Trouble installing RB-20s
Discussion in '2.5 Gen Tundras (2014-2021)' started by HangarRash, Oct 7, 2021.
  1. Oct 7, 2021 at 1:04 PM
    HangarRash
    HangarRash [OP] New Member
    Rick
    2019 Tundra SR5 4WD Crew Max
    I’m trying to install a set of Go Rhino RB-20 running boards on my 2109 Tundra Crew Max.
    I’m working on the right side at the moment. I removed the 7 existing galvanized bolts and flat washers. I have loosely installed the four brackets using the 8 supplied black bolts and flat washers. When I set the running board in place the ends of the front and rear brackets stick out below the tapered ends of the running board.
    Is this right?
  2. Oct 7, 2021 at 1:07 PM
    HangarRash
    Rick
    BTW - the two pictures were taken with the running board basically centered between the front of the front door and the rear of the rear door.
  3. Oct 7, 2021 at 1:18 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    That does not look right… I have these running boards on my DC…. Been a few years since I installed them, so off the top of my head I can’t say what is wrong… at work right now so can’t look at mine either… sorry for not being able to help right out of the gate. Hope someone else provides an answer for you soon. Good luck!
  4. Oct 7, 2021 at 1:24 PM
    Chip_Tundra
    Chip_Tundra New Member
    You have them pushed in all the way. The running boards can be adjusted and pulled out more. Once you have it the way you want, tighten the bolts under the boards.
    HangarRash[OP] likes this.
  5. Oct 7, 2021 at 1:25 PM
    HangarRash
    Rick
    I just got it figured out. I had the running boards in too close to the truck and the brackets were still real loose. I got it now so it looks a lot better.
    Chip_Tundra likes this.
  6. Oct 7, 2021 at 1:27 PM
    HangarRash
    Rick
    Yep, that’s what I had just figured out and completed. Thanks
  7. Oct 7, 2021 at 1:29 PM
    HangarRash
    Rick
    Just just to confirm. When I’m done with the install am I supposed to have the 14 original galvanized bolts and flat washers left over?
  8. Oct 7, 2021 at 1:48 PM
    Chip_Tundra
    That's what I had. I also used the bolts from the kit because they're longer and matched the color of the running boards.
  9. Oct 7, 2021 at 2:00 PM
    HangarRash
    Rick
    Just finished. Took two hours to figure out, do, and redo the first side. Took 25 minutes to install the other side. Typical.
  10. Oct 7, 2021 at 2:26 PM
    Tundra182
    Tundra182 New Member
    MA
    2021 LR TRD Pro
    2008 Limited Tundra Crew Max 2007 Sequoia SR5 2006 Tundra SR5 Double Cab 2004 Tacoma SR5 Extended Cab
    If it makes you feel better - I did the exact same thing last weekend. Even called my distributor to complain that they gave me DC boards. LOL. Ah well.
