Caliper mounting bolts are single use
Discussion in '2.5 Gen Tundras (2014-2021)' started by pman9003, Oct 17, 2021.
  1. Oct 17, 2021 at 11:58 AM
    pman9003
    pman9003 [OP] New Member
    2020 Platinum 4x4
    Came across this today and thought it was worth sharing. I don't recall ever seeing this mentioned in any of the brake threads or youtube videos covering brakes. Screen shoots are straight from the service manual. Use the information as you see fit.
    Disc Brake Caliper Bolt (Front)
    90105A0336
    Disc Brake Caliper Bracket Mounting Bolt (Rear)
    90119A0282
  2. Oct 17, 2021 at 12:12 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Eh. Been changing my own brakes all my life and I lost count on how many times I’ve removed and reused the caliper bolts. Just have to be sure to clean up the threads and reapply thread lock when putting back together. Never had a single issue ever on any vehicle. Just changed the rotors on the Tundra and reused the bolts. Never thought anything of it.
    Blowdart, chugs, HulkSmurf14 and 2 others like this.
  3. Oct 17, 2021 at 12:31 PM
    pman9003
    2020 Platinum 4x4
    I figured this would be the reaction of most on here. You are right, reusing caliper bolts is pretty normal and I have done it myself on other vehicles.
    There is a major difference here though IMO. Most of the time the service manual doesn't specifically say the caliper bolts are single use. Usually the vehicle's service manual say to re-install the bolts and torque to spec.
    I posted this to share the information as most people just post the torque spec and that's it. What anyone does with the information is not my concern.
  4. Oct 17, 2021 at 12:45 PM
    Danman34
    Danman34 New Member
    Danny
    Yea. Guess since it’s a TTY bolt, they’re just covering their ass. Ironically though, I remember watching some YouTube videos on swapping rotors on the Tundra and a couple in particular were done by actual Toyota technicians. All of them re used the caliper bolt. Haha.
    RitcheyRch likes this.
  5. Oct 17, 2021 at 12:55 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 DC Attitude Black
    Don’t thing they are TTY because there aren’t different TQ specs as a TTY bolt would require. It’s probably because they come with thread lock, which most people don’t put, including me. In all the years of doing my own brakes I have never use TQ specs or thread lock, never an issue. And I can guarantee that not even the techs at Toyota use new bolts or TQ anything.
  6. Oct 17, 2021 at 1:09 PM
    Danman34
    Danman34 New Member
    Danny
    Yea. Probably so on the thread lock. I’ve always used thread lock when putting back together. But I’ve never torqued them to spec. Just get em good and tight. Haha.
  7. Oct 17, 2021 at 1:10 PM
    pman9003
    2020 Platinum 4x4
    The torque specification does not indicate if it is TTY. the give away is when they say not to reuse the bolt. While torque plus angle is commonly associated with TTY bolts, they can still be TTY with a "regular" torque spec. Conversely, just because the torque spec is torque plus angle, it is not necessarily a TTY bolt.
    Honestly are we surprised the dealer techs didn't do something according to the manual?
  8. Oct 17, 2021 at 1:52 PM
    LML 3500HD
    Great information @pman9003
    Using the shop manuals obviously has some real benefits.
    TTund16 and HulkSmurf14 like this.
  9. Oct 18, 2021 at 3:44 AM
    CA1794
    CA1794 New Member
    2016 Bronze 1794
    How did you get access to a modern Tundra service manual? Sorry if this has been answered in the past as I am new to this.
  10. Oct 18, 2021 at 5:41 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I agree on them coming with thread lock. I know replacement calibers for trailers have new bolts with thread lock. My brother had the front pads replaced on his Ford and the dealer did not properly tighten the caliber bolts. It did not end well.
  11. Oct 19, 2021 at 10:19 PM
    TTund16
    TTund16 New Member
    Besides the leftover thread lock residue, maybe the 130 lbf-ft of torque stretches the bolt beyond or near its elastic limits ... hence the new bolt requirements for safety purposes ... just in case.
  12. Oct 26, 2021 at 9:47 AM
    pman9003
    2020 Platinum 4x4
    Ding ding ding.....we have a winner
    Based on the quick check I did (and making a few reasonable assumptions), they are going past the elastic limit at 130lbf-ft. Not by much, but enough to justify the language in the manual.
    TTund16[QUOTED] and AZBoatHauler like this.
  13. Feb 24, 2022 at 10:22 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Good thing I came across this thread. Was on the trail when the truck started making rattling noises. Checked under the truck and one of the bolts literally just fell out - didn't break or anything. The other bolt was finger loose. The crazy part is that I retorqued all of my brake bolts, as I usually do along with other bolts, before I left for the trip. I added loctite on the remaining bolt and used the one big bolt from the rear seat as a temporary replacement.
    Ordering 10 new bolts to replace the others and to carry as spares. Also ordering a new to me brake caliper. Will be using blue loctite going forward.
  14. Feb 24, 2022 at 11:12 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I just removed my caliper brackets and those bolts took a bit more persuasion than I figured they should - likely due to thread lock. I saw that my 2015 version of the FSM called for their replacement and contacted he Dealership to buy new ones - they don't stock them. I don't think the Toyota techs replace them. My FSM says torque the fronts to 73 ft-lbs and 70 ft-lbs for the rear which is what I did. I see your 2016 version says 133 for the front and 123 for the rear. I have a 2017 but the 2015 FSM is what I got from Rockauto. Why the change in spec? Guess I will retorque them....while I'm at it, will order new ones.
  15. Feb 26, 2022 at 6:05 AM
    DCLarston13
    DCLarston13 New Member
    2020 Tundra Magnetic Gray TSS
    In general I reuse those bolts but when you think about it, 133 ft/lbs is pretty high for those bolts, they probably spec no reuse because they are close to yield strength at that torque. A bolt is very much like a spring, it actually is a very tight spring, and like any spring if you stretch it too much it wont come back to its original position. So the bolt may loosen up in service. If have never seen it happen and I have done more brake jobs than I can remember. But as Cruzer mentioned it can happen. Loctite is a solution, kind of. I'll probably order the bolts shortly thou for when I do the brakes.
  16. Feb 26, 2022 at 7:50 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Guess I need to check the torque on mine. I re used my bolts when I rebuilt my calipers 6 months ago
  17. Feb 26, 2022 at 8:11 AM
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
  18. Feb 26, 2022 at 8:24 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Blue Loctite is for relatively low torque value applications. It's breakaway torque is measured in inch pounds. Red Loctite is for higher torque value applications. It's breakaway torque is measured in inch pounds however they are much higher values than blue provides.
    I use blue Loctite on high vibration low torque fasteners such as the floorboard mounting bolts on my motorcycle. Torque spec is 25 lb. ft. Blue Loctite will increase the breakaway torque enough to prevent the bolts from backing out from vibration.
    I use red Loctite on brake caliper bracket to steering knuckle mounting bolts for the same reasons except the higher torque values require a higher breakaway torque value.
    The backside of the Loctite blisterpack card has a table listing the breakaway torque values for the different Loctite products to aid in determining which one you need for your project.
    I hope this helps.
  19. Feb 19, 2023 at 11:16 PM
    tacomania
    tacomania New Member
    The 2015 manual says the specs on that bolt is 70. Not sure how that jumped to 123 seems a lot for caliper bolts.
  20. Feb 22, 2023 at 10:26 AM
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    That is kind of strange. I don't even know what the torque specs are for any of the brakes on my 4 vehicles. And I never use lock-tite on the bolts, I actually use a little bit of anti-seize. Up here in the Northeast that has always worked better for me, and honestly, in the 15+ years I've done brakes on my own cars and side work for friends, I've never had a bolt back out with anti-seize and just hand tightening them to "goodentight" specs.
  21. Feb 22, 2023 at 10:39 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, I think some folks get too carried away with torquing every bolt. I torque things where torque is critical. Head bolts, pan bolts, suspension components, and lug nuts come to mind. My brother had a brake caliper come loose on a F150. I don't think it was from not torquing but just a dealership tech not paying attention to what he was doing. It happened within probably 30 miles of driving.
    Hugemoose[QUOTED] likes this.
  22. Feb 22, 2023 at 11:14 AM
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    Yeah anything when I built an engine got torqued, and like you said, suspension parts get torqued, especially if it's a part that has a bushing. Honestly even with lugs I tend to just have a pretty good feel by now what around 90-100 ft/lbs feels like with the 1/2 ratchet I always use. I get the lugs on with the weakest setting on my impact, then "torque" by feel. If the spec is more than that, I push just a little harder lol.
    I've only ever seen one caliper come loose, and that was a friend who basically dunked the entire caliper bolts in anti-seize. I mean 100% covered, not just a dab down the threads lol. Obviously with that much it could never hold any sort of torque. But he learned his lesson, and luckily it was his own car.
