Leaking Snugtop cap
Discussion in 'Tonneau Covers, Caps and Shells' started by CCTundra, Mar 26, 2017.
  1. Mar 26, 2017 at 11:05 AM
    CCTundra
    CCTundra [OP] New Member
    Seattle,WA
    2016 Platinum Tundra
    FabTech 4" lift with dirt logic coil overs, Canopy, LT305/55R20 Cooper ST Max, 20" Black Fuel Wheels
    so I have a snugtop cap that I purchased last June. This thing is pretty new. Recently during the rainy months here in Seattle I have noticing a musty smell like moisture in the back. When I lift the bottom bed rug that I have, I saw water. Now I have a lineX bed liner on the back of the truck. I have just the bottom piece of the bed rug. When I called the shop that installed my canopy they said they would take a look at it, but it is common for water to get in anyway. Are you serious??? Doesn't this defeat the purpose of a canopy??? I wanted a canopy to keep stuff dry in the back. His reasoning is that there are too many opening in the back window area that can let water in. The other thing he told me, is that he saw a newer Tundra in yesterday and he found that water was leaking in from the drainage caps in the bed. I guess it is letting water come into the bed. He says it's a manufacturer defect. Have you guys heard of this and have had any issues with this? I am taking this thing in next Saturday for him to take a look at it. Confused how this can happen. I had a tonneau cover on my last truck and I never had any issues keeping in dry. Let me know if anyone had experienced this.
  2. Mar 26, 2017 at 11:18 AM
    gosolo
    Ray
    NW Oregon
    I have a Snugtop also and don't seem to have any leaks. However I live in AZ though, and we sure get a lot less rain than you!
  3. Mar 26, 2017 at 11:41 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Looks like he's trying to make any excuse he can. How the hell does water come in through the drainage holes... unless you're missing the plastic covers. I've never had a cap but I would expect it to be completely water tight. Like you said, what's the point if it isn't.
    gosolo likes this.
  4. Mar 26, 2017 at 3:52 PM
    CCTundra
    Seattle,WA
    Yeah, I'm trying to rationalize it. I'm going to bring it in next Saturday, but it's obvious that water is getting in. I am just trying to see if anyone has had any experience with this.
  5. Mar 26, 2017 at 8:26 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I couldn't figure out why I still had water in the bed of my truck after I changed all of the seals for my Leer canopy and installed a tailgate seal.
    It turns out that there are little holes in the drain caps that do let water in under certain conditions. I filled the holes with shoe goo and haven't had any problems since then.
  6. Mar 26, 2017 at 8:55 PM
    CCTundra
    Seattle,WA
    Wow!! So this does happen? Is this a flaw from the factory? And by holes in the drain gaps; are they easy to see? I had the truck lined with lineX so it's hard to tell. Where are the holes exactly? how can this not be part of recall from Toyota if this is something that is a factory flaw. Could you post a pic of how your drain plugs look after you sealed it? Thank you.
  7. Mar 26, 2017 at 9:19 PM
    15whtrd
    15whtrd Mr. Blonde
    Water can get in in the gaps in the tailgate. Get inside your shell and close everything up and notice all the daylight that you will see in any corner or edge of the bed. I just have a soft Tonneau cover. I did a tailgate seal and added a few pieces to make it practically watertight. Also up at the front where the side rails meet the front rail there is a little gap there too. If you don't have the deck rail system there is holes up font for that too.
    On the weatherstripping where the tailgate shuts and the vertical and horizontal strips meet, I left a little gap at the bottom so that if water does get in it can drain out.
  8. Mar 26, 2017 at 9:35 PM
    CCTundra
    Seattle,WA
    Where were you able to find these weather strips from? I want to make sure that the truck bed is completely water proof. I still can't comprehend how shops can't do this already when they install canopies. I would of paid for this all upfront if I knew it was going to be an issue.
  9. Mar 26, 2017 at 9:38 PM
    careyrob
    Carey
    Massachusetts
    I think the holes are intentional. They're in the same place on both plastic plugs and the holes are small, but square shaped.
    I'll get a picture later and post it.
  10. Mar 26, 2017 at 9:43 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
  11. Mar 26, 2017 at 9:46 PM
    Eclipsed & Floating
    Voluptuous Whitey
    You can find it anywhere online and at autozone. If you aren't worried about ever taking your topper off you can use silicone around the inside of the topper seal. The window seals on the Snugtops are pretty good but nowhere near perfect, especially if your using your topper alot. I've had numerous brands and I've never had a perfect topper, even the really expensive ones.
  12. Mar 26, 2017 at 9:59 PM
    15whtrd
    15whtrd Mr. Blonde
    As Almaboy said there is a kit or specific seal for tailgates. But it's all the same stuff really.
    You do have to get creative with placement. And i used a piece of foam weather strip on my tailgate to meet up with a secondary piece on the bed itself. Not perfectly water tight if I blast the hose at an upward angle. But its tight for direct line of fire. What ever makes it in is minimal.
    But im sure the shell installer can't guarantee no leaks on a tailgate because of its poor design. So they would rather not attempt to seal it.
    Eclipsed & Floating likes this.
  13. Apr 1, 2017 at 4:13 PM
    CCTundra
    Seattle,WA
    So I'm here at the canopy shop. They found where the leak is coming from. There was water coming in from the drain plugs in the back of the bed and the upper left corner of the bed. Gary, the owner of the canopy shop says that this is a factory flaw from Toyota. They don't seal the bed of the truck very well. His tech was able to seal the drain plugs and the corner of the bed with some kind of glue or gue. Hopefully this remedies this. IMG_7023.jpg
  14. Apr 1, 2017 at 5:28 PM
    gosolo
    Ray
    NW Oregon
    I can't imagine any reason any truck manufacturer would be making tailgates waterproof. This is not a flaw. Truck beds have been for cargo for over 100 years. Because recently some of us are treating our truck beds like big car trunks is not their fault. I'm not opposed to the idea, and I've made a fairly successful effort to do this on my own(more for dust than rain, in AZ). Get creative, there's lots of products available to facilitate this. Just my.02
    15whtrd and TheBeast like this.
  15. Apr 1, 2017 at 8:50 PM
    CCTundra
    Seattle,WA
    I can understand your point of view, but I would think that if you purchase a tonneau cover or canopy, you would expect that your cargo would be kept dry or dirt free. My old Ford F-150 had a pace Edwards power cover. I never had any issues with keeping stuff dry in there. Now don't get me wrong, I love my Tundra. It would just be nice to know this when they installed the canopy.
  16. Apr 1, 2017 at 9:03 PM
    gosolo
    Ray
    NW Oregon
    Good point, I just thought that the idea of a Toyota recall for this was a bit over the top. I'm fully on board with leaks at the camper or tonneau cover interface being unacceptable. A tailgate that has seals like a cab door would add incredible unit costs and not even be desired by fleet buyers. It would be cool if manufacturers offered this option and I bet some of the big 3 will within 10 years. Toyota never will.
    15whtrd and CCTundra[OP] like this.
  17. May 15, 2017 at 9:18 PM
    NW-TUNDRA
    NW-TUNDRA New Member
    Mill creek wa
    2014 SR5 TRD OFFROAD
    Spyder front and rear lights trd grill. Trd exhaust. Cold air intake. Snugtop rebell canopy. Color matched bumpers 20x10 XD WHEELS. Level kit. N fab side steps
    Hey guys I just bought a snugtop rebel and it keeps leaking by the front rail system. I took it in and the guy re sealed the whole canopy and still leaking. Anyone have better luck with different brands? I am on my second snug top the first one was a base model and leaked so much after 5 attempts to fix it the place I bought it from upgraded me to the rebel at the same cost. But still no luck thanks
  18. May 17, 2017 at 9:38 PM
    CCTundra
    Seattle,WA
    Man, mine is still leaking now again. I had mine sealed up, but I noticed that it was leaking from somewhere else. It
  19. May 17, 2017 at 9:44 PM
    15whtrd
    15whtrd Mr. Blonde
    Check that spot right there. That is one of the few places I see daylight with my bed cover on. There is a seam where the front of the bed meets the side rail and it is a good spot for a leak. I've been thinking of filling that gap with black silicone and then reinstalling my bed cover.
  20. May 17, 2017 at 9:50 PM
    CCTundra
    Seattle,WA
    Thanks for the heads up. I will definitely try that
    15whtrd[QUOTED] likes this.
  21. May 18, 2017 at 4:27 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    I have had ARE toppers on several of my trucks over the years. I have never had a leak with an ARE topper when installed right, not that it does not happen. They all will leak of not installed properly. I always have the installer use a double seal especially on the front lip of the bed rail corners, right where yours appears to be leaking. Also put the seal on the topper NOT on the bed rail of the truck, you will spend forever trying to remove the seal later if it's installed on your bed rail.
    The other point is to make sure Banana Joe installer does NOT put his super human gorilla grip crank down power ranger arms on your topper C clamps. :rofl:They need to be snug tight, not crimping the seal. Crimping the seal will result in leaks. As far as your window leak...that could be a leer topper issue or they could have tweaked the seal on the window when installing the topper.
    If they say they have fixed it, run your truck through a brushless car wash and check it. :thumbsup: It should not leak if they know what they are doing. No expert here, but like you I don't want water in my truck bed when covering it with a $2000 topper.
    CCTundra[OP] likes this.
  22. May 18, 2017 at 7:55 AM
    NW-TUNDRA
    Mill creek wa
    Mine leaked at the windOw as welll I watched the guy take a part the window and re seal it and that fixed the leak. As for the corner of the bed where you see Day light that's a tundra defect mine had the same thing and the guy also sealed it. Mine is leaking from the the middle where the top meets the bed. The funny thing is he also sealed the whole bed around the perimeter. So I'll give it one more shot and see if it will fix. If it I might go the ARE rout.
  23. May 18, 2017 at 7:56 AM
    NW-TUNDRA
    Mill creek wa
    Thanks my driveway had a slant so do you think it's because of that why it's leaking?
  24. May 18, 2017 at 8:02 AM
    NW-TUNDRA
    Mill creek wa
    This is where my top is leaking from.
  25. May 18, 2017 at 8:45 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I have a snugtop and they are well built, however, I found the drain holes they put in the lower window frames weren't big enough to accommodate the volume of water accumulating in the window tracks and it was coming inside under the windows. I used a small drill bit and added more holes to the outside lower track. This fixed my issue. Another thing I noticed if I spray water up into the fender it will work its way under the bedrail and into the bed. I sealed this with closed cell foam it it no longer comes in. I have also installed a tailgate seal for dust and this works well. I did all of this while I lived in GA, here in CO my only concern is the dust because I sleep back there a lot and don;t won;t choke on fine road dust.
    SiberianTundra likes this.
  26. May 18, 2017 at 9:49 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4 x 4
    Toytec -Duratrac -Expedition One-Fab Fours
    What he said. My installer did a little caulk job on the truck bed in this area.
  27. Jul 17, 2017 at 4:03 PM
    khallyro
    khallyro New Member
    2006 Tundra 4x4 TRD Double Cab
    These are GREAT suggestions.
    What type of seal would you recommend applying to the topper?
    Same type commonly used to seal tailgates?
    If not, all suggestions welcome!
    Thank you!
  28. Jul 17, 2017 at 5:28 PM
    15whtrd
    15whtrd Mr. Blonde
    On my previous topper there was a 1-1/2" or 2" wide by about a 1/4"- 1/2" thick soft quality foam that was stuck on to the bottom of the topper. Then a thinner strip along the front rail
  29. Sep 23, 2017 at 7:58 PM
    Tundra9831
    Tundra9831 New Member
    every time I think I want a topper I read threads like this and realize this sort of thing will be frustrating for me.....ahhhh, what to do
  30. Sep 23, 2017 at 9:19 PM
    gosolo
    Ray
    NW Oregon
    I’m on my third snug top and have had no leaks.
