Undercarriage Treatment?! Yay or Nay?! Pros & Cons?!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spyker, Dec 5, 2021.
  1. Dec 6, 2021 at 10:21 AM
    Kornbread
    Kornbread New Member
    For the past 3 years I've sprayed my wifes pathfinder and my (ex) tacoma with Fluid Film.
    This year I switched to WoolWax and so far I've done her pathfinder, my 4 runner and I'll probably do my Tundra this weekend. So far I think the WW goes on a little heavier, I think I used more initially than I did with FF. The black color is nice on older vehicles that are starting to show some wear on the undercarriage, makes it look nice and fresh. The Tundra is still new so I'll do it in the clear version.
    YorkT likes this.
  2. Dec 6, 2021 at 1:01 PM
    Demar002
    Demar002 New Member
    Frank
    2022 Toyota Tundra
    I have used
    CRC 06026 Heavy Duty Corrosion Inhibitor
    On my Boat Engine - It is amazing.
    My question - Where specifically are you spraying this on the undercarriage. I am about to purchase a new Tundra. I would like to protect the undercarriage. What is the best way to do this. I would use the CRC. Please keep in mind, I do not have a lift.
    Thanks
    Frank
  3. Dec 6, 2021 at 1:35 PM
    jomikepa
    jomikepa New Member
    O-H-I-O
    21 black truck
    There are several videos showing the fluid film being applied. I'm also somewhat worried about hitting all the correct spots, while missing the ones that shouldn't be hit (exhaust, seals, etc). I don't have access to a lift and know it's a messy job, so I just made an appt to have mine sprayed w/ Sta-Bil.
  4. Dec 6, 2021 at 2:02 PM
    tundrasportinMA
    tundrasportinMA New Member
    Western Mass
    2019 Tundra Sport DC
    6112/5160 , SCS Ray 10's, Cooper Discover AT3 -295/70/18, Dirty Deeds 8inch, N-Fab Podium
    I see you have the cat protection shields, I have some on order myself. Silly question but I assume you did the fluid film before getting those or took them off first ?
  5. Dec 6, 2021 at 3:07 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Yeah had the fluid film done first and then had my mechanic install them.
  6. Dec 6, 2021 at 3:09 PM
    angkorstrong
    angkorstrong New Member
    2020 Sequoia TRD Pro
    does any of this stuff make a mess when ur working under the car to say..do an oil change?
  7. Dec 6, 2021 at 4:23 PM
    Spyker
    Spyker [OP] I’m a dude,playin a dude,disguised as another dude
    Does anyone know if our frames are treated with anything from the factory?
    Any Toyota techs/mechanics on here know for certain? I know some manufacturers coat their frames in chemicals or a type of sealant, others do something similar to powder coating, where they run a charge to the frame and then spray it with the opposite charged particles (I.e. the rust inhibitor)?
  8. Dec 7, 2021 at 8:51 AM
    Corrosivetendency
    Corrosivetendency New Member
    Nate
    2016 plain-jane d-cab
    I layed under my truck with safety glasses. It can get frustrating with clearance but not as messy as I had figured. Near zero over-spray and no dripping onto my sidewalk. Warmed the FF in the oven at 120, and sprayed on a 60 degree day.
    jomikepa likes this.
  9. Dec 8, 2021 at 7:04 AM
    Spyker
    How many cans of Fluid Film would it take to coat the bottom of our trucks?
    What are the major things to keep in mind when doing so?
    avoiding rotors, brakes, exhaust, anything else?
    What’s the optimal application temp? Thanks
  10. Dec 8, 2021 at 7:07 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    I used 5 cans, but I did it heavy, moved spare, sprayed in all the internal or boxed in areas with a nozzle through the air vent holes. Spent nearly two hours working at it.
  11. Dec 8, 2021 at 9:07 AM
    vtl
    vtl New Member
    Boston 'burbs
    19 Red SR5
    I saw a 1996 Ford Ranger few years back (driven by state park rangers, ha-ha), its frame was treated with a "tar application" 30+ years ago. It spent its all life in humid and salty Cape Cod and had zero frame rust. All untreated Rangers did evaporate here decades ago.
    Krown still allows rust to grow over time. Like, Krown and alike are better than nothing, but not the best. Also it's not a one time treatment, you have to pay them every year and leave oily marks on your driveway for a few days after treatment.
    So when I've got my new 2019 Tundra I sprayed it myself with Noxudol 1600 (tar-like) and 700 (very agile wax) in cavities. Yes, it was sticky for some time, but now it's mostly cured and dry to touch. Though when the frame is hit by road debris and gets a nick through the tar, Noxudol heals itself over time, which is nice. Done once and forgot about frame rust.
    Also the truck is quieter now, that tar seems to cancel a good part of road noise transmitted via the frame.
    kleiker0303 likes this.
  12. Dec 8, 2021 at 9:21 AM
    jac70
    jac70 New Member
    Southern N.H.
    2021 TRD Off Road
    I think most any of these will work well. I've been using Fluid Film the last 5 years and bar & chain oil the previous 25 on all my vehicles. I apply about 3/4 of a gallon with the air compressor/gun and use a couple of the spray cans with the flexible hose inside the doors, hood and tailgate, the flexible hose really works well in the small drain holes on the doors, gets right up in there for a thorough application. Not sure if the frame comes treated from the factory but I spray the piss out of it! theres also some plastic caps you can remove on the frame for better access to the inside of the frame and don't forget to remove the rubber plugs on the bottom sides of the rockers, all kinds of crevices to be sprayed! You can also get creative and remove bolts in your door pillars and coat those areas too. If you look at the inside of the body panels (underneath the bed) it appears to be coated from the factory but I'd spray those areas as well, let 'er rip! don't be shy with that stuff. Don't be to concerned about coating things that don't need it, it's gonna be all over everything including you! oh, wear a mask, you don't want to be breathing that stuff!
    I would avoid the old school tar like applications, plenty of videos out there and I've seen it first hand, it can do more harm than good in the long run by trapping moisture and salt behind the application after it has dried out over the years. But there is a new product out there call Noxudol, it's a petroleum based "tar" like product that's supposed to stay flexible, it looks really good but time will tell.
    Whether its oil, FF or WW I would definitely recommend one of those if you live in a salt belt and would like to keep your truck for a long time.
    Tundra1078, classiccat and Boerseun like this.
  13. Dec 8, 2021 at 9:35 AM
    jac70
    jac70 New Member
    Southern N.H.
    2021 TRD Off Road
    The problems with the tar like applications is that they DO need upkeep, they are not a one and done type product. My guess is that ranger probably had been touched up several time to keep it in such good shape. I've seen vehicles where this stuff gets chipped away and then when it dries out it makes a nice little pocket for water/salt to collect and it goes unnoticed for years while your frame takes on strength characteristics of tinfoil. I'm not saying its a bad product, I've seen vehicles that have lived long with this stuff but it does need to be maintained. In fact the local Noxudol rep offered the first 4 years of "touch ups" for free and then I would pay thereafter, thats why I decided to stay with FF/oil products.
  14. Dec 8, 2021 at 9:40 AM
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    My vote is for Wool Wax as well.
    75466BBE-FC1A-47FC-A01C-1412B52A6836.jpg 4E0ED72D-ED31-4267-976C-F1D9D740E17C.jpg EA52F304-6DFB-4D19-9EFB-BEB2DB573F10.jpg
    WVI likes this.
  15. Dec 8, 2021 at 9:43 AM
    vtl
    vtl New Member
    Boston 'burbs
    19 Red SR5
    Yeah, it's like oil change at dealer ;)
    For me the biggest "pro" for Noxudol over rivals was the rumors that Volvo uses Noxudol/Mercasol for factory treatment. I own a 05 Volvo w/ 266k North Eastern miles on the clock, very little rust. Similar car (year, model, even color) didn't have any rust at all, but I wrapped it around a boulder :( The replacement car, as it seems, has never been washed in winter, which certainly takes toll on metal, even good one.
    Anyways, any anti-rust treatment is miles better than no treatment. It pays off.
  16. Dec 8, 2021 at 9:51 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Is Krown a rare thing in the States? Krown works well in Ontario and Ontario LOVE to spray salt/brine on the roads.
  17. Dec 8, 2021 at 11:26 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Had my truck sprayed last week with fluid film. I think it is worth having it sprayed with FF or NH-oil or something to keep the salt off the undercarriage.
  18. Dec 8, 2021 at 1:06 PM
    GratefulDean
    GratefulDean Swagless
    Dean
    Rocky Mountains
    2020 Tundra SR5 TRD in Cement Grey
    Bed Rack, Decked System, Softopper
    First thing I thought of...
    Tundra812 and classiccat like this.
  19. Dec 8, 2021 at 1:19 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Anyone use NH oil? Applied the back to black and it did pretty well for my surface rust and generally brown undercarriage. I'm talking very little rust, never lived in a salt state. Just as a way to cover the unsightly brown. I'm looking to reapply again, and wondering if anyone else has any experience here. I see some other posts, but this one seems pretty active.
  20. Dec 9, 2021 at 8:47 AM
    #50
    34ford
    34ford New Member
    2018 sky silver DC 5300 miles
    none yet
    Have used CRC product x 35 yrs. Used to be called CRC Soft Seal and only marine dealers carried .Buy 2 cheap drop clothe(plastic) use trash bags and blue tape to mask off areas you do not want spayed. WEAR a good carbon filter mask ,when finished leave drop cloths down for 12 hrs, to catch any drips you will not have to retreat unless scratched off . I started using it in mi 70 to treat GM trucks that rusted bottom of doors and wheel lips. NEVER had one rust if treated from new. 34 Ford
  21. Dec 9, 2021 at 10:22 AM
    #51
    ScottsBad
    ScottsBad New Member
    Scott
    Free Idaho, escaped Commiefornian
    2018 TRD Limited
    Just a Bed Rug, Soft Topper, Console Safe
    I moved to Idaho from California back in August. Brought my Tundra and bought a 4Runner when I got here. I asked the dealer about undercoating and he looked at me like I had two heads, like no one had ever asked him about that. Said he'd have to look into it, last time I heard from him.
    Is there a chain that does undercoating, and does a good job?
    Had Kings put on my 4R, they said I need to spray them with spray wax to reduce corrosion, I used one of the Turtle Wax versions
    Turtle Wax T-477R ICE Spray Wax. Drys clear. I may add fluid film on top, but I think Fluid film will collect dirt rather than repel it.
    Never needed extra undercoat in Commiefornia. Anyway, I bought 6 cans of Fluid Film and tried it first on the new snow blower to see how it coated the inside. I put it on thick. Interesting stuff, it leaves a fairly thick oily film which I'm sure will help to keep the snow from sticking. I had to heat my garage up for a few hours to warm things up for testing. Next year I'll do it early.
    I'm just not sure how well I can get the underneath of the Tundra and 4R coated. I'll use those drive on stands I guess, to get it up higher. I'd like to just pay someone to do it. I gotta get a new floor jack too.
    Tundra1078 and Spyker[OP] like this.
  22. Dec 9, 2021 at 12:02 PM
    #52
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Eibach pro 2.0s, toytec progressive mini AAL, ARE CX cap, Airlift bags, Harrop Supercharger, 650cc injectors, 77.5mm pulley, TRD Dual exhaust, J&L catchcan, Powertrax LSD, RRW RR7-H, 305/70r17 Toyo AT3s
    I did mine with woolwax black about a month ago. No doubt it should work to prevent rust but man was that a PITA not having a lift and sliding around under the truck on a creeper. Don’t forget to wear garbage clothes as well. I also recommend hitting the sheet metal underside of the bed since they like to rust through from underneath. Remove the spare tire to get better access. I chose WW over fluid film mainly due to the odor. WW has its own weird smell it’s just not as bad in IMO.
    BravoDeltaRomeo and Spyker[OP] like this.
  23. Dec 9, 2021 at 12:06 PM
    #53
    RusPro21
    Don
    Pa.
    I have heard this more than once about the fluid film smell. I had my 4runner Pro done when I had it and now my LunaRock pro done. I park it in my heated garage and I don’t smell it. My wife has a better sense in smelling stuff and she has not said anything about the smell. Could be they were driven a little distance before they were parked in the garage.
    Spyker[OP] likes this.
  24. Dec 9, 2021 at 12:15 PM
    #54
    Spyker
    All great information people, keep it coming, thank you :thumbsup:
    2mchfun likes this.
  25. Dec 9, 2021 at 12:28 PM
    #55
    jac70
    jac70 New Member
    Southern N.H.
    2021 TRD Off Road
    Fluid Film smells like sour milk. Lasts for about a week or so then disappears.
  26. Dec 9, 2021 at 12:30 PM
    #56
    RusPro21
    Don
    Pa.
    I have a local guy that does it and a really good job. $170.00 he will keep doing it for me. Well worth it with this shit that eats everything they put down on the roads.
    WVI and BravoDeltaRomeo like this.
  27. Dec 9, 2021 at 12:43 PM
    #57
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Hey Russ can I ask where in PA you are located? I don’t want to get into this myself and all the places I call want to do a rustproofing system (Ziebart and Linex each have their own) which have seen some pretty bad things about. Looks like the closest to me is Krown in York but that’s 2 hours away.
  28. Dec 9, 2021 at 1:06 PM
    #58
    RusPro21
    Don
    Pa.
    No problem Dennis, Do you know schuylkill haven pa? I always mention this place also every seems to know it or been there. The Big Cabela hunting store on 78? The guy that does it also does detailing. He is really busy doing fluid film. The price is right.
    classiccat likes this.
  29. Dec 9, 2021 at 1:17 PM
    #59
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    I have an appointment tomorrow at the Krown in York. Hopefully all goes well.
  30. Dec 9, 2021 at 1:29 PM
    #60
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    I use NH oil once a year. I’ve used fluid film before as well but find it washes off very easily in any area where water sprays up.
