Lifted Leaf Advice...
Discussion in 'Suspension' started by 1BadTundra, Feb 20, 2019.
  1. Nov 29, 2021 at 5:10 PM
    Evidently alot of us have paid but have crappy springs.
  2. Nov 29, 2021 at 6:05 PM
    BlackBetty10
    BlackBetty10 New Member
    Trae
    16 Tundra SR5 Long Bottom
    Just ordered old man emu suspension kit with leaf springs…. 60k on mine and the springs are flat if not slightly inverted. I haul a trailer regularly and have tool boxes which probably adds 200lbs. Didn’t think they would be as flat as 657369E2-F162-48CA-854C-544A57432022.jpg they are though.
    diablodalton likes this.
  3. Nov 29, 2021 at 6:09 PM
  4. Nov 29, 2021 at 6:21 PM
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    What’s the lead time?
    Semper Fi Brother!
  5. Nov 29, 2021 at 6:24 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Mine took 6 weeks to hit my door
    diablodalton[QUOTED] likes this.
  6. Nov 29, 2021 at 6:28 PM
    diablodalton
    Dalton
    Oregon
    What measurements did you need to provide? Also, would I still need to add traction bars to eliminate axle wrap?
  7. Nov 29, 2021 at 7:26 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Never got into the axle wrap question with him as it's not a problem for me. He asked me to measure the width of the pack, height of the pack, height of the lift block, how many leaves are in the pack, and how much weight regularly stays in the bed. For U bolts it's something like this:
    A. diameter of the bolt measured at the thread (Example 7/16, 1/2, 9/16, 5/8, etc..)
    B. distance from inside of one leg to inside of the opposite leg, measured close to the top away from the open end. (Example 2-1/2", 3", 3 1/4", 4" etc..)
    C. distance from inside middle of the top to the end of the legs (example 6-1/2", 7", 8" etc..)
    D. shape of the top (round, square, semi-round)
    E. thickness of the current spring pack, measured close to the center bolt
    F. quantity of each size needed. All U-bolts do not measure the same
    The two most common errors in measuring U-bolts are the width (B) and the length (C).
    That is from an email they sent me. I just found it easier to do all of that over the phone with the U bolt guy.
  8. Nov 30, 2021 at 4:46 AM
    BlackBetty10
    Trae
    Yeah dude, that’s wild. That’s a brand new vehicle in my eyes. I love Toyota’s but they obviously cut some cost on the rear suspension. Mine is a SR5 so I know I shouldn’t expect a beefy suspension like the TRD’s, but damn. I’d expect to get a little more life out of mine. I work with a guy that has a 18 TRD and looked at his springs yesterday, they look great.
  9. Nov 30, 2021 at 5:03 AM
    Yep, its a 2020 SR5. Look at his at 4400 miles....Post # 66030 https://www.tundras.com/threads/wha...5-gen-tundra-today.713/page-2201#post-2515129
  10. Nov 30, 2021 at 5:10 AM
    I ordered mine the day before Thanksgiving. He said 5 to 6 weeks. Ask when you call and you will get a military discount. I ordered mine with 1/2 inch lift (shackles will add the other 1.5) and they were $924 after discount. They will ask you about ubolts and calculate shipping when they are ready to ship.
  11. Nov 30, 2021 at 5:50 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD Praux
    How were they packed for shipping?
  12. Nov 30, 2021 at 6:10 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    When you lift with shackles and don't increase the bump stop heighth it allows the longer shackle to push the spring down beyond it's design limit when the truck is loaded and in motion. This leads to flattening of the springs. Lift with shackles is not a problem, just be sure to raise the bump to compensate.
    AggiePhil, rruff and BlackBetty10 like this.
  13. Nov 30, 2021 at 8:04 AM
    So I have the Toytecs at 1.5 and I am going with the Alcan springs at 1/2 of lift. With the 2 inches of lift and aftermarket rear bumper at 140 lbs, do you think I should get the Timbrens for bump stops? And what size? Mostly daily driving and we own a 3800 lb travel trailer.
  14. Nov 30, 2021 at 8:30 AM
    2mchfun
    I would be looking for either a solid material bump about 1.5" taller than stock or depending on compression rating a compressable type somewhere around 2.5" taller than stock. Personally, I use yellow Sumo springs which gives me just enough and if I load super heavy, it still has some spring to absorb impacts. The nice thing about the Sumo springs is that they are easy to slice diwn to just the right size for the application. Whatever you do, leave about 2.5" of gap between your stop at compression and the frame to allow for good articulation of the axle and shock compression stroke. There is no one size fits all, the key is to just have enough to keep your springs protected against getting put in a compromising position.
    AggiePhil likes this.
  15. Nov 30, 2021 at 8:45 AM
    Gotcha. I'm not too familiar with the Sumos or Timbrens. Being that the new springs were a grand, I don't mind adding springs or Timbrens if needed.
  16. Nov 30, 2021 at 8:48 AM
    2mchfun
    Yep, the cost of my Dobinson's and all the intense labor to swap is what inspired me to throw in the RAS for insurance.
  17. Nov 30, 2021 at 9:29 AM
    diablodalton
    Dalton
    Oregon
    I think all of the rear springs are the same. Only the shocks are different.
    2mchfun likes this.
  18. Nov 30, 2021 at 9:39 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Like this :laugh:
    DZ_[QUOTED] likes this.
  19. Nov 30, 2021 at 9:47 AM
    diablodalton
    Dalton
    Oregon
  20. Nov 30, 2021 at 9:47 AM
    #50
    diablodalton
    Dalton
    Oregon
    Is that a cup of robots??? SWEET
    AggiePhil and Sumo91 like this.
  21. Nov 30, 2021 at 9:48 AM
    #51
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    They weigh over 70 lbs per
  22. Nov 30, 2021 at 9:48 AM
    #52
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Oops
  23. Nov 30, 2021 at 10:16 AM
    #53
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Yikes
  24. Nov 30, 2021 at 10:22 AM
    #54
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    They ship them like that all the time and she said they never have issues.
  25. Dec 1, 2021 at 6:33 PM
    #55
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Good evening sir. To be honest I am kind of disappointed in them. The ride was good at first, but I have had them for about 20k miles and they are really flat. I don’t tow or haul anything heavy. I’ll post up some pics hopefully tomorrow for you.
    I will say the customer experience is great though. Like some other mentioned, talking with them was great and got everything squared away prior to. They answered any questions I had and got me what I needed.
  26. Dec 1, 2021 at 6:37 PM
    #56
    diablodalton
    Dalton
    Oregon
    WELL SHEEEOT!
  27. Dec 1, 2021 at 6:48 PM
    #57
    I'm wondering what they would say about them going flat.
  28. Dec 2, 2021 at 6:47 PM
    #58
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Mine have 5" of lift so if they go flat well I'm hauling elephants or something
    Sumo91 and diablodalton like this.
  29. Dec 2, 2021 at 6:52 PM
    #59
    Install still happening this weekend?
  30. Dec 3, 2021 at 9:50 AM
    #60
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep, tomorrow
