DIY Trd Pro Rigid fog lights!
Discussion in 'Lighting' started by Neshra54, Nov 7, 2018.
  1. May 3, 2020 at 9:25 PM
    #151
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Cool. Looks awesome. Thanks a bunch.
  2. Jun 4, 2020 at 6:56 AM
    #152
    Heloravy
    Heloravy 2018 TRD Sport
    Québec, QC
    2018 MGM Tundra TRD Sport
    I would like to thank everybody that contributed to this post!
    Fog lights are now installed and I'm very happy! Much brighter than the stock ones!
    Thanks again!
  3. Jun 18, 2020 at 10:07 AM
    #153
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    I’m Finally doing this install after having the parts for months. Is there a little gap around the housing and the light? Like 1/8 of an inch? I thought it was going to be a snug fit?
    EN2TUNDRA likes this.
  4. Oct 18, 2020 at 7:41 AM
    #154
    sbrannon02
    sbrannon02 New Member
    scottie
    2018 Cement Limited Tundra
    Where did you get the brackets?
  5. Oct 20, 2020 at 9:21 PM
    #155
    GSD
    GSD New Member
    Seattle, WA
    2019 Platinum Crewmax
    x2. Looking for some solid/thick brackets.
  6. Oct 22, 2020 at 5:10 AM
    #156
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    I have lights and bezels if interested
  7. Nov 19, 2020 at 4:14 PM
    #157
    jebber
    jebber New Member
    Jeff
    SOLD
    I have these led rigid fog lights, bezels, brackets, and wiring harnesses for this setup that I looking to sell. I was all set to install and things changed and I need to order a bumper with deer protection and cant use them. PM if interested.
  8. Jan 25, 2021 at 8:03 PM
    #158
    SoCalRandy
    SoCalRandy New Member
    Randy
    San Diego, California
    2020 MGM Limited Crewmax 4x4
    Has anyone found a bracket that works with the Rigid SAE fog lights yet?
  9. Jan 25, 2021 at 8:32 PM
    #159
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I bet if the light was removed, cover installed - the light would fit back into place. Just a guess based off the side clearance I see on pictures posted
  10. Oct 11, 2021 at 10:20 AM
    #160
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You need to pry those clips very carefully to release them and don't force them.
    Pry them as pictured and slowly pull the liner out.
    63teqgkc_zpsiuulkvy3_4560290e6188c0c16c7645ea1fc1b940b2a710d9.jpg w1bin1u5_zpsbea9ponj_4adbcb7ceeae5a41a496ac45e7aad4935d472ab8.jpg
    6C99E975-21F4-4133-BA83-2DC2FB5082ED_zps_5d499fa6bf841196c11ab595de16ba2426e4a7d2.jpg
    The liner and the fender clip are 2 different parts.
    You can see at the top and bottom of the clip how much plastic goes into that hole and that is what prevents you from pulling it out.
    Work it gently, otherwise you'll end up needing to buy 2 of the fender clips, like many of us have..:eek:
    53883-0C040 - Fender Liner Seal (Left, Front) - 2014-2020 Toyota Tundra | Sparks Parts
    53882-0C050 - Fender Liner Seal (Right, Front) - 2014-2020 Toyota Tundra | Sparks Parts
    If you do need to buy them, check your part numbers.
    There are 2 different parts number for truck with or without the off road package.
    Part # 16 in this diagram.
    Fender & Components for 2014 Toyota Tundra | Sparks Parts
    Savmikey47 likes this.
  11. Oct 11, 2021 at 11:32 AM
    #161
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    VERY helpful, thank you.
    I just pulled one side and after wriggling and looking at things from the inside and up past the tow hook I tried another method. Reach in from behind and gently hold/lift the little tabs(I worked from top to bottom and there are three, two are marked with red arrows) while carefully pulling the panel sideways, towards the inboard on the vehicle and down. It literally fell out of position while leaving that fender liner seal in position.
    Here's a couple of pics that might help others and explain how I removed them.
    1lowlife[QUOTED] likes this.
  12. Oct 11, 2021 at 4:53 PM
    #162
    1lowlife
    DADA
    2014 MGM DC SR5
    Jeeezus Christ your fender well is clean...:eek2:
  13. Oct 11, 2021 at 8:08 PM
    #163
    BCTRD
    BCTRD New Member
    B.C.
    Lol, the trucks less than a month old and last couple weeks were spent doing a fluid film/cosmoline treatment followed by Cquartz UK ceramic coating anywhere it would stick before she hits the dirt. Basically went over every nut and bolt I could reach with rust preventative as they pour the frigging brine on roads around here at the slightest hint of frost.
  14. Jan 8, 2024 at 6:39 AM
    #164
    BR33ZY
    BR33ZY XP Rockstar ha
    Hate to bump an old thread but Specialty Performance has the clear lights for 50% off right now, I'm gathering the parts to do the DIY and wanted to share.
    bulldog93, iHacker and Patch999 like this.
  15. Jan 8, 2024 at 7:20 AM
    #165
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    Thanks. Got a extra $8.99 off with "Welcome5" code
    BR33ZY[QUOTED] likes this.
  16. Jan 8, 2024 at 7:28 AM
    #166
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Great deal!!
    Here is the link to make it easier for those interested
    Rigid SAE D pods
    https://specialtyperformanceparts.com/products/rigid-clear-sae-pair-d-series
    Harness to make them work with factory wiring
    https://specialtyperformanceparts.c...onnectors-pair-spv-harness-system-see-details
  17. Jan 8, 2024 at 9:06 AM
    #167
    BR33ZY
    Looks like they got wise and raised the price slightly. Probably due to popularity. I got in at $149 which was easy to justify.
  18. Jan 9, 2024 at 7:00 AM
    #168
    CountryNut
    CountryNut New Member
    Nelson
    Coeburn, VA
    2017 Tundra CM SR5 TRD Off Road 4x4 (MGM)
    Retrax OneMx cover, 12voltSolutions Remote Start, Driver's side grab handle
    I am in the mood to upgrade my fogs. I have about decided to go with Diode Dynamics Pro Ambers. Does anyone have any experience on how the DD stack up against these Rigid SAE D pods?
  19. Jan 9, 2024 at 3:33 PM
    #169
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    CountryNut[QUOTED] and bulldog93 like this.
  20. Feb 28, 2024 at 2:19 PM
    #170
    MTG-MAN
    MTG-MAN New Member
    Rick
    2019 TRD Pro
    Is anyone selling these brackets anymore? I need a set ASAP!!
  21. Feb 28, 2024 at 2:21 PM
    #171
    MTG-MAN
    MTG-MAN New Member
    Rick
    2019 TRD Pro
    Where do I get those brackets? Which ones are you talking about?
