Bilstein 6112/5160 Settings
Discussion in 'Suspension' started by greatpennstater, Apr 7, 2017.
  1. Apr 7, 2017 at 10:51 AM
    greatpennstater
    greatpennstater [OP] New Member
    Geoffrey
    2016 Limited DC
    Hi All,
    I'm looking into purchasing and installing the 6112/5160 set up, but before I take the leap I wanted to get some clarification. I want to *nearly* level the front with the rear, but maintain a slight rake. When I go hunting or camping and have water/coolers/gear, etc. I don't want to be nose high. I'd also like to avoid shackles or shims, if possible, to keep costs down. I've read that if you put the 6112 at the top setting, the truck ends up slightly nose high, even without any load, and I definitely don't want that. If I put the 6112 at the 1.9" setting, will it maintain a slight rake, even after it settles?
    BTW, I have a 2016 Double Cab, if that makes a difference for weight distribution. I have no after market bumpers either.
    Thanks in advance!
  2. Apr 7, 2017 at 10:57 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Yup, just put them at a lower setting than top.
    Rica25, SouthBoundSteve and AnonVet like this.
  3. Apr 7, 2017 at 11:19 AM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    Mine is at the 1.9 inche setting and is dead level.
    Inquiringone, EvilOne, Rica25 and 4 others like this.
  4. Apr 7, 2017 at 11:20 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    At the 1.9 inch setting, you'll be sitting at the exact same height as a TRD Pro. I parked next to one and it was identical.
    Tundra805 and EvilOne like this.
  5. Apr 7, 2017 at 11:21 AM
    greatpennstater
    Geoffrey
    2016 Limited DC
    Wow, thanks for posting. Is your setup without any shackles or shims?
  6. Apr 7, 2017 at 11:21 AM
    greatpennstater
    Geoffrey
    2016 Limited DC
    Nice. I think I can live with that :)
  7. Apr 7, 2017 at 11:22 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    No shackles or shims.
  8. Apr 7, 2017 at 11:23 AM
    greatpennstater
    Geoffrey
    2016 Limited DC
    How do you like the ride compared to stock (TRD Off Road)?
  9. Apr 7, 2017 at 11:24 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Much better. A little firmer on road, but it is way better off road.
    geno0506 likes this.
  10. Apr 7, 2017 at 11:26 AM
    greatpennstater
    Geoffrey
    2016 Limited DC
    Good to know, thanks!
  11. Apr 24, 2017 at 2:17 PM
    judge
    judge New Member
    2017 Black Limited 4x4
    Line-x bed liner, bilstein 6112 front/ 5160 rear, Century Royal Cap, 3m crystalline tint, Weathertech rear mat (large), Yokohoma G015 AT 275/60R20
  12. Apr 24, 2017 at 2:20 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Myself and my wife both dislike the super squishy/bouncy suspension and am looking forward to the stiffness that we should get when I change the suspension.
  13. Apr 24, 2017 at 6:18 PM
    NJBBPTUNDRA
    NJBBPTUNDRA New Member
    Sal
    2016 Blazing Blue Tundra Platinum
    TRD Exhaust TRD Cold Air Intake TRD Sway Bar
    Where did you get the shocks for that price?
  14. Apr 25, 2017 at 6:36 PM
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    Warning: suspension noob question ahead -
    Do the 6112's have to be removed to be adjusted or can they be adjusted while mounted?
  15. Apr 25, 2017 at 7:10 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    They must be removed to be adjusted.
    PermaFrostTRD[QUOTED] likes this.
  16. Apr 25, 2017 at 11:30 PM
    PermaFrostTRD
    Northern NY
    I figured. Thanks!
  17. Apr 27, 2017 at 9:19 AM
    greatpennstater
    Geoffrey
    2016 Limited DC
    Awesome, thanks for sharing this info. I think my mind is pretty much made up...just need to $$$ to pull the trigger.
  18. Apr 27, 2017 at 9:20 AM
    greatpennstater
    Geoffrey
    2016 Limited DC
    That looks damn nice!
    geno0506 and SouthBoundSteve like this.
  19. Apr 27, 2017 at 9:23 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I got mine from carid but they offer a 10 percent military discount which really helped
  20. Apr 28, 2017 at 10:52 AM
    greatpennstater
    Geoffrey
    2016 Limited DC
    That'll be a fun couple of games for sure! I live in Colorado now, but my family is still back in PA. I'll have to plan a trip up there for that one.
    SouthBoundSteve likes this.
  21. Apr 28, 2017 at 5:21 PM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2015 MGM TRD 4x4 Crewmax
    Toyota spray in bed liner/ 30" LED Lightbar/ Pro Comp Pro Runner SS @ 2.5"/ Husky Xact fronts/ Weathertech rear/ NFAB steps/ 275/70R18 BFG KO2's/ LED interior from GTR lighting/ Tekonsha Prodigy Trailer brake Controller
    20170417_063425.jpgi have the 6112s on the top setting with 5160s and toytec shackles on middle setting. I know you dont want to deal with shackles but just thought i would post for reference.
    toyofan87, EvilOne, tdcate and 8 others like this.
  22. Apr 29, 2017 at 5:37 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Muley, what size tires you got?
  23. Apr 29, 2017 at 8:21 AM
    Muleycrazy13
    Buckeye, AZ
    Those are 275/70r18. They look super small at times. Getting 295s next
    PermaFrostTRD likes this.
  24. Apr 30, 2017 at 8:27 PM
    greatpennstater
    Geoffrey
    2016 Limited DC
    That looks good...I actually was looking at the adjustable shackles at Toytec. This gives me a great reference!
    I agree with Bprose...I like the stance and tire size too. Nice truck, man.
    Muleycrazy13[QUOTED] likes this.
  25. May 1, 2017 at 4:42 AM
    Muleycrazy13
    Buckeye, AZ
    Thanks ya these shacklez are set at the middle setting. It was way to ass high when i tried them on the top setting. In person those tires look real small !
  26. May 8, 2017 at 6:20 PM
    geno0506
    geno0506 New Member
    Michael
    This is my 2017 CM 4X4, 6112's at top setting, 5160's with no shackles yet but I have CB #2 standing by, I just don't want a high rake!. SCS SR8 rims and 295-70-18's Nitto Ridge Grapplers!
    18222413_10212141072940643_8597197617655431214_n.jpg 18119405_10212141071500607_6986543202950021700_n.jpg 18157187_10212141073700662_8464790192389363209_n.jpg 18157380_10212141073340653_707886775048481045_n.jpg
  27. May 8, 2017 at 7:33 PM
    geno0506
    geno0506 New Member
    Michael
    Lmao
    Snoozer and SouthBoundSteve like this.
  28. May 17, 2017 at 10:55 AM
    judge
    judge New Member
    Race Consulting Agency, but I called.
  29. May 17, 2017 at 11:42 AM
    judge
    judge New Member
    Here it is with the 6112/5160 and Yokohoma g015 AT 275/60 R 20. Almost 3" of lift all the way around. The Windex bottles are 10" high and you can see 3-4" between them and the bottom of the step.
    saadi996tt and geno0506 like this.
  30. May 17, 2017 at 7:14 PM
    geno0506
    geno0506 New Member
    Michael
    Great looking truck!
