Lomax Tonneau cover, so far all good
Discussion in 'Tonneau Covers, Caps and Shells' started by gamester5, Apr 22, 2020.
  1. Apr 27, 2021 at 12:44 PM
    #61
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    The Stance folds up against the rear window and attaches to a couple anchor points located on the roof...the original lomax only folds 2/3 of the way, but can removed without any tools!
    KatoK likes this.
  2. Apr 27, 2021 at 8:42 PM
    #62
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    I have the stance. It only comes in the bed liner finish. Looks great. Love the cover. The stance fold up exposing the entire bed (by propping up against the back window. Never comes in contact because there are support rods). As opposed the the other that folds twice and to use the entire bed you have to remove the tonneau from the bed of the truck.
  3. Apr 28, 2021 at 6:16 AM
    #63
    KatoK
    KatoK 2021 Super White 4X4 TRD Pro
    Jeff
    N. Texas
    thanks for the feedback. I called Agri-cover yesterday for some more info and ended up ordering one. I definitely like the bed liner finish over the others. I have the bed rails so will check back if I have any issues.
  4. May 2, 2021 at 9:44 AM
    #64
    Gomting_Jaeger
    Gomting_Jaeger New Member
    2021 Tundra 1794 CrewMax Smoke Mesquite 4X4
    Painfully Stock
    I have the bed liner looking finish on mine. Make sure they send you the correct pieces for your truck. I received side rail for Ram 1500 initially and took two diff phone calls to Agri-Cover to get the right part. Also, if you have the oem bed divider, it will work with it but there are couple of tricks to it.
  5. May 4, 2021 at 1:22 PM
    #65
    hillbillytoyo
    hillbillytoyo Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
    Can I get a top view pic of the cab to see where you guys are mounting the brackets that hold the cover upright?
  6. May 5, 2021 at 2:40 PM
    #66
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    hillbillytoyo[QUOTED] likes this.
  7. May 7, 2021 at 2:06 PM
    #67
    hillbillytoyo
    Daniel
    WV
    Thank you sir!
  8. Jun 15, 2021 at 11:26 AM
    #68
    TipToeTyler
    TipToeTyler New Member
    These look really nice. Lot of bakflips around my area. Where is go to site to purchase?
  9. Jun 15, 2021 at 11:54 AM
    #69
    KatoK
    Jeff
    N. Texas
    Not to steal the question but, I got mine straight from the dealer -AgriCover.com Very helpful and can answer all your questions. I did have some local shops who would order AND install at no additional charge which might be worth it.
    TipToeTyler likes this.
  10. Jun 25, 2021 at 7:08 AM
    #70
    kmeindin
    kmeindin New Member
    Ken
    2021 Tundra Trail - Cement
    Lomax Cover, Adarac Rails, Yakima Bike Racks, Undercoat, 3M PP, Step
    I just got a Lomax cover installed on my 2021 tundra. Also installed tundra side rails, Adarac rails, towers, bars and Yakima bike racks. The cover, towers, rails, and bars are made by Agri-Cover. I just bought the truck and didn’t have the factory tie down cleats in the truck when they installed the system. I was going to try to put the cleats in the factory rails but it looked like there isn’t enough room above the cleat so the cover will hit the cleat. Do the factory cleats still go into the factory rails ?
  11. Jun 25, 2021 at 7:13 AM
    #71
    kmeindin
    kmeindin New Member
    Ken
    Here is a picture of the cover and racks
    jlarkin1918 and baron like this.
  12. Jun 25, 2021 at 7:18 AM
    #72
    baron
    baron New Member
    Brett
    2021 TRD Pro
    They do, but it's a tight fit. Pretty close to the tonneau, but they do clear.
  13. Jun 25, 2021 at 4:04 PM
    #73
    kmeindin
    kmeindin New Member
    Ken
    Are the cleats really that useful being so high in the box.
  14. Jun 28, 2021 at 8:52 AM
    #74
    KatoK
    Jeff
    N. Texas
    They are still functional but it’s a tight fit. This is the OEM rails and cleats. 17EC94F6-BA69-4FA2-82EB-DF6ED3E46B69.jpg
    NewImprovedRon likes this.
  15. Jun 28, 2021 at 10:19 AM
    #75
    Gomting_Jaeger
    Painfully Stock
    I figured it out. Like you said, you have to turn the connector upside down and you will have to find the exact spot to install the connector. I can take a picture of my setup later today and post it.
  16. Jun 28, 2021 at 10:33 AM
    #76
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    My BakFlip MX4 has been sheer garbage. Leaks in multiple areas, well beyond the typical corner of the bed leaks. Several pieces have broke off in less than year and the cover gets very little use.
    I can attest that BakFlips customer is nothing less than atrocious. I sent them over 30 pictures as per their request and still got nothing resolved. Multiple calls were made as well and they could care less about the customer once the cover was sold.
  17. Jun 28, 2021 at 4:36 PM
    #77
    Gomting_Jaeger
    Painfully Stock
    Here it is. Connectors upside down.
    NewImprovedRon and KatoK like this.
  18. Jun 29, 2021 at 7:33 AM
    #78
    kmeindin
    kmeindin New Member
    Ken
    I installed the tie downs on the rails. They could only slide in one way. They just fit. I had to remove the clamps and the stops at the top and reinstall but it all worked out.
    KatoK likes this.
  19. Jul 7, 2021 at 7:46 AM
    #79
    jlarkin1918
    jlarkin1918 New Member
    Jared
    Western Massachusetts
    2020 SR5 TRD Offroad Crewmax-Cement
    OEM Spray-In Liner TRD Pro Black Badges & center caps GoRhino RB20 running boards Lomax cover
    How do you like the rack with the hard cover?
    I love my Lomax and considered getting the adarac but I know the pro tall straight rack is the only one that lets you open the cover. Curious what your doing with the shorter bars? Taking them off to open the cover or just keeping the cover closed all the time?
  20. Jul 7, 2021 at 9:56 PM
    #80
    kmeindin
    kmeindin New Member
    Ken
    I use it to haul my bikes when I am towing my trailer. I can access everything I need from the tailgate. After camping season I will remove the towers, bars and bike racks. Then I can open the tonneau cover if I need to haul something taller.
    jlarkin1918 likes this.
  21. Sep 17, 2021 at 7:40 PM
    #81
    turbopomsky
    turbopomsky New Member
    2011 tundra limited
    Air bags
    When u open it all the way up
    Does the remaining bottom piece protrudes out to the front bed rail or sits flush?
  22. Sep 17, 2021 at 7:42 PM
    #82
    turbopomsky
    2011 tundra limited
    Air bags
    This piece
  23. Sep 20, 2021 at 5:44 AM
    #83
    L_S_SHOE
    L_S_SHOE New Member
    SE Louisiana
    2021 MGM TRD Pro
    Caved and finally picked up a Lomax trifold, not the stance. Installed it last night and noticed this this morning. I torqued all clamps to 25 foot pounds, as per the instructions. Both deck rails are now bent downwards slightly. Are you guys seeing this on your trucks?
    Nervous to uninstall and find that the deck rails and the box panel behind them are permanently bent.
  24. Sep 20, 2021 at 12:31 PM
    #84
    L_S_SHOE
    L_S_SHOE New Member
    SE Louisiana
    2021 MGM TRD Pro
    Agri-Cover customer support says they've never seen or noticed the deck rail roll like that. Advised taking the torque down to 20 foot pounds. Improved but not by much. Still curious what it looks like on your trucks.
  25. Apr 15, 2022 at 6:41 PM
    #85
    itsBryantP
    itsBryantP New Member
    B
    Which kit are you guys buying if you have the oem bed rails? I'm not sure if I should buy the tonneau with or without the deck rail system.
  26. Apr 15, 2022 at 7:20 PM
    #86
    kmeindin
    kmeindin New Member
    Ken
    The clamps that come with the cover fit into the OEM rail system. The clamps clamp the the lomax rails that the edge of the cover sits onto. You need the cover and system that fits the Toyota Tundra. I have rails also that fit above the sides of the box so I can bolt towers and bars on.
  27. Apr 20, 2022 at 7:05 PM
    #87
    Richie Rich
    Richie Rich New Member
    California
    07 Crewmax Limited TRDOR.
    Coilovers, wheels, 35s, Amp steps, Carplay
    Thread has great timing. Been looking at hard cover options for my bed. Normally I do camper shells but kind of want to try something different but was becoming kind of disheartened by the negative reviews that almost all folding bed covers seem to have. Well that and I don't want to lose use of the roll down back window.
