Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Oct 20, 2021 at 5:01 PM
    #2281
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Nope, just leave it in the "run" position. You can let sit out and ask to wake up the sensors. They are in a sleep state and adding the air wakes them up.
  2. Oct 20, 2021 at 5:08 PM
    #2282
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    is this the reset? For tpms sensors
  3. Oct 20, 2021 at 5:15 PM
    #2283
    FitsofRage88
    Hill Country, Texas
    Im needing the exact steps nothing is happening..
  4. Oct 20, 2021 at 5:33 PM
    #2284
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Pushing the reset button will reset the psi when the tpms low tire pressure warning will come on. So if you set your ties at 35psi the will come on roughly 25psi. Set the tire pressure to 50psi, push the reset button and warning will come on at 40psi (approx). It takes awhile for the psi to be displayed. Take the truck for a ride and it should reset. The only reason it wouldn’t display the pressure is if you changed the wheel sensors and didn’t register them, you don’t have sensors or the batteries are all dead in all four sensors (very unlikely).
  5. Oct 20, 2021 at 6:10 PM
    #2285
    FitsofRage88
    Hill Country, Texas
    Sounds like i need to register one rrear
    One was replaced all other three were reading fine and then all went blank
  6. Oct 20, 2021 at 6:13 PM
    #2286
    FitsofRage88
    Hill Country, Texas
    this is the reset correct
  7. Oct 20, 2021 at 7:56 PM
    #2287
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Correct.
  8. Oct 20, 2021 at 7:57 PM
    #2288
    FitsofRage88
    Hill Country, Texas
    Could you walk me through the proper steps..
  9. Oct 20, 2021 at 7:59 PM
    #2289
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you replaced one of the wheel sensor the ID# that is printed on the sensor has to be registered using Techstream.
  10. Oct 20, 2021 at 8:04 PM
    #2290
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Each wheel sensor has a unique ID# that is used by tpms module. Using Techstream you can see these ID#. If the ID numbers are not shown in the data stream then they have to be register so the truck can see them.
  11. Oct 21, 2021 at 6:15 AM
    #2291
    FitsofRage88
    Hill Country, Texas
    All four ID shows on techstream
    one was replaced at tire shop three were reading but the one sensor on the right rear wasn't.. all of them now are recalibrating going on days now…
    can techstream recover or scan a new sensor ID?
  12. Oct 21, 2021 at 6:24 AM
    #2292
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Techstream can’t scan the sensors. The IDs your seeing on Techstream are likely the old IDs that were registered. You need a hand held scan tool to read the IDs. The IDs are also printed on each sensor.
    NewImprovedRon likes this.
  13. Oct 26, 2021 at 12:22 PM
    #2293
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Code: P2757
    Meaning: torque converter clutch pressure control solenoid circuit
    2007 Toyota Tundra, RCLB, 4x4, 4.7L V8 base model
    Truck had transmission shudder, fixed with transmission additive (a couple months ago- shudder had been going on for a long time)
    Where should I start? transmission drain and fills? Replace transmission filter? things I should check?
  14. Oct 26, 2021 at 12:24 PM
    #2294
    joseph_womack
    Joe
    Louisiana
    Side note, code only seams to pop up when cruising on longer drives (not in the city) 65+ mph for hour+ drives
  15. Oct 26, 2021 at 2:26 PM
    #2295
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    How many miles on the truck? Have you change the fluid and if you have how does it look? If it’s been shuttering for awhile it’s possible the TC clutch may be gone. It happens more at 65mph on the highway because that’s when the TC clutch is on most of the time.
  16. Oct 26, 2021 at 9:15 PM
    #2296
    joseph_womack
    Joe
    Louisiana
    the fluid has not been changed recently, I did double check the level and it didn't look that dark, not bright red but like a dark red... the shuddering would happen at lower speeds while accelerating (25-30 mph, 1000-2000 RPM)
    Is the TC clutch in the TC? Or is that something separate to be replaced?
  17. Oct 26, 2021 at 9:34 PM
    #2297
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes the clutch is in the TC. You can buy a new TC but most off the time with the clutch fails the material ends up contaminating the rest of the transmission. I’m assuming you know the procedure for checking the level? The reason I asked the mileage on the transmission is because you don’t want to dump a large sum of money into it and get stuck changing it out later.
    joseph_womack[QUOTED] likes this.
  18. Oct 26, 2021 at 9:49 PM
    #2298
    joseph_womack
    Joe
    Louisiana
    oh yes, I'm sorry I didn't answer that question, the truck has 230k on it and original transmission, I do know how to check the level
    do several fluid changes then change the TC?
  19. Oct 26, 2021 at 9:53 PM
    #2299
    joseph_womack
    Joe
    Louisiana
    also, I know how to check the level with a scanner and just watching temp then pulling the check plug
    I was seeing how some guys were waiting till the "D" (assuming shifter) light came on then they pulled the plug? Do I need techstream for that?
  20. Oct 27, 2021 at 5:48 AM
    #2300
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would get Techstream. It will help you with diagnosing the problem and setting the trans fluid level. Start with a fluid change since the oil is dirty and it will give you an idea on the the condition. Without good ATF a transmission will never perform correctly. I don’t recommend just changing the TC. Contaminates from the TC end up circulating through the transmission. I seen quite a few techs change out just the TC and have the shudder issue come up after a couple of weeks. The contaminates will end up back into the new TC and cause issues. You end up having to purchase another TC and the transmission.
    Personally if it was me I would get Techstream and scan for codes and look at the datastream for TC lock up. My feeling is your going to be in for a transmission and TC. With the mileage that you have on your transmission and because the problems has been going on for awhile I would skip the fluid changes to save some money and find a good used transmission with a warranty.
  21. Oct 27, 2021 at 8:38 AM
    #2301
    joseph_womack
    Joe
    Louisiana
    what exactly would I be looking for on the TC lockup data stream? And I’ve got about a gallon of ATF, should I just drain and fill just to see? Or just skip it like you said and go for a remanufactured or used trans?
  22. Oct 27, 2021 at 9:45 AM
    #2302
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    With Techstream you can control the TC lock up or disable it. On the data stream you can see when it actually when it on or off while driving which will help diag. You can also do a healthcheck. It’s your call of the trans fluid but my feeling is that 4 quarts won’t actually help much on a transmission that has around 12 quarts. You might want to save it for the replacement transmission.
    There is a thread on the forum about where to get Techstream for free and what interface to use on your laptop. I posted in that thread on a OBD2 interface that works very well and the cost is quite reasonable.
  23. Oct 27, 2021 at 7:00 PM
    #2303
    joseph_womack
    Joe
    Louisiana
    so what if I just disabled the TC lockup? I guess that would limit drive ability?
    then second thought, what if I replaced the TC and fluid, how long would it take a contaminated new TC to give me real issues? What if I used the shudder fix again?
    thank you for the info on Techstream! I’ll look into that!
  24. Oct 27, 2021 at 7:33 PM
    #2304
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    There is no way you can permanently stop lockup with Techstream. You could manually shift it to 3rd gear and it would stay out of lockup but that really isn’t practical.
    If you’re going to replace the TC you might as well just change out the tranny since you already have it off. I don’t recommend just the TC with a fluid change. The TC will start failing again and you will be doing it all over again. There really isn’t any way to predict how long it would last. It all depends on the condition of the transmission. I’ve seen them fail with just a TC change in a couple of days and others last a month. Any additive that you add is just a band-aid and can’t fix a mechanical issue.
    NewImprovedRon and Wynnded like this.
  25. Oct 27, 2021 at 9:54 PM
    #2305
    joseph_womack
    Joe
    Louisiana
    yeah I figured, so transmission it is; thank you so much for the help and information!!
    Ruggybuggy[QUOTED] likes this.
  26. Oct 28, 2021 at 5:35 AM
    #2306
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you do end up changing the transmission remember to clean or replace the transmission cooler. The clutch material from the TC can block the flow to the cooler. They do make a transmission cooler cleaner. You spray it into the cooler line then use compressed air to blow it clean. Personally I would just replace it. Either take the one off the donor Tundra or get an aftermarket. They are very hard to clean completely out.
    Good luck.
  27. Oct 28, 2021 at 5:45 AM
    #2307
    THORYOTA
    THORYOTA God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
  28. Oct 28, 2021 at 6:44 AM
    #2308
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    joseph_womack likes this.
  29. Oct 28, 2021 at 8:15 AM
    #2309
    joseph_womack
    Joe
    Louisiana
    New thought- I used to work at a mechanic shop… what if I used the transmission flush machine (uses the transmission’s pump, not an external one) and pumped like 30 Qts through it, then replaced the TC?
  30. Oct 28, 2021 at 9:00 AM
    #2310
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I know you really don’t want to replace the tranny but do you want to put money into a high mileage transmission on a gamble? I’ve used that type of fluid exchange machine as well and it a safe way to change the transmission fluid but it will not remove any debri that’s in the transmission. It’s a gamble but the odds are not in your favour and in the end it could end up costing you more.
