Recovery methods and tools
Discussion in 'Recovery & Gear' started by TXRailRoadBandit73, Mar 12, 2017.
  1. Apr 30, 2017 at 2:09 PM
    gosolo
    Ray
    NW Oregon
    Actually you can do quite a bit with a winch if you're also carrying several snatch blocks. I have 3, and can do offset pulls as long as there's a couple anchor points. For instance, pulling yourself forward at the same time you're pulling sideways so you won't roll down a mountainside.
  2. Jul 31, 2017 at 1:55 PM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Take a peek at today's post on Icon's IG page. There's a fantastic example of what not to do in a rollover recovery. Cringe worthy. Jeepers.
    Anyway, I carry ARB's Essentials recovery kit. There are 2 versions, Essentials and Premium, with the difference being the winch line damper and an extension strap. I'll be picking up both once I get the new bumper/winch on the truck. I also carry some extra snatch blocks. I'm also a huge fan of the stuff from Factor55. I have a Flatlink for the winch and a set of Shorty Straps.
    There's also the HiLift. There's two tricks I've learned over the years after watching someone smash their HiLift all the way through their passenger door. Start out with the base closer to the vehicle than the top. This way, as the vehicle gains height, the HiLift will naturally straighten towards vertical rather than aiming at your car. Two, open the door.
    T-Rex266 likes this.
