2020 TRD Pro Total Coachbuilder or Wescott??
Discussion in 'Suspension' started by Geno 20TRD PRO, Mar 15, 2021.
  1. Mar 15, 2021 at 8:02 PM
    Geno 20TRD PRO
    Geno 20TRD PRO [OP] New Member
    Geno
    2020 Tundra TRD Pro
    Greetings, got my 20 Pro a couple months ago, so forgive me if this is a repeat discussion.
    I'm looking to keep all Fox suspension and want just a little bit of lift.
    Coachbuilder has a TRD Pro complete kit.
    https://shop-coachbuilder.myshopify.com/collections/frontpage/products/coachbuilder-trd-pro-kit-2015
    Seems like a great kit although quite pricey!
    I also see Wescott design front collars with CB rear shackle combo.
    So as a newbie, can I get some expert thoughts on which route to go????
    Thanks in advance!!
  2. Mar 16, 2021 at 3:55 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    I’d measure for lean, 2 shims left 1 right with CB +2 or +3 shackles for some positive rake.
    I’d pass on the CB steering kit.
  3. Mar 17, 2021 at 8:30 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thanks for posting, We have put allot of consideration into our Coachbuilder TRD Pro kit.. To be completely honest adding lift was not our main goal but rather improving handing, steering response, ride quality and weight distribution. You're heavily invested in your PRO and the last thing you want to do is add anything thats going to decrease performance or take life away for your truck. Our kit addresses everything front to back and the value you're adding will not disappoint your driving experience :)
    Hope this helps, please feel free to reach out with any questions. David 801.635.4872
  4. Oct 21, 2021 at 3:47 AM
    joeyk39
    joeyk39 New Member
    joseph
    Tundra Trd Pro White
    none
    I can attest David is a great guy. I just purchased the kit from him and he is there to answer all of your questions in length and detail. Just what you want from someone that sells you something that they made and are passionate about. Great guy!
  5. Oct 21, 2021 at 4:06 AM
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
