Canopy/topper Roof Rack Options- Let’s See Them
Discussion in '2.5 Gen Tundras (2014-2021)' started by TunsofFon, Jan 7, 2022.
  1. Jan 13, 2022 at 12:38 PM
    TunsofFon
    TunsofFon [OP] New Member
    Pacific NW
    2021 MGM Platinum
    Can anyone confirm if Thule and Yakima use the same size tracks?
  2. Jan 13, 2022 at 5:38 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    I just purchased the Rhino Rack ROC25 roof rack with Vortex Aero crossbars. In fact, etrailer just shipped it (item #RR64YR) a few hours ago. For a more streamlined "factory" look, the crossbars sit flush into the legs rather than extending past the legs on either side.
    Also have a cheap Chinese-made basket to sit on top of that, which will have four 4" flood/spot cube lights installed.
    Behind that, in the bed, is a color-match (sunset bronze) A.R.E. DCU truck cap with double doors in the rear (tailgate removed). A bed slide is fitted inside the bed cap to make it easier to get to my stuff.
    All this is my winter ("overland" truck) build, which should be finished by the end of this month.
  3. Feb 4, 2022 at 7:04 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Got the Rhino Rack Pioneer Platform on today. I installed the Backbones a few days ago. What’s strange is the center crossbar on the platform doesn’t align with the center tabs on the backbone. So the platform is bolted down in the 4 corners but not the middle. I still need to install the forward facing cargo rail.
  4. Feb 4, 2022 at 7:11 PM
    Windsor
    Windsor New Member
    Oregon
    2008 Tundra Crewmax 5.7L
    Seat covers, SnugTop.
    Flip the platform around. The center bar is offset. The platform is marked front/back.
    Edit: comparing yours to mine, the offset looks correct, are the rails on the correct side?
  5. Feb 4, 2022 at 7:59 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    I have the platform oriented correctly and as far as I can tell, the backbones should have the Rhino Rack emblem to the forward facing side. I saw the offset and measured but it doesn’t seem like it would fit either way. It is a universal system so maybe it’s just not used? Seems odd though.
  6. Feb 4, 2022 at 8:00 PM
    Windsor
    Windsor New Member
    Oregon
    Weird.
  7. Feb 4, 2022 at 8:31 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    It is. I’m going to call RR on Monday.
    On another note, if you happen to have a 46” piece of that extruded aluminum you’re not going to use, I would be interested in taking it off your hands for a fair price.
  8. Feb 4, 2022 at 8:56 PM
    Windsor
    Windsor New Member
    Oregon
    I have a 47" piece of the rail. Is that what you need? D shaped extruded.
  9. Feb 4, 2022 at 9:00 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    @Windsor is your 42113 center crossbar riveted in place? Mine is. Mine also came pre assembled and it looks like the 42113B that comes with the universal canopy kit has to be manually assembled. All three crossbars on that one can be moved around.
    I’ll probably center the platform and just drill new holes for the forward and rear crossbars so I can use all 6 mounting points.
    RR also just seemed to update all their part numbers which isn’t helping things.
  10. Feb 4, 2022 at 9:02 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    If it’s the same stuff as the cargo rail then that would be about perfect. If you’re willing to part with it, PM me and name a price.
    If not, no worries.
  11. Feb 4, 2022 at 9:20 PM
    Windsor
    Windsor New Member
    Oregon
    Yeah, the center bar is riveted in place. 2 rivets per slat. Moving it should be pretty easy. One hole drilled on each side rail, 2 on each slat (they even designed it with lines to mark where to drill for fasteners).
    This is the rail I'm talking about. Its extra from my full rail kit. I have 2 left, I'll part with one.
    Either pay shipping, or have someone pick it up. Right now, I'm about 6 miles NE of Glide OR in the hills, but I can drop it off at my folks place in Myrtle Creek on tuesday to be picked up at a later date.
  12. Feb 14, 2022 at 7:51 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Got the final piece to the cargo rail cut, drilled, painted and rigged tonight. Now it is ready to be installed on the platform. Big thanks to @Windsor.1C0D0E89-06B1-46BD-AA94-B630A8FC5D5F.jpg
    I’m waiting on some hardware to make the platform adjustment so I can use all 6 mounting points. Instead of repositioning the center crossbar which has a bunch of rivets, my plan is to keep the center crossbar on the platform where it’s at and move the entire platform back on the backbone ~1.5” to line it up with the center mounting points on the backbone. This will give the platform a more centered position on the canopy too. Then I’ll drill new holes to reposition the forward and rear crossbars on the platform to line up with the fwd and rear backbone mounting points. This will reduce the drilling to 4 new holes. Here is a photo of how it looks now:89A45CC8-455B-46FE-93DB-464D79B96E33.jpg
    Windsor likes this.
  13. Aug 8, 2022 at 4:25 PM
    CarlsSenior303
    CarlsSenior303 New Member
    Carl
    2022 Tundra Limited TRD Offroad Army Green (hopefully)
    How high from your roof to the top of the platform is this, @TunsofFon ?
  14. Aug 9, 2022 at 8:03 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    About 5-6 inches to top of the platform. Add another 3 inches for the rail in the front. I no longer clear 7 ft clearance bars anymore. I think I’m sitting at 7’1” or 2” with that front rail on the rack.
  15. Aug 9, 2022 at 8:06 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
  16. Aug 9, 2022 at 9:24 PM
    RetiredTundraBC
    RetiredTundraBC New Member
    San Diego County
    2020 Cement Tundra
    Snug Top, Icons, RXT Fuel Wheels, Toyo RT Trail, Prinsu Top Rack, Iceco Fridge,MIA RTT, RCI Skids,Sliders
    I have the Snugtop Rebel with the Prinsu Top Rack, mounted with 3 Sherpa mounts on each side. Also using the Sherpa 1/2 inch raised tent mounts.image0 (10).jpg
  17. Aug 10, 2022 at 4:52 AM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
