Baja Squadron SAE (square) to Tundra wiring harness/adapter?
Discussion in 'Lighting' started by unsub1, Dec 9, 2021.
  1. Dec 9, 2021 at 8:16 AM
    unsub1
    unsub1 [OP] New Member
    Steven
    2020 MGM Tundra 4x4 SR5 TRD Off-Road Package, Convenience Package,
    Victory 4x4 sliders, RSI SmartCap, ICI Alumilite front bumper, TRD Pro wheels, Nitto RidgeGrapplers, FrontRunner rack, National Luna DC25 dual battery, X2Power AGM main battery, Cascadia 4x4 hood-mount solar panel, NOCO X2 Pro charger
    Searched but keep coming up with results for the direct-fit lights.
    I have the square, non-Tundra-specific Baja Designs Squadron SAE fogs for my aftermarket bumper and am trying to sort out what I need to make them replace my OE fogs wiring-wise.
    Any help? Thanks!
  2. Dec 9, 2021 at 8:18 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
  3. Dec 9, 2021 at 8:26 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
  4. Dec 9, 2021 at 8:28 AM
    unsub1
    Steven
  5. Dec 9, 2021 at 8:30 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    2017 Limited Crew TRD, Ironman Pros with JBA uppers. Prinsu rack. RSI, RCI sliders
  6. Dec 9, 2021 at 8:34 AM
    MadMaxCanon
    Should just be plug and play.
    I used these with my Rigid SAEs on ironman bumper.
    unsub1[QUOTED][OP] likes this.
  7. Dec 9, 2021 at 8:36 AM
    unsub1
    Steven
    My lights have round pins. Again, I'm probably missing something simple.
  8. Dec 9, 2021 at 8:37 AM
    MadMaxCanon
    Those adapters have round pin heads to go into your fog and the factory style on the other end to plug into your factory fog harness.
  9. Dec 9, 2021 at 8:56 AM
    unsub1
    Steven
    These are the ends on the Baja side. The first pic is the end of the harness I'm not using, the second is the pigtail on the light.
  10. Dec 9, 2021 at 8:56 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    unsub1[OP] likes this.
  11. Dec 9, 2021 at 8:58 AM
    unsub1
    Steven
    I think I have everything to cut and set up the adapters I bought, just surprised I have to.
  12. Dec 9, 2021 at 9:03 AM
    MadMaxCanon
    Ah ok, guess the BD is a different style. You will have to do some chopping or find another premade harness on Amazon for that style.
  13. Dec 9, 2021 at 9:07 AM
    unsub1
    Steven
    I have adapters just like yours and the BD head and some pins the lights came with. Hopefully cutting the bad end and adding those works okay.
  14. Dec 9, 2021 at 9:10 AM
    MadMaxCanon
    It should if you just solder the necessary wires.
  15. Dec 9, 2021 at 9:14 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I have these crimpers, they're not the best but they're invaluable for properly crimping the terminals. I also solder my wires to the pins but that's not 100% necessary.
  16. Dec 10, 2021 at 8:26 AM
    unsub1
    Steven
    Well, my stop-gap was to splice together the Amazon harness I got with the one the lights came with. After blowing 3 fuses, I got the polarity correct and I'm set until I can get some real ones..... if Baja Designs ever respond to me!
