Hi I'm new to this forum..I'm from New Mexico and own a 2011 Toyota Tundra.
Discussion in 'New Member Introductions' started by Tundragirl7, Sep 19, 2021.
  1. Sep 19, 2021 at 3:27 PM
    Tundragirl7
    Tundragirl7 [OP] New Member
    Yvonne
    New Mexico
    2011 iforce toyota tunda
    Lifted 6" pro comp
    My outer tie rod I have on my truck are 90-4229 and are straight I know they changed numbers to 90-40231 which are curved, does that make a difference from the straight ones, or will it be ok to put on.
  2. Sep 19, 2021 at 3:43 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    First post needs a official welcome... Official welcome..pics welcome too.
    Gravy likes this.
  3. Sep 19, 2021 at 3:57 PM
    Welcome from NY.
    Tundragirl7[OP] and GIN•OKUMA like this.
  4. Sep 19, 2021 at 4:01 PM
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Welcome from South Carolina.
    Tundragirl7[OP] likes this.
  5. Sep 19, 2021 at 4:06 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Welcome from CO!
  6. Sep 19, 2021 at 4:07 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from WA state.
    Unfortunately, I can't answer your question, but I'm sure someone will be along that might be able to help.
    Now get some pictures of that truck posted!
    :worthless:
  7. Sep 19, 2021 at 4:20 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Welcome. :hattip:
    Do you have a 6” lift on it?
  8. Sep 19, 2021 at 4:21 PM
    Lifted 6" pro comp. :D
  9. Sep 19, 2021 at 4:23 PM
    GIN•OKUMA
    Fish
    26.57°
    :spy:
  10. Sep 19, 2021 at 4:27 PM
    GIN•OKUMA
    Fish
    26.57°
    Looks like Pro comp changed the part number from the one you have to the one you’ve listed 90-40231 that should work with what you have going on.
  11. Sep 19, 2021 at 4:29 PM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    Welcome
  12. Sep 19, 2021 at 4:39 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Welcome from SoCal
    Tundragirl7[OP] and ToyoMafia like this.
  13. Sep 19, 2021 at 4:45 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Welcome from Texas!
  14. Sep 19, 2021 at 4:48 PM
    Welcome from Colorado.
  15. Sep 19, 2021 at 5:16 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Welcome from Maryland :hattip:
    Pretty sassy avatar pic
    Can’t help with your ?? But good luck and post some truck pics
  16. Sep 19, 2021 at 9:06 PM
  17. Sep 20, 2021 at 2:47 AM
    Welcome from Ohio
  18. Sep 20, 2021 at 3:41 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  19. Sep 21, 2021 at 4:24 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  20. Sep 21, 2021 at 6:00 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  21. Sep 21, 2021 at 6:14 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    You shouldn't have a problem, it should help you out when it comes to full lock. It should clear the spring without hitting. Also, welcome from New Mexico.
  22. Sep 21, 2021 at 6:20 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Welcome from New Hampshire
  23. Dec 31, 2021 at 11:34 AM
    BabyBlackYota
    BabyBlackYota New Member
    Alex
    Longview TX
    2015 Black Tundra SR5 offroad
    AFE cold air intake, Outlaw Catback Dual Exhaust, ProRunner Fender Flares, DAPTISED 37x12.5x20’s, (soon to be 38x13.5x17) Zone 5 bracket lift kit /with pro comp spindles and outer tie rods grip pro lsd rear, Revolution 5.29 gears Deaver U748 springs Camburg shackles Fox 2.5 Coilovers 7” BDS Icon Billet adj/UCA’s
    I actually have the curved tie rod ends they definitely look like they give you a little more space between the coilover and tie rod.
    This weekend I am installing the fox 2.5 from the bds 7in kit witch are beefed up a little more so we shall see
  24. Dec 31, 2021 at 6:50 PM
    AsThe_SkyFalls
    AsThe_SkyFalls New Member
    2020 Black Tundra TRD Pro
    Welcome from NM
