Payload stickers on 3rd gens?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Jan 4, 2022.
Thread Status:
Not open for further replies.
  1. Jan 4, 2022 at 9:33 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60/R20 Falken Wildpeak A/T3W
    Could you 3rd gen owners kindly upload pictures of your payload sticker? Also please state the specs of your vehicle as well. TIA!
  2. Jan 4, 2022 at 9:39 PM
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
  3. Jan 5, 2022 at 8:48 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
  4. Jan 5, 2022 at 9:00 AM
    Terndrerrr
    Music City
    Dual 5.7s
    One thread that ventures off and on topic > duplicate threads :notsure:
    ColoradoTJ and Cpl_Punishment like this.
  5. Feb 21, 2022 at 11:30 AM
    PJzblueprint
    PJzblueprint New Member
    PJ
    2022 Tundra Limited Crewmax 4X4
    I just weighed my truck, 22’ limited Crewmax 5.5 with premium pkg and full moon roof, oval aluminum running boards from Toyota and trifold tonneau. GVWR = 7230 on sticker; says payload is 1400 before running boards and cover but…..
    CAT scale weight was 5980. So, as equipped, and adding 300 for two passengers and removing 65lbs for tonneau and minus some tools at about 50 lbs, the true payload for an empty slide in camper could only be about 1065 lbs. then adding gear would most likely drop it to under 1000lbs available payload. Not to mention adding airbags for suspension.
  6. Feb 21, 2022 at 12:44 PM
    LML 3500HD
    Closed. Use the other thread. Sorry if you have to work a little.
Thread Status:
