DD Exhaust resonator causing tip to move?
Discussion in 'Performance and Tuning' started by worktruckwhite, Oct 15, 2021.
  1. Oct 15, 2021 at 10:19 AM
    worktruckwhite
    worktruckwhite [OP] bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Hey, something I’ve been noticing recently. Dirty deeds budget system w/ resonator. I’ve got the 2 clamp on the exhaust and resonator both tight. Even so, the exhaust tip freely moves up and down to the point where it’s scratching the paint. @dirtydeeds 57C0C263-E5AE-4FFC-9F18-4A02449A930C.jpgBA1CA0E7-1B94-4AF5-BB05-86C937466A5B.jpg
    Anyone have a similar problem?
    Rica25 likes this.
  2. Oct 15, 2021 at 10:28 AM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    Try tightening the tailpipe clamp
    Rica25 likes this.
  3. Oct 15, 2021 at 11:23 AM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    I’ve got the clamp torqued beyond belief. Loctite as well.
    Rica25 likes this.
  4. Oct 15, 2021 at 11:27 AM
    biebs96
    PA
    It looks like the tailpipe was twisted at the clamp behind the muffler. Loosen, adjust and retighten.
    Rica25 and worktruckwhite[OP] like this.
  5. Oct 15, 2021 at 11:30 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Is the clamp seated properly on the tailpipe flange and muffler outlet flange? In other words, are the flanges centered in the clamp all the way around.
    I used to have a BAM and sometimes the factory clamp didn't hold the 2 together as well. I had to play with it a bit. Eventually went with this clamp recommended by @BlueBottle and it worked better with the BAM setup.
    Vibrant 1491C Stainless Steel Quick Release V-Band Clamp
    $26 Vibrant 1491C Stainless Steel Quick Release V-Band Clamp
    https://www.amazon.com/dp/B001P28WK2
  6. Oct 15, 2021 at 11:37 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The factory tailpipe clamp might be worn out. Ive noticed it seems to stretch more now that ive tightened/loosened it a lot
  7. Oct 15, 2021 at 12:14 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    The weight of the resonator may be causing the "loose" tailpipe to rotate counter-clockwise at the flange causing the end of the tailpipe to move upwards. But the issue is where the tailpipe flange meets with muffler outlet flange.
    If re-adjusting and tightening your existing clamp doesn't work, replacing the clamp should solve your problem.
  8. Oct 15, 2021 at 8:43 PM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    All of the above is correct. That clamp is only meant to be used by Toyota once. It just happens to be reusable. But for our trucks to have low end torque, you wanna use a stock tailpipe.
    get a new gasket and clamp, tighten well. If still doesn’t work I’ll make you a new system. Just send back the old one. 760-877-4234
    Rica25, 1794TX and worktruckwhite[OP] like this.
  9. Oct 16, 2021 at 7:31 AM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    Thanks guys & Keith. I just went under and after looking at what y'all said, the clamp is definitely stretched. The bolt runs out of threads before the clamp gets really tight. I've been torquing the bolt down but it doesn't actually do anything. Just ordered that clamp posted above.
    Rica25 and Hbjeff like this.
  10. Oct 16, 2021 at 7:39 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Not waiting on someone to ask, and putting yourself out there to make things right, is rare. Good on you, sir.
  11. Oct 16, 2021 at 8:31 AM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    Keith is one of the greatest people I’ve ever purchased something from. His post shows that, but also during the whole purchasing process and walking me through every option. Everyone hyped up BAM and it’s all true.
