New 2021- Door Eve Guards help
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by usfdrohead, Sep 24, 2021.
  1. Sep 24, 2021 at 9:37 AM
    usfdrohead
    usfdrohead [OP] New Member
    Ughhhhhhh, my lunar rock that I’m picking up in a week apparently has those horrible door edge guards. They are the paint matched ones that are like a metal material. The dealer won’t take them off because they don’t want to be liable for any scratches.
    Does anyone have these? Are they easy to remove? I absolutely do not want these but I’m scared taking them off will scratch the paint because they are not rubber.
  2. Sep 24, 2021 at 9:49 AM
    dzznts
    dzznts New Member
    Tennessee
    2021 Lunar Rock Tundra TRD PRO
    I have them on my LR and no issues so far.
  3. Sep 24, 2021 at 9:49 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Never seen them on a tundra, but I would share you concern. Would prefer they were not installed too. Things like that often end up looking like crap a few years down the road, collecting dirt, coming loose, or other problems with the finish. But since they were factory installed, they will have a warranty for a while.
    I found them- https://parts.toyota.com/p/Toyota__...y-Metallic---C-Cab/69550890/PT9363417011.html
    And yes, metal-Thermoplastic-coated stainless steel. I would be inclined to leave them alone as who know what kind of adhesive or glue was used to install them. Maybe you could contact toyota and ask, of if they were dealer installed, they should know.
    If you do try and remove you need to find out what adhesive was used. I am guessing some sort of 3M thin tape . I would think that using a heat gun (carefully) to heat it up a little and then use a set of plastic trim tools could get them off. But the paint could have scratches under from the install....no way to know.
  4. Sep 24, 2021 at 9:53 AM
    usfdrohead
    yea they are factory installed from what I know. Honestly had I known I may not have signed the paper. Stupid me. I hate those things and don’t want them. I’m so ocd with that kind of stuff too.
  5. Sep 24, 2021 at 9:55 AM
    usfdrohead
    Any chance you have some good pics I can see? I’m more concerned about how noticeable they are and how they look.
  6. Sep 24, 2021 at 10:03 AM
    dzznts
    dzznts New Member
    Tennessee
    Scud likes this.
  7. Sep 24, 2021 at 10:04 AM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    I put them on both my 17 Tundra and 18 Highlander. Wish we had them on the 07 FJ. Really help to protect the door edge and look great.
    my .02 anyway.
    -Mike
    CopFiveO likes this.
  8. Sep 24, 2021 at 10:08 AM
    usfdrohead
    thank you, I guess they are not too terrible…
    I would need to see a full view of the truck to see how noticeable they are . Based on the installation do you think if I take them off I will mess the paint up?
  9. Sep 24, 2021 at 10:10 AM
    frichco228
    Frank
    Virginia
    not bad at all, much better looking installed at the factory than some of the dealer installed items.
    I would not attempt to remove them.
  10. Sep 24, 2021 at 10:12 AM
    Scud
    Scud New Member
    Working on it :-)
    They blend in with Super White very well.
  11. Sep 24, 2021 at 10:14 AM
    Scud
    Scud New Member
    Working on it :-)
    You wont get this.
    dzznts likes this.
  12. Sep 24, 2021 at 10:14 AM
    dzznts
    dzznts New Member
    Tennessee
    They aren't noticeable at all and you will forget they are even installed. I wouldn't try to remove them. To me it's like with fender flares, once installed I'd be afraid to see what's underneath them lol.
  13. Sep 24, 2021 at 10:27 AM
    usfdrohead
    Goodness! Is that from removing these metal guards?
  14. Sep 24, 2021 at 10:28 AM
    usfdrohead
    Ok that’s comforting! As long as they disappear from my eyes and are not killing the clean lines of the truck I won’t care .
  15. Sep 24, 2021 at 10:57 AM
    Scud
    Scud New Member
    Working on it :-)
    No, purchased an FJ and that's how the doors were. Wish they made the door edge guards for the FJ.
  16. Sep 24, 2021 at 11:00 AM
    FirstGenVol Brake Czar
    2002 AC
    There is no way I would remove those. We bought our 2012 Rav4 new and 9 years later those door edges look rough while the rest of the paint looks great. You'll be glad you keep them if you have the truck a long time.
  17. Oct 5, 2021 at 6:55 PM
    DoublePro
    DoublePro New Member
    Just got mines in the mail. Looks like it’s held in by pressure snap? No 3m tape on the back side like I assumed.
    Big Papi likes this.
  18. Oct 5, 2021 at 7:14 PM
    usfdrohead
    Yup just pressure. I’m leaving mine on can’t even see them.
    DoublePro likes this.
  19. Oct 6, 2021 at 11:18 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I’m glad I was able to get them removed off of my build before my LunaRock Pro was built. I only had them do the spray in bed liner. Which I’m glad because it has the tundra name in it. They also took the predator steps off also.
  20. Nov 27, 2021 at 6:38 AM
    JDM FTW
    JDM FTW New Member
    VA
    2021 AG Limited TRDOR
    Are t
    Are these Army Green (6V7)? I’ve been looking for a set for my (6V7) CM and can’t find the correct part number.
  21. Nov 27, 2021 at 7:00 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    These are one of few oem factory upgrades that are worth every cent. Their cheap, functional and in my opinion look great. I have little kids and go offroading so these are indispensable.
    JDM FTW likes this.
  22. Nov 29, 2021 at 6:05 AM
    DoublePro
    Lunar rock color, Contact sparks parts Toyota, give them your vin and they will do the rest
    JDM FTW[QUOTED] likes this.
  23. Nov 29, 2021 at 6:22 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5
    ATF Cooler
    I have them, metal tip next to the handle caught my hand a time or two but I don't even really notice them. My first thought when I picked up the truck I said to myself, "oh it has those, cool." that was the extent of it lol
  24. Nov 29, 2021 at 8:42 AM
    ziggy04
    ziggy04 New Member
    Eric
    2021 Tundra
    I was going to do a search on these and just stumbled on this thread. I'm super mixed on these. They came from the factory on my 21. I suspected they could be a problem and I really just don't like them. Yesterday, with less than 500 miles on the truck I ran it through a car wash for a quick wash. As I was pulling away I looked in the side view mirror and saw something sticking out from the truck at an odd angle. Turns out about 3/4 of the rear door strip ripped off. The first thing I checked was the paint on the door and it looks fine. I pulled the strip the rest of the way off and the part that was still connected came off pretty easily and left no marks. Based on how the bottom section pulled off I think they are just pressed on.
    I'm seriously considering pulling the other 3 off now. I'm always super careful opening doors on my trucks (my kids not so much) and don't do nearly as much damage to my doors as others do to me. I'm considering pulling another one off to see how it goes. The one that pulled off is a little mangled at the bend point and I don't think it will look good put back on.
  25. Nov 29, 2021 at 4:43 PM
    JDM FTW
    JDM FTW New Member
    VA
    If you’re worried about protecting your paint…stop taking your truck through car washes.
    Ginsterkev and Sumo91 like this.
  26. Nov 29, 2021 at 5:22 PM
    Big Papi
    Big Papi New Member
    Massachusetts
    2021 Tundra TRD Pro Black
    DoublePro,
    Looks simple to install just press on, let us know? I just ordered them for my 21 yesterday and they already shipped.
  27. Nov 29, 2021 at 8:01 PM
    bfunke
    bfunke Tundra Curmudgeon
    I’m not worried about dinging my door edges. It’s the idiots who park next to me and ding their door edges against my doors and fenders. I wish they had the black rubber lower door guards that my Gen1 has
  28. Nov 29, 2021 at 8:19 PM
    DoublePro
    i would start at the bottom, do a YouTube search on how to install. Buy a rubber mallet.
  29. Nov 30, 2021 at 5:50 AM
    Big Papi
    Big Papi New Member
    Massachusetts
    I own a rubber mallet. I will check out YouTube, thanks for the tip.
  30. Dec 5, 2021 at 8:24 PM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Install starts at the top. I put them in my truck. Not difficult, but a few places do need a little care and love with the mallet. Definitely nice to save the door edges
