Show your Tonneau cover
Discussion in 'Tonneau Covers, Caps and Shells' started by G-manCO, Nov 13, 2017.
  1. Aug 31, 2021 at 8:17 PM
    #361
    Jailer6
    Jailer6 New Member
    Washington
    2018 Midnight black 1794
    23557D44-3495-4EDF-8B92-84D00BB19FFA.jpg Added a Peragon bed cover. Still need some fine tuning, but love the look.
    ColoradoTJ and Tamutundra like this.
  2. Sep 13, 2021 at 3:34 PM
    #362
    TRDFett
    TRDFett New Member
    PA
    21 Tundra Limited
    TruXedo LoPro
    Tamutundra likes this.
  3. Sep 23, 2021 at 8:52 PM
    #363
    usfdrohead
    usfdrohead New Member
    About to order this one. Had their tri fold on my raptor, became a real pain to fold up. Love the idea of this one just rolling.
  4. Sep 24, 2021 at 7:25 AM
    #364
    cygan1008
    cygan1008 New Member
    “RIP” 2013 Tundra TRD Rock Warrior, 2018 TRD SPORT CM 4x4 SUPER WHITE Eibach Pro 2.0 275/65/20 Recon Grapplers
    My brother has their tri fold on his truck and now wishes he had known about this one. I’m completely satisfied with it for what I need.
  5. Oct 11, 2021 at 7:43 PM
    #365
    BhamDadTundra
    BhamDadTundra New Member
    2021 MGM Tundra CM SR5
    Did you by chance shim yours per the diagram? I just got a 21 tundra and the X4s and sat a rail on the bed tonight and it looked almost perfectly flush and straight. But was wondering if these instructions were outdated (even though the X4s was released like a year ago) since the Toyota section doesn’t have anything that notes “-current”
  6. Oct 12, 2021 at 12:13 AM
    #366
    cygan1008
    No, I did not need to because it all lined up perfectly for me.
  7. Oct 12, 2021 at 3:08 AM
    #367
    BhamDadTundra
    thanks! I think I’m gonna give it a go without shimming and see how it lines up.
  8. Oct 12, 2021 at 5:58 PM
    #368
    BhamDadTundra
    Got mine installed! Not too bad. I think it’s lined up perfectly, but does yours hang off the back this much on the cab side? It’s perfect at the tailgate. I’m certain it’s as far forward as it goes after playing with it a bit. But was surprised at all the over hang.
  9. Nov 11, 2021 at 7:48 PM
    #369
    UnicornHunter
    UnicornHunter New Member
    Brandon
    Smyrna, GA
    2021 Lunar Rock Tundra TRD Pro CM
  10. Nov 29, 2021 at 11:12 AM
    #370
    TOY4TKK
    TOY4TKK New Member
    2016, Silver Tundra TRD OFF ROAD
    Installed quick release fork mount bike.
  11. Dec 9, 2021 at 7:53 AM
    #371
    Koba
    Koba New Member
    2017 Black Tundra CM SR5
    Is it possible to add racks to it? Are you going to drill into the cover, or is there factory option? (I didn't see any rack options on their website)
    I am considering the same cover, and if it's possible to add racks, I will get it asap.
    Thank you!
    cardinal[QUOTED] likes this.
  12. Dec 9, 2021 at 8:18 AM
    #372
    mjunior
    mjunior New Member
    mike
    2019 Crewmax Platinum XP
    Yes you can. Here's a picture of my 2013 with the Undercover LUX. You can see I added Yakima rails to the cover. I would recommend mounting them as close to the bed rails as possible so you have that support under them.
    cardinal likes this.
  13. Dec 10, 2021 at 1:50 PM
    #373
    cardinal
    cardinal New Member
    Central Ohio
    2021 SSM CM LTD TRD4x4
    There doesn't seem to be any manufacturer-provided option. However, almost all of the major manufacturers (and I'll probably go with Rhino Rack) have track systems designed precisely for these types of applications. So, you'd have to drill into it, but they make them for truck camper shells, fiberglass camper tops, etc... so it's made for this. These can hold up to 500# evenly distributed, so it's exactly what I'd need. I just haven't pulled the trigger yet since I can still carry everything I need without one, for now...
  14. Dec 10, 2021 at 5:51 PM
    #374
    cardinal
    cardinal New Member
    Central Ohio
    Thanks for this - it confirms exactly what I want to do to mine. And great suggestion about mounting over the bed rails - not sure why I didn't think of that, but it probably would've lined up that way anyway with the decorative ridges (or aerodynamics whatever they're for).
  15. Jan 26, 2022 at 10:25 AM
    #375
    TundraFL
    TundraFL New Member
    2020 Calvary Blue Tundra SR5
    The BakFlip Revolver X4S just arrived, and I just installed it. Super easy installation, and it works really well. Very low profile, and very secure.
    BhamDadTundra, cran2 and cardinal like this.
  16. Feb 9, 2022 at 9:11 AM
    #376
    odin1701
    odin1701 New Member
    2021 Tundra LTD TRD OR MGM
    Instead, put a bead of black RTV sealant under the seal.
  17. Feb 9, 2022 at 9:28 AM
    #377
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I'll have to take a picture but i just bought a 2021 CM Pro that came with a weathertech aluminum trifold cover. Didn't know they made one. Seems okay. Nice feature is you can remove it from the rails easily without tools. I also use a softopper for vacations so i think i can modify the softopper clamps so i can quickly change between the two
  18. Feb 28, 2022 at 1:26 PM
    Jaba’sDad
    Jaba’sDad New Member
    Two votes for Diamondback. I’ve had two SEs, one for several years on a ‘14 F150, and one on my Tundra now. Zero water leaks, tough as nails, extremely secure and very versatile. I tie all kinds of stuff to the top. I can still haul a refrigerator around. I walk on it all the time. I beat the crap out of it, run it through the car wash and it looks brand new. And their customer service is second to none. This is truly one of the best companies I’ve ever dealt with and I recommend them to anyone looking for a cover.
  19. Mar 9, 2022 at 2:41 PM
    #379
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
    I installed the BAKflip MX4 tonneau cover this past weekend. It was quite easy to install.
    TLH13, cardinal, WVI and 1 other person like this.
  20. Mar 9, 2022 at 5:49 PM
    #380
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    This is what’s on my 02. Been on since first owner. Still going strong. Glad I didn’t have to drop the coin on it though lol
    Areith762[QUOTED] likes this.
  21. Mar 9, 2022 at 5:54 PM
    #381
    odin1701
    odin1701 New Member
    These are the best IMO.
  22. Mar 9, 2022 at 6:04 PM
    #382
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I would agree with that statement prior to them being bought out several years ago. Many family members and I have used them for many years with great results. The one I purchased in 2020 is pure garbage and is falling apart. It leaks like crazy from places it shouldn’t from the day I bought it. Poor craftsmanship and basically I was told to go pound dirt. Their customer service was horrendous and I feel burned by a company I was once loyal to and would always recommend.
  23. Mar 9, 2022 at 6:07 PM
    #383
    odin1701
    odin1701 New Member
    Huh... didn't know they were bought out. I got a new one recently and it seemed just as good as the one I got many years ago.
    Oey12[QUOTED] likes this.
  24. Mar 9, 2022 at 6:20 PM
    #384
    Oey12
    Oey12 New Member
    Joey
    New York
    Unfortunately I will have to purchase another cover in a few years but I am trying to wait as long as possible before dropping another 1k. My cousin purchased the same cover for his F150 and didn’t have the issues I did. I just wish they helped me…
    Sorry brother, nothing against you.
  25. Mar 24, 2022 at 5:02 PM
    #385
    Wiesy442
    Wiesy442 New Member
    2016 Tundra SR5 Double Cab Red
    Auto headlight mod, seat covers, drop down rear seats mod, 2018+ LED Headlights, USA flag Tundra tailgate decal (many compliments on red Tundra), Alpine ILX-F509, front Focals, JL 10TW1-4s, Waxoyl undercoat, StartX remote start.
    TundraFL likes this.
  26. Mar 24, 2022 at 5:48 PM
    #386
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
  27. Mar 31, 2022 at 6:14 AM
    #387
    TundraFL
    TundraFL New Member
    It keeps it out pretty well! You'll get a little bit in there, but overall it stays pretty darn dry!
    Wiesy442[QUOTED] likes this.
  28. May 19, 2022 at 11:39 AM
    #388
    LR23
    LR23 New Member
    NC
    2021 TRD Pro
    I feel like I'm beating a dead horse here, but I can't seem to find a definitive answer. Do you have the factory bed rails/cleats and if so, do you have to lower them with a bracket to install the X4S?
    I really like this cover, but can't seem to find that answer.
    Thanks!
    TundraFL[QUOTED] likes this.
  29. May 19, 2022 at 11:48 AM
    #389
    justcuz
    justcuz 2.5 Gen Member
    Leer HF 650 M
  30. May 19, 2022 at 11:55 AM
    #390
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
