Product Warning & Recall Notice : Winchester 9mm Luger 115 Grain
Discussion in 'Guns & Hunting' started by P-Factor, Jul 10, 2021.
  1. Jul 10, 2021 at 4:31 AM
    P-Factor
    P-Factor [OP] New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    FYI -
    Olin Winchester, LLC is recalling the following lots of 9mm Luger 115 grain Full Metal Jacket and 115-grain Jacketed Hollow Point pistol ammunition.
    Symbols: Q4172, RED9, USA9JHP, USA9MMVP, USA9W, WW9B
    Lot Numbers:
    SC03LD44, SC03LD45, SC03LD46, SC03LD47
    SC13LD1, SC13LD6, SC13LD18, SC13LD44, SC13LD45, SC13LD46, SC13LD47
    SC52LD44, SC52LD45, SC52LD46, SC52LD47
    SC62LD44, SC62LD45, SC62LD46, SC62LD47
    SC72LD44, SC72LD45, SC72LD46, SC72LD47
    SC92LD44, SC92LD45, SC92LD46, SC92LD47
    SD10LD1, SD10LD3, SD10LD6, SC10LD12, SD10LD18, SD10LD46, SD10LD47
    SD50LD1, SD50LD3, SD50LD6, SD50LD11, SD50LD12, SD50LD18, SD50LD46, SD50LD47
    SD60LD1, SD60LD3, SD60LD6, SD60LD11, SD60LD12, SD60LD18
    SD70LD1, SD70LD3, SD70LD6, SD70LD11, SD70LD12, SD70LD18
    SD80LD1, SD80LD3, SD80LD6, SD80LD11, SD80LD12, SD80LD18
    The Symbol designations and locations of the Lot Numbers are depicted in the photographs above and below.
    NOTE: If ammunition of the above Symbols was purchased before March 25, 2021, it is NOT subject to the recall.
    Winchester has determined the above lots of 9mm Luger 115 FMJ and JHP ammunition may contain propellant that does not properly ignite and burn when the cartridge is fired. Ammunition containing propellant that does not properly ignite and burn may result in a bullet remaining in the barrel (i.e., a bullet-in-bore obstruction). Firing a subsequent bullet into the bore obstruction could cause firearm damage, rendering the firearm inoperable and subjecting the shooter and bystanders to a risk of serious personal injury.
    DO NOT USE WINCHESTER® 9MM LUGER 115 FMJ / JHP OF THE ABOVE SYMBOLS THAT HAS ANY OF THE ABOVE LOT NUMBERS. The ammunition Lot Number is stamped on the cartons of the Symbols involved as indicated here:
    Recall Winchester Asssorted 9mm Luger 115 Grain
    To determine if your ammunition is subject to this notice, review the Symbol and Lot Number. If it is any of the above Symbols and Lot Numbers, immediately discontinue use and contact Winchester toll-free at 844-653-8358 for free UPS pick-up of the recalled ammunition. Upon receipt of your recalled ammunition, Winchester will ship replacement ammunition directly to you or issue you a reimbursement check.
    This notice applies only to the above 9mm Luger 115 FMJ and JHP Symbols with the above Lot Numbers. Other Symbols or Lot Numbers are not subject to this recall.
    If you have any questions concerning this 9mm Luger 115 FMJ / JHP pistol ammunition recall please call toll-free 844-653-8358, write to Winchester (600 Powder Mill Road, East Alton, IL 62024 Attn: 9mm Luger Recall), or visit our website at www.winchester.com.
  2. Jul 10, 2021 at 5:21 AM
    BobsYourUncle
    BobsYourUncle New Member
    2021 Super White Tundra TRD Pro
    Guess I’m safe because of the March 21 date. Haven’t seen any Winchester 9mm in stock for about a year.
  3. Jul 10, 2021 at 6:08 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Thanks for sharing @P-Factor ,I did buy the 500 bulk pack a couple months ago and shot 100 rds and shot flawlessly. I better check the other remaining boxes. Thanks again.
  4. Jul 10, 2021 at 6:15 AM
    LML 3500HD
    What!!!???
    You all found ammo?
    :D
    Thanks for the safety update @P-Factor
    aperezsh, P-Factor[OP] and 1lowlife like this.
  5. Jul 10, 2021 at 2:22 PM
    P-Factor
    Bumped for safety awareness.
  6. Jul 10, 2021 at 3:19 PM
    glowblue
    glowblue From time to time
    VA
    Good to know…for the 3 people who actually were able to buy this ammo!
  7. Jul 10, 2021 at 3:21 PM
    Shark Bait
    Shark Bait Not new anymore
    2019 Platinum
    it also includes some Herters 9mm that they manufacture for Cabelas/Bass Pro.
    equin likes this.
  8. Jul 12, 2021 at 10:33 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Hey I am in Commifornia, imagine the ammo shortage I gotta deal with. That being said, anytime I am near a gun store and remember, I swing in to see what they have if any in range or defense. Just this weekend I was in Huntington Beach and saw a Turners Outdoors. They only had 9mm range ammo, but I bought 3 (50rds.) boxes just because.
  9. Dec 19, 2021 at 12:45 AM
    aberserker
    aberserker New Member
    2021 White
    If you get an 03 FFL Collectors of Curios and Relics license and a COE "Certificate of Eligibility" from the state cost about 50 dollars for both and you can buy ammo online and have it shipped to your house. Not as many sellers want to deal with California BS but quite a few still do. Just an FYI
  10. Dec 19, 2021 at 7:19 AM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Thank you
