Hello (new member) & plowing question
Discussion in '2nd Gen Tundras (2007-2013)' started by BritChic, Jan 12, 2022.
  1. Jan 12, 2022 at 2:27 PM
    BritChic
    BritChic [OP] New Member
    Hi there,
    I live in the Northeast and am looking for a used truck that I can use as my primary vehicle, as well as to get loads of hay, and plow my driveway.
    I have found a 2009 Tundra - SR5 Double Cab 4.7L 4WD for sale w/ Bosch plow. It has been used to plow for the last 4 years, apparently. 4 driveways.
    I had been looking for 3/4 ton trucks but I much prefer the appearance of the Tundra.
    Do you think this truck will work for me? I've been told that it's not a good idea to plow with a 1/2 ton truck but perhaps incorrectly?
    Thanks for any advice you might have. This is all very new to me (buying a truck, and plowing!).
    Mountun Goat likes this.
  2. Jan 12, 2022 at 2:29 PM
    Coal Dragger
    Coal Dragger New Member
    2007 White Double Cab Limited 5.7L 4X4
    I wanted a faster vehicle so I also bought a Chevy SS... because 4 door sedans with big V8’s are hilarious.
    Light plowing shouldn’t be an issue. If you plan to have a side business I would buy a 3/4 ton with a plow prep package, preferably one with a solid front axle.
  3. Jan 12, 2022 at 3:13 PM
    BritChic
    Thanks Coal Dragger! No side business but my driveway is very steep. I'll start from the top so the first pass is downhill. The engine on the one I found is 4.7. Would it make much difference to have the bigger engine?
  4. Jan 12, 2022 at 3:47 PM
    Coal Dragger
    Probably, the 5.7L has a lot more power.
    One thing to watch out for on the 4.7L is the age and mileage on the timing belt. Supposed to be changed at around 90K is memory serves and can be a ticking time bomb if it snaps.
    tundratoofun and Mountun Goat like this.
  5. Jan 12, 2022 at 4:09 PM
    BritChic
    That's very good to know. I will be sure to check. Thank you for being so helpful.
  6. Jan 12, 2022 at 4:23 PM
    Coal Dragger
    Sure thing, good luck.
    Some searching of the 2nd Gen technical sub forums might give you more answers.
  7. Jan 18, 2022 at 6:25 PM
    MTRock
    MTRock 1889
    Montana
    2013 Rock Warrior DC
    DC rear fold down seats, decals removed, blacked out badges, complete stereo, ceramic coating, ToyTec Boss 3/1.5, RidgeGrappler 305/70r17, blacked out rock rings and center caps, smoked tail lights, BAMUFFLER Alpharex Pro headlights, TRD PRO Sequoia Grille, DAPtune
    I plow often.. No problems
    This guy gets after it though!
    @Mountun Goat
  8. Jan 18, 2022 at 6:56 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Hi there @BritChic Welcome!
    I plow with my 2008 5.7 dc often. It works well. I rarely use low range 4x4- only in real deep snow in the pasture that hasn’t been plowed for months. I bet you’d be fine with the 4.7 in low range. :)
    Truelifelover and BritChic[OP] like this.
  9. Jan 18, 2022 at 7:40 PM
    Welcome from NY.
    BritChic[OP] likes this.
  10. Jan 18, 2022 at 8:07 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I don't have enough snow to cover the ground down here, much less plow.
  11. Jan 18, 2022 at 8:12 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Anyone else's childish mind struggling to ignore "member & plowing" in the thread title?
    I call for a committee to determine a new "less distracting" title for the thread before erasing the current from history.
    ....I think I need to go to bed... Or whiskey
  12. Jan 18, 2022 at 8:17 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Welcome from OKC! If I were gonna buy, most definately it would be a 5.7. Just get ready to spend on gasoline.
  13. Jan 19, 2022 at 3:38 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  14. Jan 19, 2022 at 8:05 AM
    BritChic
    Thanks for the lovely welcomes and also for the encouraging info about plowing @Mountun Goat. I ended up getting the 5.7 (I pick it up on Saturday). Very happy. Do you recommend getting coils or lifted or (insert correct terminology here) or am I fine to plow without any adjustments? I'm getting a 7.6 Steel Boss HTX. My driveway is pretty steep here in Vermont. Lower AL sounds like a good move considering we just got a foot of snow here.
    @COTundie - Ha! Can't believe my British sense of humoUr missed that one :)
    Mountun Goat and 2mchfun like this.
  15. Jan 19, 2022 at 8:34 AM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    If your plow has auxiliary lights you will want a heavy duty alternator. Dim lights & blowing snow are a bad combination.
  16. Jan 19, 2022 at 8:38 AM
    Welcome from Ohio
  17. Jan 19, 2022 at 10:36 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Nice work on the 5.7. I can’t comment on the lift for the front of your truck. Ive had heavy duty 613 old man emu coils on the front of my truck before I had a plow so can’t compare to a oem suspension. :hattip:
  18. Jan 19, 2022 at 10:52 AM
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    Congrats and welcome. I was strongly considering putting a plow on my truck after the tractor/snowblower experiment failed. I have roughly 1000' of driveway to plow plus a ½ court sized area down by the garage. I'd heard it's hard on vehicles (tranny, frame, suspension). I still thought it through. Then I watched a 1-ton truck plow my driveway (we can get up to 2' overnight on occasion), and he was slamming into banks and just hammering the truck. He wasn't out of control or reckless, but I immediately changed my tune about plowing with a ½ ton. I think you'll be glad you have the 5.7L but I'd be cautious plowing anything deeper than 10" at a time, and it doesn't sound like it will be your daily driver either so that will help. I think if you can plow frequently enough that it doesn't stack up over a foot or more, you'll be just fine. Good luck. And yes, heavy coils up front recommended.
  19. Jan 19, 2022 at 10:59 AM
    2mchfun
    Without heavy coils, the truck will likely be on the bump stops more often than not, resulting in a very harsh ride. Some of which can be absorbed with max tire sidewall height and tire sidewall construction. Higher load rated tires equates to a stiffer sidewall.
  20. Jan 31, 2022 at 4:55 AM
    JCtheOtherOne
    JCtheOtherOne New Member
    Jack
    Outside of Philly
    2011 White Tundra TRD- Philly
    Here is my bad boy. I have 2 western plows for it. A 7.5’ and 8.5’ i was too cheap to buy a factory light harness so i retrofitted my Ford F-250 harness to the Tundra. Works well except i have a switch to turn on the plow lights instead of them turning on by themselves. Yes there is a sticker that says Meyer but it was free so i just slapped it on the plow.
  21. Apr 14, 2022 at 10:26 AM
    Dwarven1
    Dwarven1 New Member
    Ross
    2018 SR5 w/TRD Off-Road.
    2018 SR5 - Bolo Mark XXb - Unit DNE of the Line. "Denny"
    Greetings from another Vermonter! I bought my '18 DC with a 5.7 a year ago and promptly had a Boss HTX installed (I used GB Mechanical in Williston). And, of course, it was done RIGHT after the last snow fell last spring. :) But it's been working great for my driveway this winter. Not terribly steep, but 100 yards of gravel going uphill - and I'm in the foothills in S. Starksboro, so we always get more snow than forecast.
    I'm also debating getting a lift kit for the front - doesn't quite get tall enough to suit the Boss specs (13.5" vs the recommended 14" high), so I frequently have to "encourage" the plow to get mounted. And after seeing the rear squat when towing some larger trailers (like a car carrier), I'm thinking I need to do something on the rear, too.
    Here's my beast wearing his winter gear. Less the cap that got put on in December.
    Mountun Goat and PermaFrostTRD like this.
  22. Apr 14, 2022 at 11:03 AM
    PermaFrostTRD
    Northern NY
    Some heavier springs would help.
    OME and other manufacturers make 650lb (stock), 700lb, & 750lb. Not sure how much you daily the truck when the plow is off, but 750# will be pretty stiff in the summer.
  23. Apr 17, 2022 at 9:10 AM
    Dwarven1
    Dwarven1 New Member
    Ross
    It's a daily driver; sold the Subaru and the 2000 Tundra after getting this.
  24. Apr 17, 2022 at 9:25 AM
    PermaFrostTRD
    Northern NY
    Maybe 700# for a happy medium.
  25. Jan 14, 2023 at 3:12 PM
    Truelifelover
    Truelifelover New Member
    2009 Toyota Tundra SR5
    2 inch lift Mevotech TTX outer tie rods Mevotech Supreme inner tie and next are the control arms
    Hello and I have to ask cause I just bought a snowplow for my 2009 5.7 SR5. Any pointers that I need to know? Like what option on the truck to have on or off? Thank you in advance
