Heavier front springs needed for HD Bumper
Discussion in '2nd Gen Tundras (2007-2013)' started by SouthWestGA, Aug 28, 2021.
  1. Aug 28, 2021 at 10:34 AM
    SouthWestGA
    SouthWestGA [OP] New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    If you guys have suggestions or see any deals on HD springs since I’m carrying more weight please let me know!!
    2007 CrewMAX 2wd
  2. Aug 28, 2021 at 10:37 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Eibach can get you setup.
  3. Aug 28, 2021 at 11:35 AM
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    Old Man Emu 613 will give you 2.5" lift.
  4. Aug 28, 2021 at 11:39 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 AC TRD
    Bassani cat-back
    Put some weight in the back. It’ll even out for a smooth ride.
  5. Aug 28, 2021 at 11:46 AM
    SouthWestGA
    Not sure I want a lift, stock height is fine with me. Lifting always causes me to have alignment issues lol
    Also I’m only 2wd
  6. Aug 28, 2021 at 12:10 PM
    audiowize
    Paul B.
    I would get some adjustable coilovers up front and heavier springs. The Bilstein 5100 and Eibach Pro lift springs with the 5100s set to the lowest setting provides 1" or so of lift with a stock front bumper. You may find that setup on the middle setting is about right for what you're doing.
  7. Aug 28, 2021 at 1:04 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    I think he means that the 613s are often used to bring front end suspension heights back up to previous after adding a heavy aftermarket bumper. But this is generally on trucks running OME or Bil 5100s that have been leveled/lifted. Since you are running stock height, probably just get an appropriate set of Eibachs/whatever as mentioned above. What set that is, couldn't tell you, but can tell you I did business once with Off Road Warehouse and the sales rep was very knowledgable on coils, ended up selling me a set of Eibachs for a custom application. Might check them out.
