I’m new 2016 tundra platinum
Discussion in 'New Member Introductions' started by peterska1, Aug 14, 2021.
  1. Aug 14, 2021 at 6:25 PM
    peterska1
    peterska1 [OP] New Member
    Kyle
    Hey guys I’m new here I bought a 2016 tundra platinum around 2 years ago now. I love it but I’d like to start doing some work on it lifts, cold air intake, bigger wheels, I’m not sure where I should start. I want to be able to pull a trailer and take it on light off road for camping and things like that. I know it can do all that as is but I’d like to get the most I can out of it so any pointers you guys can give me im all ears especially a good starting point.
  2. Aug 14, 2021 at 6:27 PM
    CallsignKodiak
    CallsignKodiak New Member
    Bear
    Iiawah
    2021 CrewMax 4x4
    Welcome from Iowa!
    toyofan87 and peterska1[OP] like this.
  3. Aug 14, 2021 at 6:29 PM
    peterska1
    Kyle
    Thank you from Maryland
    CallsignKodiak likes this.
  4. Aug 14, 2021 at 7:48 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Welcome from SoCal :worthless:
  5. Aug 14, 2021 at 7:48 PM
    Welcome from NY.
    peterska1[OP] likes this.
  6. Aug 14, 2021 at 8:24 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Welcome. The intake is a CAI, save your money.
  7. Aug 14, 2021 at 8:25 PM
    peterska1
    Kyle
    Thanks I will
  8. Aug 16, 2021 at 3:40 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Welcome from New Hampshire
  9. Aug 16, 2021 at 4:08 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  10. Aug 16, 2021 at 5:09 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  11. Aug 16, 2021 at 8:06 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! You found the right place to get answers, but you might have to look at some other forums on this site.
  12. Aug 16, 2021 at 8:19 PM
    CorpsTundra
    CorpsTundra New Member
    Michigan
    2021 Tundra CrewMax SR5-TRD OR - Cement
    Welcome from Michigan!
    2 years and no mods?! Let the fun begin!
  13. Aug 19, 2021 at 7:19 AM
  14. Aug 24, 2021 at 9:12 AM
    peterska1
    Kyle
    Any recommendations??
  15. Aug 24, 2021 at 9:16 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome.. Fast forward two years... Toytec aluma coilovers lift kit is a great start without cutting up your cross member to achieve a solid lift and clear bigger tires. Good luck and post pics..
    We likey pics here
  16. Aug 24, 2021 at 11:56 AM
    CorpsTundra
    Michigan
    I’m new to the truck and the forum myself, so my suggestions are based on what I am planning and have looked into personally.
    If you want to do a lift and get larger tires it makes the most sense to plan to do both at the same time. You said you need to tow and run into some light off roading. That is similar to my needs and my plan is to keep whatever lift I go with under 2 inches in the front with coilovers and 1 inch in the rear with an add a leaf.
    Aesthetically the possibilities are endless. I prefer color matching the body wherever possible. Some model trims make that more expensive than others. Since you don’t have the TSS system that will make it easier if you plan to change the grille insert. If you plan to upgrade bumpers then don’t bother color matching bumper end caps.
    I recently installed the Toyota bed step. Amp Research produces the step and also sells it under the Amp name. It was cheaper to buy the Toyota version, at least when I was looking for one. Some good advice that I found here and also to be true when I did the install…Just. Trim. The. Bracket. It’ll make sense if you decide to look into installing one.
    What I normally do is Google search whatever I’m looking at options for and add Tundras.com to the search wording. You’ll find plenty of threads for suggestions and instructions.
    peterska1[QUOTED][OP] likes this.
  17. Aug 27, 2021 at 3:20 PM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  18. Aug 27, 2021 at 4:51 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
