciate that Steve and I even used lead-free solder like a good boy !
  24. Jun 4, 2017 at 4:42 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
  25. Oct 13, 2017 at 4:54 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I installed this system for one of my well water customers - no spots.
    Backslider and CM-LENNY like this.
  26. Jan 25, 2021 at 10:57 AM
    Taco4life
    Taco4life New Member
    99 Taco SR5
  27. Feb 5, 2021 at 4:28 PM
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    Do you have a pic of your setup? I have been looking at doing something like this for a long time but just cant seem to figure out what system to go with. This looks like a good system but how much are filters?
  28. Apr 3, 2023 at 1:02 AM
    Eoliens
    Eoliens New Member
    You installed a water filter to avoid hard water stains resulting from the buildup of minerals like calcium and magnesium. Water softener for pre-filtering water filter for the whole house. Or use RO system water filter.
