SE Toyota center console wireless charger.
Discussion in '2.5 Gen Tundras (2014-2021)' started by prerunnerseth, Nov 19, 2019.
  1. Aug 20, 2021 at 2:00 PM
    #751
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    My 11 Pro Max with Otterbox fully updated charges fine. Little slow but still come out ahead with map use and streaming over Bluetooth.
  2. Sep 9, 2021 at 3:08 AM
    #752
    redrum448
    redrum448 New Member
    So it gets crazier... Since my new phone wont charge (would cycle from charging to not charging every 5seconds) I put this liner in the tray hoping I could lay the phone there and it being somewhat thick it would prevent any attempt at charging.
    Well it charges instead lol.....
    Granted it only charges on slow but its better then nothing.
    So to others with the charging error try putting something thick (er) between the phone and charger and post results.
  3. Nov 23, 2021 at 3:42 PM
    #753
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    I have to report that my iPhone 13 Pro Max is having issues with the charger. My Iphone 8 Plus worked like a champ. I've tried no case, and three other cases, it will charge for about 40 seconds then turn red. Its pretty maddening.
  4. Nov 24, 2021 at 5:57 AM
    #754
    redrum448
    Try what I did (by accident)
  5. Nov 24, 2021 at 6:34 AM
    #755
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    I don't have the charger but I do have that little silicone mats that you have. To save some grief, put a couple of glue dots (Zots) under it and it will not move when you open the console lid.
  6. Nov 24, 2021 at 7:19 AM
    #756
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    I think this is more an apple problem than Toyota problem. My belief is apple changed the QI charging components whenever they introduced the MagSafe charging on the 12. Have the same exact issue. Worked flawless before and now won’t work with my iPhone 12 Pro. I can charge my airpod pros on the arm rest no problem though lol
  7. Nov 24, 2021 at 7:21 AM
    #757
    Clemsonman14
    Do you have the link or location where you bought the insert? Would like to give this a try
  8. Nov 24, 2021 at 8:09 AM
    #758
    redrum448
    Clemsonman14[QUOTED] likes this.
  9. Nov 24, 2021 at 10:13 AM
    #759
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Anyone has issue with these on the newer samsungs (S20, S21, Z fold etc)? I've been debating to get one but seems like a waste of money if it constantly cuts off.
  10. Nov 24, 2021 at 10:54 AM
    #760
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    The wife and I have S21s and they charge fine.
  11. Nov 24, 2021 at 11:26 AM
    #761
    redrum448
    read my posts, i have a S21
  12. Nov 24, 2021 at 11:27 AM
    #762
    redrum448
    My S21 ultra does not charge unless i have that "pad" i linked
