2018 Bluetooth not working after iPhone update
Discussion in 'Audio & Video' started by sbbcc, Nov 7, 2021.
  1. Nov 7, 2021 at 5:17 PM
    sbbcc
    sbbcc [OP] New Member
    Just updated my iPhone to iOS 15. Ever since the update the phone connects as normal on startup and can play music. When talking on the phone through the Tundra it will work for about 5 minutes then either drop the call completely or disconnect. Once this happens you cannot reconnect and if you go to "select device" it shows the music player is connected but the phone is not. If I select the phone icon it bumps me off completely and I do not have option to reconnect either. Once I restart the truck it connects as normal .
    Any fixes?
  2. Nov 7, 2021 at 5:31 PM
    RikkiBobbi
    RikkiBobbi i'm Literally Rikki Bobbi
    RikkiBobbi
    Austin, Texas
    2021 Toyota Tundra TSS Off Road
    Linkit 3.0 wireless CarPlay, Husky Xcut, Tundra metal letter on trunk, upcoming .... Smartcap EVO shell, Rail system, bed cover, ceramic tint including windshield, tinted headlights and tail lights, full time gps alarm system with dash camera front and rear, bull nose for front, debating rear bumper, waiting on long gun locker for under rear seat with seat rail mods to sit flush and not raise back seat, Pedal Commander ordered as well as fender flares and tinted film for front logo and led conversion lights for all interior lights
    I apologize if this sounds simplistic but delete your truck from your bluetooth devices on your phone, then make sure all updates for all apps are done for the moment and either do a full power off and back on or do the mini power off by pushing voice and power button but then hitting cancel as that will clear the RAM/temp memory etc then re add your truck back. It's a simple fix but often thats all it takes, hoping this helps.
    Kung, 1lowlife and Saltyhero13 like this.
  3. Nov 7, 2021 at 6:54 PM
    sbbcc
    Ill take the simplest fix out there. I tried deleted from he truck and phone. Ill give it another shot with a full power off... thanks for getting back to me so soon
    RikkiBobbi[QUOTED] likes this.
  4. Nov 8, 2021 at 4:57 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Try doing a restart on your headunit by pushing the on button and hold it in.
  5. Nov 10, 2021 at 9:29 AM
    mrfreeman
    mrfreeman New Member
    Kenny
    Buffalo
    2022 Tundra SR5
    Have you had any luck? I am dealing with the same issue and have tried all fixes above. I have no problem while listening to music, but it loses Bluetooth while on the phone.
  6. Nov 10, 2021 at 9:36 AM
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    Virginia Beach
    2021 CrewMax TRD OffRoad
    Stock for now
    Tagging in here too. But for my wife in her 2018 4-Runner
    The phone calls aren't disconnecting on her Iphone, but for whatever reason the call transfers back the handset. She can pick up the phone and manually toggle the call back to Bluetooth.
  7. Nov 10, 2021 at 9:38 AM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Un-Pair and Re-Pair
  8. Nov 10, 2021 at 10:37 AM
    RusPro21
    Don
    Pa.
    I read post where a lot were having issues depending what iPhone you have connecting. That’s why I have not rushed into buying a new iPhone. I have a 7plus. Have had no issues with my tundra and none when I had my 2020 4runner Pro.
  9. Nov 10, 2021 at 12:14 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Have had that happen with my phone before, after update. Delete it from the HU and repair.
  10. Nov 26, 2021 at 3:58 PM
    sbbcc
    I’ve tried re-pairing, I’ve updated my phone, made sure the entune app was updated and no fix. After talking on phone for between 3-5 minutes I loose Bluetooth connection. Also the call and hang up button in steering wheel are working intermittently
  11. Nov 27, 2021 at 10:30 AM
    DME109
    DME109 New Member
    I have the exact same issue on my 2019 Limited. I have unpaired and deleted from both head unit and phone (12 Pro). I am at a loss. Real pain in the ass.
  12. Jan 4, 2022 at 9:48 AM
    Klsu24
    Klsu24 New Member
    Kevin
    2017 Tundra
    same issue here on my 2017 tundra. updated software and issues. un-paired and re-paired-still not working
  13. Jan 6, 2022 at 7:49 AM
    hpeeler
    hpeeler New Member
    Same here. Between this and the 2018 brake controller issues I am pretty frustrated
