Choice between the REadyLift plus2, coachbuilder, or Westcott Designs?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by NLTRDPro, Feb 7, 2020.
  1. Apr 2, 2021 at 5:56 PM
    #61
    Bigslick43
    Bigslick43 New Member
    Napa, CA
    2019 Super White TRD PRO
    SDHQ Sliders Line-X Bed Liner All Weather Floor Matts Westcott Designs Preload Collars Lift Kit Method MR312 18x9 +18 OS Toyo Open Country RT 35”x12.5”x18”
    Just got everything delivered. In the next week or 2 I will get it installed! The tires are so hard to find.
  2. Apr 2, 2021 at 8:44 PM
    #62
    PNWTundra2021
    PNWTundra2021 New Member
    Craig
    Puyallup, WA
    2021 Tundra TRD Offroad
    Limited Faux Pro
    With the Westcott lift, I have 35x12.5x18 Grabbers and there is just a little rubbing at lock on the front mud flaps. I have the Coachbuilder front bumper shims so the air deflectors are not a problem but I will do a little heat gun action on the flaps or maybe a little trim to stop the rubbing at some point. Jeff Westcott advises to remove the air deflector and the front mud flaps and there will be no rubbing but I wanted to keep them as much as I could.
  3. Apr 6, 2021 at 8:21 PM
    #63
    Bigslick43
    Napa, CA
    Got the Westcott Design lift installed today. It gave me 1” in back and 2” up front from center of wheel to fender. Eliminated the 1” rake from factory and cleared 35” tires on Method MR312’s with +18 OS no problem without a BMC. It eliminated body roll and the dip in the front end when you brake. Overall, very satisfied! Overall ride hight is 3 1/2” higher in front and 2 1/2” higher in rear with new tires and lift. I adjusted air pressure to 37psi in front and 40psi in back and rides like a dream.
  4. Apr 14, 2021 at 8:47 AM
    #64
    LAPlatinum
    LAPlatinum New Member
    Hey guys just wanted to ask on the forum first if the westcott Design is compatible with any Bilsteins. Ive seen mainly on Pros but ive also seen a video on their ig and some pictures that the WC collar kit is mounted on Bilsteins 4600 to 5100 and maybe Toyota oem black shocks? Can anyone confirm this.
    Thanks
    Rob's Inferno likes this.
  5. Apr 14, 2021 at 9:58 AM
    #65
    Bigslick43
    Napa, CA
  6. Apr 14, 2021 at 10:21 AM
    #66
    LAPlatinum
  7. Apr 14, 2021 at 8:57 PM
    #67
    woofhauler
    woofhauler New Member
    Pacifica, CA
    I had the readylift +2 sitting around for a while. My topper with a Prinsu caused a little sag, add 250lbs of dogs in the back and I really noticeably sagged so I just thew on the rear blocks. (that's my 4R in the photo too)
  8. Apr 27, 2021 at 10:14 PM
    #68
    JJ_TNDRA20
    JJ_TNDRA20 JJ
    SOCAL
    2020 TUNDRA TRD PRO SW
    *Wheels/Suspension -ReadyLIFT Plus 2 -ReadyLIFT skid plate adapter -Method MR701 18 x 8 + 25 -BFG KO2 305/70/18 *Exterior -BakFlip MX4 hard cover -Rigid Industries foglight caps *Audio -2 AudioMobile 10 in subs -Sealed dual 10 enclosure -Helix Class D 1 channel amp -Helix 4 channel amp -5 channel Line Out Converter -BLAM audio 6.5s/6x9s/tweeters
    Readylift Plus 2...just picked her up today...
  9. Apr 28, 2021 at 7:06 AM
    #69
    Markh314
    Markh314 New Member
    Mark
    2016 Magnetic Gray TRD Pro
    Current Mileage: 82K as if Nov2021 Undercover RidgeLander Tonneau Cover w/ Rack System ReadyLift 2" SST Lift LT295/70R18/10 Nitto Ridge Grapplers
    Just put the deposit down on my ReadyLift2. Going with Ridge Grappler 295/70s on the factory pro wheels. Can't wait. Scheduled for 6/7 intall. With two little ones I don't have time to DIY. Pics to follow.
    GarTX526 likes this.
  10. Apr 28, 2021 at 7:11 AM
    #70
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    2020 Army Green TRD PRO CM
  11. Apr 29, 2021 at 9:52 PM
    #71
    Ron_Pro
    Ron_Pro New Member
    California
    2020 Tundra TRD Pro CrewMax
    Did you use the 1” inch rear block Wescott provides in their kit or did you use another method to raise the rear? Stance looks great.
  12. Apr 30, 2021 at 7:53 AM
    #72
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Anyone here has added a front winch with either set up?
    Luke_Skywalker and kingpin3919 like this.
  13. Apr 30, 2021 at 1:47 PM
    #73
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    I have the SDHQ mount with a 9000lbs Badlands with the Readylift +2.
  14. May 1, 2021 at 4:42 AM
    #74
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Any thoughts from anyone that did the whole Westcott lift? Did it make the ride a little stiffer? I know all of the systems are going to make the tundra feel different in the ride. When I did my AG 4runner pro I added the new Eibach springs to lift it higher. So I could run 285’s. All I can say it made my 4runner ride and handle better. It stiffened the ride up just a bit so no nose dive on braking. I feel the tundra rides just like the 4runner Pro nice ride but I feel it should be a little firmer. That why I ask if anyone did the front and rear westcott lift to see if it firmed up the tundra ride. Thanks.
    Jr3volution likes this.
  15. May 1, 2021 at 5:43 PM
    #75
    Downytide
    GTA
    The hidden mount right? that's the one I've been looking at, did it bring down the front after the +2? I just want to maintain the OEM front height with the winch.
  16. Sep 26, 2021 at 4:58 PM
    #76
    TruPatriot
    TruPatriot New Member
    Lee
    Northeast Texas
    2020 TRD Pro MGM Mall Crawler & Trail Riding Queen
    Interested in lifting my Pro and leaning toward the Westcott front & rear. She’s a daily driver and pulls a bass boat & small trailer from time to time. No major overlanding trails. Has anyone went with Westcott and regretted it?
  17. Sep 26, 2021 at 5:16 PM
    #77
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    Gimme two weeks and I’ll report back.
  18. Sep 26, 2021 at 5:18 PM
    #78
    TruPatriot
    Lee
    Northeast Texas
    Lol…Roger that!
  19. Sep 27, 2021 at 6:07 AM
    #79
    Markh314
    Markh314 New Member
    Mark
    Had her back for a few months now. 2" Ready Lift. Love it. No issues except now I have to replace both lower control arms as the bolts are all seized and it cant be aligned. Did not have another $1,500 in my $1,500 budget. I'm procrastinating at this point since I really don't notice it while driving. The beauty of living by the ocean. My local mechanic used to work on boats and said when they do fix it to have them put some type of marine anti-rust/corrosion on all the connections. Can't recall the name but I did right it down if anyone is interested in the product.
  20. Oct 16, 2021 at 3:22 PM
    #80
    TruPatriot
    Lee
    Northeast Texas
    After much contemplation & research, I went with the Westcott Designs Fox TRD Pro Lift Kit. I think I spoke with everyone at Westcott Designs with the exception of Jeff, multiple times. I told them I was indecisive regarding what to do with the rear, whether I want to use their block or go Coachbuilder Shackles. They spoke very highly of Coachbuilder and stated they use their products (not sure which) in their shop, but after he told me that the blocks they fabricate along with everything else in the kit wouldn’t produce any problems in the long run and that Toyota dealerships are using their lift kit products all over America, I went with the full lift kit. After having the kit installed, I can’t tell a difference at all in the ride. 100% the same. The look is extremely impressive in my opinion. I’m one happy customer.
    Tires - I went with 295/70/18 Toyo AT3’s and couldn’t be happier. I was worried about road noise, but I’m not hearing much at all. As everyone knows, tires are hard to find and nearly everyone wanted to charge over $100 just to have them shipped in. Discount Tire found 4 in Florida and all I had to do was put down a $25 deposit to get them here. I was also given a 10% discount for being a veteran. I’m just as happy with my tires as I am with the Westcott Lift Kit.
    KatoK, Rob's Inferno, FISHN43 and 4 others like this.
  21. Oct 16, 2021 at 3:58 PM
    #81
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    Looks great man!
    I just put their kit up front with CB in the back and 35s. Really impressed with both companies!3456440B-3400-4123-A5C6-607766868A46.jpg
  22. Oct 16, 2021 at 4:40 PM
    #82
    TruPatriot
    Lee
    Northeast Texas
    NICE!!!
    VTYOTER[QUOTED] likes this.
  23. Nov 4, 2021 at 7:39 PM
    #83
    Badge618
    Badge618 New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    Looking at going from the readylift plus 2 to the Westcott collar for the front. The readylift was installed when I bought the truck. Will I have a straight forward switch? Need any original parts? Will the readylift UCA's work with the Westcott collars?
  24. Nov 4, 2021 at 7:58 PM
    #84
    Ron_Pro
    Ron_Pro New Member
    California
    I just received my Westcott front and CB +3 shackles. For those with the Westcott kit, did you guys install the kit yourself or did you take it to a shop? I called a couple of shops and they are not familiar with the kit, but are willing to install it for me. My local 4WP is the only shop that “heard” about the company, but has never installed it. It makes me a little weary of taking it in to a shop that’s not familiar with it, but I also don’t have the tools to do it myself either. Please let me know what you guys did with your truck. Thanks!
  25. Nov 5, 2021 at 8:10 AM
    #85
    TruPatriot
    Lee
    Northeast Texas
    I took it to a shop that installs a lot of Rough Country lifts. They never heard of Westcott and I pointed them to the website. They charged me $500 for the install. Everything came out great with no problems.
    Ron_Pro[QUOTED] likes this.
  26. Nov 20, 2021 at 5:23 AM
    #86
    2020cementsr5
    2020cementsr5 New Member
    Those who had it done, much did you spend to get your Westcott lift installed at the shop?
  27. Nov 20, 2021 at 7:34 AM
    #87
    Ron_Pro
    Ron_Pro New Member
    California
    I called three shops and their quotes ranged from $700-$750! I ended up doing it myself with a couple of buddies. It’s a fairly straightforward and simple install with proper tools. Send me a direct message and I can give you more info on how we seated the collar without a vice or a press like they used in the video.
  28. Nov 20, 2021 at 7:45 AM
    #88
    TruPatriot
    Lee
    Northeast Texas
    $500
  29. Feb 15, 2022 at 12:12 PM
    #89
    DadduMan
    DadduMan New Member
    2021 Black Tundra TRD Pro
    What size CB did you put in the back? +2 or +3?
    I have CB+2 in the back and wanting to get westcott lift and use the block. So CB+2 plus the 1inch block (2.25" total in back). Everything I'm reading on seems this wont' be a problem? I also have a TRD rear sway bar and I think an extra 1inch shouldn't' be issue with the sway bar too.
    kingpin3919 likes this.
  30. Feb 15, 2022 at 12:13 PM
    #90
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    +3
