Aluminum Oil Filter Housing Cap for Tundra - Is there one or not?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 45er, Nov 3, 2021.
  1. Nov 3, 2021 at 3:49 PM
    45er
    45er [OP] New Member
    Rob
    2021 SR5 Crew Cab 4x4
    Tonneau Cover
    I had a very bad experience with my 2016 Tacoma when the plastic oil filter housing broke during and oil change. I went to buy an aluminum one for my new Tundra and was told by the Toyota dealer that they have one for the 6 cylinder Tacoma but not for the 5.7 liter Tundra. One online dealer told me that the 15620-31060 would fit the Tundra but the dealer says no.
    If Toyota, or any other reputable third party makes a good metal oil filter housing cap, would someone please give me the part number or a link to buy one. I don't want to go through what I did with that Tacoma again!
    Thank you.
  2. Nov 3, 2021 at 3:50 PM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    Barrett50 and AZTundra like this.
  3. Nov 3, 2021 at 5:02 PM
    45er
    Rob
    Tonneau Cover
  4. Nov 3, 2021 at 5:03 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    21 SR5 TSS Onroad, 24 Camaro 2SS 6.2 L
    To much to list:)
    There are two tabs that hold it in you have to bend the tabs to take it out to put into the metal one then bend the tabs down to hold it in place. I broke one of the tabs while they were changing my oil a couple years back and just by luck parts was open and had the metal housing in stock so I had to take the short one out and replace with the long one in the plastic. Patients and gentleness when messing with the prongs.
    Hoodrat_tundra likes this.
  5. Nov 3, 2021 at 5:07 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I went back to the OE plastic one when the aftermarket aluminum housing started to leak. Chances are you'll be better off with an OEM part but now I figure if it ain't broke don't bother fixing it. Still have to clean a bunch of oil off the top of my skid plate :)
  6. Nov 3, 2021 at 5:09 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I put the venzas metal one on my tundra and will put another on the sienna we just put purchased. The tundras filter is taller than the venzas and therefore you need to swap out the shorter support for the longer one. It's very simple. You'll need a flat head screwdriver. It took me less than 5 minutes to do. I highly recommend this swap. It will save you headaches down the road.
    Edit: Over a 100k miles with aluminum housing and no problems or leaks.
  7. Nov 3, 2021 at 5:14 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Also have the Venda aluminum oil filter housing installed. Truck has 20,000 miles on it with the housing and performs flawlessly. Would do this swap again and again.
    2021 Semi Pro likes this.
  8. Nov 3, 2021 at 5:14 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Anyone have part number to factory plastic one?
  9. Nov 3, 2021 at 5:14 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    2017 Limited Crew TRD, Ironman Pros with JBA uppers. Prinsu rack. RSI, RCI sliders
    BlueCrushSC16 likes this.
  10. Nov 3, 2021 at 5:16 PM
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    Then the answer to your original question is "No. There is no metal housing made specifically for the Tundra." The filter tube swap is really simple, and commonly done though. To boost your confidence on it, I would suggest you stop by a dealership's part counter and ask to see a filter housing for your truck. You can look inside of a clean new one and see just how it would pop out and transfer to the metal one that has a short filter tube.
    AZBoatHauler, Bammer and Ely010606 like this.
  11. Nov 3, 2021 at 5:17 PM
    Wyoming
    WhistlingPete72 likes this.
  12. Nov 3, 2021 at 5:21 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    The main housings are all the same weather it’s plastic or aluminum- the only difference between motors 6/8 cyl is the filter element is shorter for 6cyl therefore as already mentioned you will just have to swap the LONGER center shaft out of your plastic junk and put it in the new aluminum housing to match your tundras longer element- it’s by NO means a hack job- 1000’s of fellow tundra owners have done this with NO ISSUES- including myself on both of my Toyota’s
    only way it will leak is if you install the 2- seal rings INCORRECTLY - nothing to do with the element shaft you are swapping over
    WSJ, JLS in WA and Black@Blue19 like this.
  13. Nov 3, 2021 at 5:30 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Just swapped over to the metal one. Get oem and you won’t have any issues.
  14. Nov 3, 2021 at 6:02 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5
    ATF Cooler
  15. Nov 3, 2021 at 6:04 PM
    OHwendTrd
    Josh
    21 SR5
    ATF Cooler
  16. Nov 3, 2021 at 6:28 PM
    TTund16
    TTund16 New Member
    There was a nice video of how to swap the guts with the longer one that comes with the truck.
    Is the video a sticky or hidden somewhere in one of the threads?
    Black@Blue19 likes this.
  17. Nov 4, 2021 at 4:10 AM
    Danman34
    Danman34 New Member
    Danny
    If you can change the oil in these trucks, you can swap the inlet tube. It takes 10 seconds
  18. Nov 4, 2021 at 6:39 AM
    45er
    Rob
    Tonneau Cover
    You guys convinced me. Ordered the aluminum housing last night. I'll be super careful when I remove the filter support cylinder. As a side note, I went ahead and spent one of my two "free" oil changes at the dealer yesterday. Truck had 657 miles on it. Figured I'd do this to ensure I'd get the metal filings from the machining work out of there early!
  19. Nov 4, 2021 at 8:05 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Curious to how many metal filings were actually there? Enough to clog the filter and prevent it from filtering oil?
  20. Nov 4, 2021 at 8:46 AM
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    Don’t forget to order the Fumoto valve drain plug and tubing and the MotivX wrench set, which itself comes with tubing to drain the housing before removing it. Can do an oil change with no mess whatsoever. That’s possible anyway but tough to do and tougher in these trucks it seems
  21. Nov 4, 2021 at 9:12 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    That's the one I got as well.
  22. Nov 4, 2021 at 10:58 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Thanks for reminding me that
    Not enough to clog it, but when I changed mine at about 500, yes shavings were present. Not a good thing!
  23. Dec 17, 2021 at 4:29 PM
    WSJ
    WSJ New Member
    W
    Phoenix AZ
    19 Platinum 5.7 4WD Crewmax
    Sadly, they all have these to a noticeable and regrettable amount of metal in the filter. 2010 Avalon and 2019 tundra. Secondly, Toyota hack technicians do not know how to do an oil change. An o ring, not a compression gasket, seals the large canister. A spring and notches keep it from unscrewing. The square key plug has a well designed seal and hence low torque also. And if the dammed thing falls out, adequate check valves back it up. Look, see, and learn. And best do your own oil changes to get it right. Next new Toyota of mine will get 100, 500 and then every 5000 oil changes and I will never let a dealer change it unless he gives a blood oath he’ll do it right. An excellent design in the hands of the untrained and unsupervised becomes an abortion. and I am well experienced and well trained to know that of which I speak. And think WTF they’re doing to your pan drain plug. And if they can’t do a simple oil change…
    WhistlingPete72 and jrquist like this.
  24. Oct 6, 2022 at 11:21 AM
    WhistlingPete72
    WhistlingPete72 New Member
    2017 Toyota Tundra SR5 CREWMAX
    OHwendTrd[QUOTED] likes this.
  25. Oct 6, 2022 at 11:24 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Still using my OEM plastic cap with zero issues :notsure:
    hagrid, Joe333x and KNABORES like this.
  26. Oct 6, 2022 at 12:55 PM
    I actually broke mine on my 2013. The filter was tight as hell for some reason. One of the tabs broke off. When it broke, it actually put a hole in the housing. I have a picture of it somewhere.
  27. Oct 6, 2022 at 2:03 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I swapped for the aluminum housing on mine, super easy.. and Fumoto drain valve..
  28. Oct 6, 2022 at 2:12 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Same here, I think the issues with the plastic cap arise from them being torqued on too tight.
  29. Oct 6, 2022 at 2:25 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Oh most definitely. Usually by the winners at WalMart who moved into Automotive from the Grocery dept
  30. Oct 6, 2022 at 2:31 PM
    Joe333x
    Joe333x Member
    Boston
    I've heard stories of people using the filter drain plug to torque them back on too.
