Vibration while stopped and in gear
Discussion in '1st Gen Tundras (2000-2006)' started by Jesse_Payaso, Oct 21, 2021.
  1. Oct 21, 2021 at 11:59 AM
    Jesse_Payaso
    Jesse_Payaso [OP] New Member
    2003 Toyota Tundra T3 Edition
    I have a2003 Tundra T3 Edition. When I'm at a stop sign or light it will do a loud sound/vibration. When I start to drive it stops, and doesn't do it while I'm park. I've tried to see what it is for awhile but haven't been able to pin point it.
    Thank you!
    Jesse
  2. Oct 21, 2021 at 12:06 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    post up some video of the issue. Would also be helpful to list more about the truck- miles, mods, up to date on maintenance?
  3. Oct 21, 2021 at 12:14 PM
    shifty` Our private little trip to hell
    And is the vibration feeling like ... maybe a rough idle? Or like the truck wants to keep going forward but can't? What do the RPM look like in this case, do they drop or rise, and how many RPM is it while vibrating?
    What happens if you:
    • Shift to Neutral and keep your foot on the brake?
    • Shift to Park and keep your foot on the brake?
    • Shift back to Neutral, but take your foot off the brake?
    • Shift back to park but take your foot off the brake?
    I ask these four questions so we can understand if the vibration is maybe a result of (A) depressing the brake pedal or (B) Braking while in gear.
    You're telling us the car vibrates while it's in gear but unable to move, but it's fine when in gear and able to move. So this is why I wonder what other cases you tried.
    PS seeing your nickname has this stuck in my head.
    https://www.youtube.com/watch?v=Aq1qOE9cayg
  4. Oct 21, 2021 at 3:25 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Sounds like a worn-out transmission mount.
    shifty` likes this.
  5. Oct 31, 2021 at 1:08 AM
    stevechumo
    stevechumo New Member
    Check the mid drive shaft mount. If it sags, then the bushing is broken. Always go with factory Toyota bushing on that. I went with Autozone bushing and it lasted for only 1 week.
  6. Nov 1, 2021 at 5:00 AM
    bmf4069 Yup, that's car parts in a dishwasher
    You got a t3? Got any pics?
  7. Nov 1, 2021 at 1:53 PM
    Any chance your truck is 2WD and you periodically hear a 'thunk' off the line and on bumps? Thinking about T-SB-0067-09 here ...
  8. Jul 23, 2022 at 5:36 PM
    tundrainsc
    tundrainsc Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    I have this problem on 06 dc 2 wd. Anyone had this fixed? Cost? Is it a concern?
  9. Jul 23, 2022 at 5:56 PM
    @alb1k is the only person who comes to mind that's bought the part.
    Seriously, this is something you can absolutely do yourself if you have the most basic tools.
    In fact, many people with this problem have said, backing each bolt out, adding blue threadlock, and reinstalling (hell, just torquing them down w/o removing) solves the problem well enough.
    The big issue is, from what I gather, the material used as shock absorber compresses over time. That basically creates a gap.
  10. Jul 24, 2022 at 8:24 AM
    tundrainsc
    06 Limited 4.7 2WD
    294555845_5630461636976315_6809095327783_92dbd71146067a7a64fba18daa4bf21e1fad5555.jpg
  11. Jul 24, 2022 at 1:27 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I had it a year or two ago. I did the blue loctite and no problems since.
    I even bought the updated bolts, just in case they came loose again but never changed them.
    shifty`[QUOTED] likes this.
  12. Jul 24, 2022 at 3:38 PM
    tundrainsc
    06 Limited 4.7 2WD
    I crawled under to tighten bolts. Found two missing from the mount and other two very loose. Also two missing from the trans housing. I could tell that the two missing from the mount were at one time there because of the color around the holes. The two missing from the housing i could not tell if they were ever in place. I found the two for the mount online Toyota South and are on the way. Not sure what to do about the other two.
    https://share.icloud.com/photos/0082s-jBvkPFLuXZVlTc2gTDA
  13. Jul 24, 2022 at 3:53 PM
    Are these the two you're identifying as "missing from the housing"?
  14. Jul 24, 2022 at 4:45 PM
    tundrainsc
    06 Limited 4.7 2WD
    Yes, Those two holes don't look so important to keeping things together. What are they?
  15. Jul 24, 2022 at 6:09 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Torque converter cover plate, bolts should come from the other side.
  16. Jul 25, 2022 at 4:09 PM
    tundrainsc
    06 Limited 4.7 2WD
    FIXED
    Problem noise is no longer annoying me After tightening the two remaining bolts holding the mount to the cross member. They were both looser than finger tight. I should get the other two I have ordered in a day or two and I'll put them in. I have driven several times and its has not made that popping clunking sound. Its like driving a new truck. Much quieter than my 2018 Kia Optima. Thanks to this this site and is members for your help.
    shifty` likes this.
  17. Jul 25, 2022 at 5:01 PM
    Totally. Do yourself a favor. Get some Loctite blue (specifically the blue one) for installing the bolts on arrival. It's a really, really light threadlock, similar to using fingernail polish to paint something shut. If you ever need to remove it later, you won't need to use heat to remove, like you would with red threadlock.
    Loctite sells their threadlock in a tube, like lip balm, that I prefer to use in cases like this.
  18. Jul 25, 2022 at 5:03 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I can say after having done everything except replace the trans, there is still some let's go now! thud now and then. It's better with the new crossmember and and trans mount, more like rear end take up. 4.7 just wants the skinny pedal I think.
  19. Jul 25, 2022 at 8:00 PM
    tundrainsc
    06 Limited 4.7 2WD
    Thanks, Will do
