5k oil change?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by ersg6, Sep 27, 2021.
  1. Sep 29, 2021 at 12:27 PM
    EN2TUNDRA
    EN2TUNDRA NOT SO New Member!
    North TX
    2021 Tundra TRD PRO Lunar Rock
    Also with the options to work remote due to the recent situation, I just did my first dealer oil change as I hit 3k miles in 7 months. Before all this, I usually hit close to 40k miles per year.
  2. Sep 29, 2021 at 3:16 PM
    glowblue
    glowblue From time to time
    VA
    I change my oil every 10,000 seconds based on the engine hour meter.
  3. Oct 4, 2021 at 8:52 AM
    DrunkytheMonkey
    DrunkytheMonkey New Member
    RJ
    Jacksonville, FL
    2021 TRD Pro CM in Lunar Rock
    My mother has a 2015 Subaru Outback with 4,875 miles on it. She is on her 7th oil change since the book says 12 months or 5,000 miles. Somebody is gonna get the nicest decade old Subaru when she stops driving!!
  4. Oct 4, 2021 at 4:17 PM
    vbb
    vbb New Member
    2020 MGM Tundra TRD Pro Crewmax
    She's clocking in at about 800 miles per year. If I drove that infrequently, I might push the interval back just a tad, especially out of warranty. But I drive about 7000-8000 miles per year, give or take a few, so changing once per year doesn't seem to be quite as excessive.
  5. Oct 14, 2021 at 1:40 PM
    Quattroa4m
    Quattroa4m New Member
    Then you wouldn't want to hear about the BMW my mechanic is putting an engine in @75K miles following BMW's prescribed extended change intervals. Turbo 4 banger with wiped camshafts and high oil consumption. This isn't his first one and it won't be his last. And oh, by the way, the turbo is getting replaced as well. It seems that they really don't like extended oil change intervals either.
    Audi, VW, BMW, etc. have all seen early engine failures attributable to extended oil changes. Some have to do with driving style and habits, while the majority can't be attributed to anything but extended oil changes.
    It's puzzling as to why someone would be willing to risk shortening the engine life of a very expensive vehicle over a very inexpensive oil change.
  6. Oct 14, 2021 at 1:50 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    You should take your logic over to the four stroke dirt bike forums. They swear up and down that you don't need expensive and that changing it often is a waste of money. People will do what they like but changing the oil does not lead to engine failure.
  7. Oct 14, 2021 at 2:02 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I get the extended performance high mileage mobile one supposedly good for 20K miles yet I can't make myself go past 3K in a turbo car i have, 5K in the my others, uggg - the oil looks clear and clean enough to use on the lawn mowers....
  8. Oct 14, 2021 at 2:52 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I'm glad I sold my BMW. Don't think I'll ever go back to German cars ever again. Too many of the same issues keep popping up all across the lineup and not one has ever been a Unicorn and not have issues.
  9. Oct 14, 2021 at 4:13 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    5k oil change?
    No.
    Saltyhero13 likes this.
  10. Oct 14, 2021 at 4:38 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    My Truck has 270k on it and that’s with 10-12k service interval at dealer using 0-20 bulk oil
    Also. this is a ffv truck
    wexttxco likes this.
  11. Oct 14, 2021 at 5:24 PM
    Blueknights75
    Ron
    Clayton, NC
  12. Oct 14, 2021 at 6:19 PM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    I've known several people who put ridiculous mileage on vehicles with extended oil changes. A friend put 270,000+ on a 2000 Tundra changing it every 20,000. Virtually all his miles were highway, though. He lives way out in the sticks so a trip to work and home is 40 miles each way. Everywhere else he goes is several miles too, so the truck had an easy life. The truck looked and drove just fine when he traded it in on his new Tundra. I personally bought a '97 Cavalier for a commuter car with 132,000 on it. I changed it every 12,000, and it was still fine when I sold it at 241,000. I put 111,000 miles on a Honda Goldwing changing it every 12,000 and never had a bit of trouble out of the engine. Valve checks were at 32,000, but I never had to adjust one. They just didn't seem to wear.
    But I put a lot of easy freeway miles on all of them. The Tundra I recently bought will spend 80% (or more) of it's miles hooked to a 6000-pound trailer. I'll probably change it every 5000.
  13. Oct 14, 2021 at 6:52 PM
    t4r2tundra
    t4r2tundra New Member
    2019 Platinum 4x4 - Smoked Mesquite
    See sig for mods...
    I do 7500 mile changes because I commute 8-11 minute 3 mile trips to work daily (pretty much 80% city miles on this truck). Unfortunately and fortunately my work is close to home but it's hard on the truck since it doesn't truly warm up. I only have 13k miles in 2.5 years. If I lived further then I would likely do 10K mile changes.
    This is all coming from someone who used to do 3k mile changes in the 90's and believed firmly in it.
  14. Oct 14, 2021 at 7:41 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    all euro cars are engineer to fall apart in 5 year.
    Canebrake and Katblackdiesel like this.
  15. Oct 15, 2021 at 6:42 AM
    Quattroa4m
    Oil change intervals are based on a mythical mixed mode of driving.
    a.)Someone who drives 4 miles to work 5 days a week is stressing the oil differently than
    b.)Someone who drives 30 miles to work 5 days a week than
    c.)Someone who tows
    Even Toyota has "severe service" recommendations, that most folks seem to conveniently forget about.
    Only the person who drives 30 miles to work 5 days a week is the one that most likely qualified for normal 10,000 mile oil changes. The other two scenarios would qualify for severe service or 5,000 mile changes.
    Would Toyota cover an oil related engine failure if you could prove you did 10,000 mile oils changes? It all depends if Toyota felt that the overall engine condition was consistent with "normal" operation. They most likely would be generous, but heavy varnish, sludging, camshaft wear, etc. might raise a few questions.
    As for the four stroke dirt bike forums, talk is cheap until you lose an engine on your own nickel or a warranty claim is denied. All over a cheap oil change??
    In nearly 50 years of dealing with every type of motorcycle imaginable, I've known no one who has lost an engine as a result of frequent oil changes. Dirt bike riders around here typically change oil and filter after a handful of hard weekends. Its just cheap insurance.
  16. Oct 15, 2021 at 7:46 AM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    55 years motorcycling here. I've motocrossed, flat tracked a little, hare and hounds, road raced, and Lord only knows how many miles on the highways between Nova Scotia and the southernmost borders of the US. Given the choice, I'll change more often than I think desirable because less often just isn't in my wheelhouse.
    I've also been taking part in various email and Internet forums since shortly after they began. I've taken part in countless threads such as this with varying opinions on product brands and frequency of service. My most noticeable takeaway is that nobody is ever wrong in their own minds. I like to say that everyone's right and everyone else is wrong. :) I've seen one post in 20+ years where the guy said his personal choice had turned out wrong and he damaged an engine -- exactly one. And without going into details, even that one post was highly questionable as proof of anything.
    We won't settle anything here, but others' opinions are interesting.
    Like t4r2tundra a few posts above I also came from the time where you changed your oil every 3000 miles. But times change.
    Do what makes you happy :)
    crewmaxlmt likes this.
  17. Oct 27, 2021 at 1:28 PM
    Gman8P0W1
    Gman8P0W1 New Member
    Utah
    21 Lunar Pro
    ADD Venom w/Rigid 30” AT Overland Summit KMC: 315/70/17 KO2
    Toyota care is a joke. They do the bare minimum. It’s all a marketing tool
  18. Nov 4, 2021 at 5:46 PM
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    Funny that as soon as all the dealers started having to cover the bill for maintenance packages to stay competitive, oil change intervals went to 10k miles. On a brand new engine I change the oil 3 times before it hits 6k miles. Every time there’s large metal flakes in the oil filter cartridge cap from the new engine breaking in. They diminish over time with every oil change, but there’s no way I’m leaving those circulating for 10k miles. On a brand new engine I change at 500, 1500, 3500, 6500, 10k and then I do 5k intervals from then on. Oil is the lifeblood of your expensive vehicle and it’s cheap to change it.
    Pig Rig and RusPro21 like this.
  19. Nov 4, 2021 at 5:51 PM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    I change my oil once a year, around 3000 miles for me, with Amsoil signature and eom filter. I sleep better at night knowing the bolts are to torque.
    If I relied on the dealer, 5k mile or 1 year whichever came first intervals would be the minimum.
  20. Nov 19, 2021 at 12:39 PM
    #50
    eagleguy
    eagleguy New Member
    Just came from the dealer at 4700 miles. No oil change and they did not even rotate the tires!
  21. Nov 19, 2021 at 12:44 PM
    #51
    PKFan
    2018 Inferno! DC SR5 4x4
    Just curious -- why did you go?
  22. Nov 19, 2021 at 1:19 PM
    #52
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Did you ask them to?
  23. Nov 19, 2021 at 1:35 PM
    #53
    Redline870
    Ian
    Central NY
    What did they even do then? 5k is supposed to be a tire rotation per Toyota cares maintenance schedule.
  24. Nov 19, 2021 at 1:53 PM
    #54
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5
    ATF Cooler
    According to the Toyota maintenance schedule on the app, this is done 0 - 5000 miles.
    5000 miles.
    Rotate tires
    inspect/adjust all fluids
    Check installation of driver-side floor mat
    Visual inspection of brake lines/drums and pads/discs
    Inspect wiper blades
    Replace engine oil and filter
    Torque propeller shaft bolt
    Torque nuts & bolts on body and chassis
    Inspect ball joints and dust covers
    Inspect drive shaft boots
    Inspect steering linkage and boots
    Inspect engine air filter
  25. Nov 19, 2021 at 2:06 PM
    #55
    Redline870
    Ian
    Central NY
    No shit, I thought the first oil change was 10k, even though I do four of them by the first 10k miles.
  26. Nov 19, 2021 at 2:14 PM
    #56
    OHwendTrd
    Josh
    21 SR5
    ATF Cooler
    Should've quoted the OP's question, that's what I was answering.
  27. Nov 19, 2021 at 2:19 PM
    #57
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    We all could just follow the owner's manual...and the dealer should support that in OP's case.
  28. Nov 19, 2021 at 4:10 PM
    #58
    OHwendTrd
    Josh
    21 SR5
    ATF Cooler
    agreed.
