Auxiliary Backup Lights
Discussion in '1st Gen Tundras (2000-2006)' started by Neo, Apr 13, 2020.
  1. Apr 13, 2020 at 6:41 AM
    Neo
    Neo [OP] New Member
    Alabama
    2003 Tundra SR5 StepSide Access Cab
    Lexus GX460 Rims, Projector Headlamp Drop-ins
    I know a lot of folks have done this to their Tundras. Just thought I'd show the end result on my dad's 1st gen. These activate when you shift into reverse by tapping into the backup light circuit with a relay. He has them angled out a little on each side for better coverage.
    Darkness and thunder100 like this.
  2. Apr 13, 2020 at 6:44 AM
    Cthulhu
    Looks awesome. I used to have those, but I bottomed out in a mud pit and bent the brackets. So, I went with these:
  3. Apr 13, 2020 at 7:33 AM
    Neo
    Neo [OP] New Member
    Alabama
    Really nice and clean look!
  4. Apr 13, 2020 at 11:19 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Nice.
    I added these a while back. They go right in the OEM fixture and made a HUGE difference. I highly recommend.
    https://www.amazon.com/gp/product/B07BMQKSPL/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
    Kimosabe, Darkness and NewImprovedRon like this.
  5. Apr 23, 2020 at 12:26 PM
    Waterboyz
    Waterboyz New Member
    Fredericksburg VA
    2006 Silver Tundra X-SP Double Cab 2WD 18" Wheels
    I did the same thing but with another brand. No regrets. But, then again, I don't spend a lot of time in the R shifter position or hooking up trailered equipment.
  6. Apr 24, 2020 at 7:44 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Nilight (Amazon) specials. They work great!
    Darkness likes this.
  7. Apr 24, 2020 at 9:36 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Yeah, I have been adding lights to my trucks for years. Comes in handy camping and now living in the country where there are no street lights just backing up the driveway.
  8. Nov 17, 2021 at 8:34 AM
    JDM FTW
    JDM FTW New Member
    VA
    2021 AG Limited TRDOR
    Can you explain your components and process please?
  9. Nov 17, 2021 at 8:08 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Can we get a picture from any of y'all with these lit up at night?
  10. Nov 17, 2021 at 8:10 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Just finished mine today
    DarkMint likes this.
  11. Nov 17, 2021 at 8:18 PM
    DarkMint
    Ben
    :eek2::eek2::eek2::eek2: Holy shit, I have to have these now.
    And I thought my LED bulb replacements were an upgrade... this is next level stuff.
    Tundra2 likes this.
  12. Nov 17, 2021 at 8:23 PM
    ErikTRDTUNDRA
    Erik
    No drilling, used existing bumper bolts to attach the lights, wired them directly into the reverse light wire in the tow plug harness so they only come on when the truck is in reverse. Super happy with them.
  13. Nov 17, 2021 at 9:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Have you seen the VLEDS license plate reverse light? I bought one used, and it makes a HUGE difference. It's It's low profile
    Mounts right over the top of the license ate.
    DarkMint[QUOTED] likes this.
  14. Nov 17, 2021 at 9:09 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Here's some in cab shots so you can see what you'd see from inside.
    Punk1974 and DarkMint like this.
  15. Nov 17, 2021 at 10:14 PM
    DarkMint
    Ben
    Talk about light up the night!!! Were these hard to install at all? My wiring knowledge is 0... I still gotta wire up my camper shell 3rd brake light somehow.
    Pros and cons between the bumper light vs license plate mounted LED?
    Tundra2[QUOTED] likes this.
  16. Nov 17, 2021 at 10:27 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Wasn't hard at all. Just replaces the hardware for your plate, and two water proof t-taps into the reverse wires for the tail light
  17. Nov 18, 2021 at 5:42 AM
    Cummins3500
    Logan
    SharkDog and Tundra2 like this.
  18. Nov 18, 2021 at 6:13 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Just read that part about pros and cons of the license plate thing.
    License plate​
    Pro:
    1. Pretty much direct "bolt on."
    2. No cutting.
    3. Fits any license plate.
    4. Clean, and low profile. Isn't seen until in reverse.
    Con:
    1. T-tap for power.
    2. Cost. (I bought mine used, cheap;))
    Bumper lights​
    Pro:
    1. Flush mount.
    2. More lights per kit.
    3. Potentially wider throw of light?
    Con:
    1. Some DIY skill required.
    2. Holes cut in your bumper.
    3. Some wiring needed if using relay.
    4. Keeping install even/level.
    5. Stands out (not low profile)
    DarkMint and Punk1974 like this.
  19. Nov 18, 2021 at 1:26 PM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    Was reading in another thread where guys used hir bulbs in place of factory bulbs in the rev factory houseings pics look amazeing and was cheep
    Tundra2 likes this.
  20. Nov 18, 2021 at 1:41 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I went the hidden route with Rigids, back when Rigids didn't cost a fortune. They throw good light about 30 feet back. Would be more if I bumper mounted them but I like not seeing them. Plus if I'm dumb enough to drive with them on I don't blind anybody, they just think I'm a fast n furios fan.
  21. Nov 18, 2021 at 3:00 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Asmith2945, MS22, flyfisher and 4 others like this.
  22. Nov 18, 2021 at 3:47 PM
    Cummins3500
    Logan
    View standing in the bed with my rigids
    And then same view knelt down beside the rear bumper
    and that fence row is roughly 75 ft away. They’re probably overkill for reverse lights but man they make a huge difference when the camper top is on
    (before paint, post light install)
    SouthPaw, Darkness and Lil Steve like this.
  23. Nov 18, 2021 at 7:40 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 tundra AC
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    I was thinking in adding some reverse light but I wanted to see if there was a way that I can also wire it to a switch to turn on when not in reverse. Maybe with a relay and diode? Anyone have a schematic for something like this.
    ErikTRDTUNDRA likes this.
  24. Nov 19, 2021 at 5:20 AM
    Punk1974
    J.P.
    connect it to your cargo lamp
  25. Nov 19, 2021 at 5:42 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Cargo light doesn't work above 5mph with the button. Still works with the door I think...
  26. Nov 19, 2021 at 6:17 AM
    Punk1974
    J.P.
    push cargo lamp on when going into rev not many ppl go more than 5 mph in rev 2 amps draw on cargo cirkit not much to blow it
  27. Nov 19, 2021 at 6:18 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 tundra AC
    But I want it to come on with reverse and good idea of using the cargo switch. So do you know how to run the wires?
  28. Nov 19, 2021 at 6:19 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Mine are only on a switch. The kit I bought (now overpriced imo) had the relay and a switch. I tossed the switch and ran one that fits the blanks in my dash. That took some patience to wire to because the switch had no details. I blew a few fuses on my lights before I got it right.
    I didn't want them to be automatic but if you want both maybe a 3 way switch would work. Auto/off/on
  29. Nov 19, 2021 at 6:23 AM
    Punk1974
    J.P.
    i have know idea but the cargo switch is right there for an eaze push when needed to add extra light i think the roof cover inside needs pulling to gain access to the cargo lamps and you run a wire from there. posters from a few years back did it here i read.
  30. Nov 19, 2021 at 1:16 PM
    Cummins3500
    Logan
    https://m.youtube.com/watch?v=W2Mr2Zgv1Ck
    I wonder if you could run a 5 pin? Hook everything up like normal for a switched setup but also run that center pin of the relay for a constant hot from the trailer plug so that they deploy in reverse :monocle:
