Engine Ticking Noise
Discussion in '2nd Gen Tundras (2007-2013)' started by kenomouth64, May 5, 2017.
  1. May 5, 2017 at 6:59 PM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I know that these engines are normally quite loud upon initial startup when it is cold (and sometimes when it is warm). However the noise I am getting when it is cold, seems to be more pronounced than what others are getting.
    This is a 2007 Toyota Tundra 5.7l with 142,000 Miles
    This noise only happens when it is cold outside BUT it will happen when the motor is up to operating temperature as well as when it is cold. It usually has to be below 40° F for the noise to happen. Also the noise is sporadic and will only happen randomly. I have no heard the noise in a while as it is warm here now, but after searching through Youtube, I found a Tundra noise video with the SAME NOISE.
    The video is an exact replica of the noise I get.
    https://www.youtube.com/watch?v=iHf8NAaPGo8
    and this one too
    https://www.youtube.com/watch?v=XQK9HRAZJvE
    What do you think is it normal?
  2. May 5, 2017 at 7:26 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I'm assuming you checked your oil level, and that you are using the correct viscosity. The "normal" noise is more like a diesel rattle than a tick. If you are hearing a rhythmic ticking sound that doesn't go away on warm up. It might be cause for mild concern.
  3. May 8, 2017 at 10:06 AM
    kenomouth64
    Tetrus
    Oil level is good and I use Mobile1 5w-20 weight oil, regardless of the season or temperature.
    Thinking about 5w-30 as 20w is not very viscous at all.
    What does anyone else think?
  4. May 8, 2017 at 11:06 AM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    One of two things off top of my head..
    One lifter sticking somewhat. But my money is on an number 2..
    Two the Teflon on the chain guides shot(wore out) and the guides need to be replaced.
    joonbug likes this.
  5. May 8, 2017 at 6:28 PM
    Stig
    Stig New Member
    Go buy genuine Toyota synthetic oil from the dealer and do an oil change. Seems these engines are sensitive to the exact type of oil. Even if you use the exact oil weight/viscosity, it can still make that ticking sound (for instance the Mobil 1 fuel economy version).
    TroubledTundra81 and J.A.T.O. like this.
  6. May 8, 2017 at 9:55 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Mobile 1 is what Toyota recommends.
    kenomouth64[OP] likes this.
  7. May 9, 2017 at 8:15 AM
    kenomouth64
    Tetrus
    That is an interesting thought, it is definitely possible, however I am wondering if the noise would be at a greater tempo, since it has so many revolutions. The noise is gone for now, but it comes back in the cold weather, so I figure that the noise would be constant, regardless of weather if it had something to do with the timing chain. However I will look into it.
    See I have heard that synthetic Toyota motor oil is nothing but Mobile1 Synthetic in a different package. I have heard about that advanced fuel economy stuff, but will not ever use it, it is just less viscous oil, which offers less resistance to the motor turning, which will grant very slightly better fuel economy. At the expense of , maybe, more wear to the motor, 20w is already pretty thin anyway. I use Mobile1 High mileage. However I will look into the motor oil thing again, as there is a lot of misinformation out there!
  8. May 9, 2017 at 9:41 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Sounds more like something is slapping. On my 2004 F150, the cam phazers were going bad and it developed a loud tick which was very common for that year. But what quieted it down was going to a heavier oil, 5w-0, I believe. The cam phazers causing the tick were higher up in the motor and the lighter weight oil was just too thin. Anyways, that was just a band aid fix, you really need to have this checked out, that is definitely not normal.
  9. May 9, 2017 at 1:15 PM
    kenomouth64
    Tetrus
    I am going to take a video of what it sounds like now in the 80° weather. It does not have such a pronounced noise as the one in the videos now, but in the colder temperatures it does.
  10. Jun 21, 2020 at 2:38 PM
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    OP, did you find a solution? The links you posted no longer work so I’m hoping you found your answer.
    Here is a video of mine.
    2013 Tundra 5.7 FFV 108k. Oil changed every 5k with 0w-20 Mobil one synthetic and OEM filters.
    I’ve owned the truck since new and I’m used to the normal valve train noise. This started on mine less than a week ago and seems to be getting worse.
    Is this video similar to your problem?
    https://youtu.be/T0hlRCSjsrg
  11. Jun 22, 2020 at 2:14 PM
    Tundra_power
    Tundra_power New Member
    Thats not normal at all. Lifter tick???
  12. Jun 22, 2020 at 3:45 PM
    bordenj
    bordenj New Member
    Fremont IN
    2008 Sequoia Limited 4x4
    As a general observation to sound issues like this, you can use your phone and a sound analyzer to locate more specifically where the sound is coming from.
    I used the free version of this app (iPhone) last week to verify the idler pulley assembly was bad and causing my engine squeel (08 Sequoia).
    You slowly move the phone in areas of the engine compartment/elsewhere and watch for spikes associated with the sound of curiosity. A selfie stick is also useful. High squeeks will be on the high end of the spectrum. Clunks will show up on the mid/low end.
    Dalandshark and J.A.T.O. like this.
  13. Aug 8, 2020 at 9:09 PM
    NR-J
    NR-J New Member
    Justin
    2015 white tundra
    Did you ever figure this out? That sounds a whole lot like mine is sounding. I think I’ve got it narrowed the front driver side area, and it’s down low somewhere.
    It comes and goes and isn’t really consistently timed.
    Geo4x4 likes this.
  14. Aug 11, 2020 at 12:53 PM
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    I replaced the Mobil 1 with Toyota brand oil from the the dealership and the problem has been gone now for over 2k. Im sticking with OEM oil from now on.
    Hilandr, Johnsonman and Geo4x4 like this.
  15. Aug 11, 2020 at 3:18 PM
    NR-J
    NR-J New Member
    Justin
    2015 white tundra
    ok, so you’re issue definitely isn’t what I hear. Mine is something external and louder than lifter noise is.
  16. Aug 12, 2020 at 9:24 AM
    Geo4x4
    Geo4x4 New Member
    2010 Rock warrior
    I have the exact same noise as @J.A.T.O. I’ll try the Toyota oil next oil change. Thank you. I’m pretty worried It’s a timing chain issue.
    TroubledTundra81 likes this.
  17. Aug 12, 2020 at 10:17 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    More phosphorus & zince to help coat/protect metal parts from each other. I especially like the mobile extended performance high mileage. see specs attached. essentially this is what toyota is having bottled up for it to use/sell.
  18. Aug 12, 2020 at 10:29 AM
    Trikerider
    Trikerider New Member
    2015 Limited CM
    Have the same problem with my Tundra intermittently in the colder months. Has been much less pronounced since switching away from the advanced fuel economy Mobil 1 and actually just switched to Pennzoil Platinum but have not had a winter with it yet. Last winter was not bad, started using a little Marvel Mystery Oil occasionally which helped clear it up. From all the research I've done I think the noise is the hydraulic timing chain tensioner not getting enough oil pressure on cold start up and letting the chain slap. Again, the MMO has seemed to help, dont know if cleaned up something inside the hydraulic tensioner or what.
  19. Aug 12, 2020 at 10:32 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    others have fixed ticking from lifters by using the correct spec, Toyota oil. I just read a thread yesterday where the person had been using mobil 1, had noise and ticking and moved back to toyota oil and the noises went away.
  20. Aug 12, 2020 at 11:32 AM
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    I see that a lot have mentioned that their problem was when it’s cold or during start up. Mine started in June (Tennessee) and would make the noise all day long while driving.
    BADTRANSAM likes this.
  21. Aug 17, 2020 at 5:55 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    i still use 0w-20 the 5w-20 is to thick for me, are VVTI and high tolerance engines need the thinner stuff. thicker oil will actually cause damage to are engines if they are healthy do to oil starvation on start up.
  22. Aug 17, 2020 at 6:05 PM
    NueveTundra
    Planet Earth
    so beside that we seem to have loud injectors , the other ticking noises are either 1.) the injectors got louder 2.) exhaust leak around the manifold 3.)sticky lifter/s and the most dreaded is 4.) piston slap
    if it doesn't sound like a tick and more of a hard tick when cold and after warming up goes nearly 100% away , maybe a slight vibration coming from the engine and a noticeable un-normal use of oil its piston slap.
    but i find it interesting that one video showed the passenger side , i'm curious how many all hear it the most pronounced on the passenger side?
  23. Aug 17, 2020 at 6:33 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    Mine was for sure on the passenger side and was pretty persistent though not constant either.
    We tracked it down to a bad alternator,replaced the alternator and silence!
    It was tough to narrow down too due to where the stupid alternator is located but once decided it has all been good.
  24. Aug 17, 2020 at 7:04 PM
    Shearboy2005
    Shearboy2005 New Member
    coming over from TW and dtill using a 2nd gen tacoma for a work truck I've gotten used to a certain level of engine tick.
  25. Aug 17, 2020 at 9:16 PM
    NueveTundra
    Planet Earth
    now that i think of it :rofl: i haven't herd mine since i replaced my alt with a 300amp H.O do to other things.
  26. Sep 24, 2020 at 1:55 PM
    BADTRANSAM
    BADTRANSAM New Member
    Josh
    2017 tundra SR5
    Service bed
    J.A.T.O my tundra is making the same noise on the passenger side did you find the problem
    Geo4x4 likes this.
  27. Sep 26, 2020 at 12:33 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    You read too much internet. The difference between the two is insignificant unless your driving in Antarctica.
    Myhobbes25 and Dalandshark like this.
  28. Oct 12, 2020 at 5:27 AM
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    Switched to OEM oil instead of Mobil 1 synthetic (the one that mentions Toyota On the bottle) and the problem hasn’t came back yet. Ticking stopped immediately. It’s been approx 5k miles now and is still quiet as new.
    My understanding is that Mobil 1 makes the OEM oil buts adds extra zinc and something else for the Toyota blend.
  29. Feb 7, 2021 at 11:53 AM
    Prc
    Prc New Member
    ‘01 Tundra/‘12 Sequoia
    01’ bilstein 5100’s with Alcan springs in the rear. ‘12 stock
    Just had this same noise on my ‘12 Sequoia w/200k miles. Definitely from the oil filler area and increases intensity when oil cap is removed. Going to try oem oil as previously mentioned by others. Hope this helps. I’m in Michigan it was 14 degrees when I first noticed.
    Any updates from you guys?
  30. Feb 11, 2021 at 12:28 PM
    Prc
    Prc New Member
    Problem solved. Used Toyota brand oil!
    TroubledTundra81 and PhotoNerd like this.
