Cell phone mount?
Discussion in 'General Tundra Discussion' started by hi_rawb, Feb 24, 2018.
  1. Apr 10, 2019 at 5:28 PM
    #151
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    Stays very secure. However if you have a large phone with a "Otter" protective case it may not open wide enough to accept it without a little persuasion.
    Ronin73[QUOTED] likes this.
  2. Apr 12, 2019 at 1:45 PM
    #152
    hnsmrob
    hnsmrob New Member
    Tampa, FL
    Maximum Effort
    Doesnt rub at all, there is a 3m adhesive strip that connects to the silver. also the mount is contoured to sit perfectly into place.
    see my previous post with pictures - #141
    proclip with the ram mount is a solid setup
  3. Apr 12, 2019 at 1:55 PM
    #153
    glowblue
    glowblue From time to time
    VA
    I just installed my Hondo Garage unholey with a RAM Xgrip set up. It’s solid and works great. Only issue for me is I have a column shifter that sometimes gets in the way if I put the truck in park.
    I’ll have to play with it to see if I can adjust it to stay clear of the shifter.
  4. Apr 12, 2019 at 7:48 PM
    #154
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    Just play with how it's set, I have the coulumn shifter as well and I was able to get mine to clear when in park.
  5. Apr 12, 2019 at 8:02 PM
    #155
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    lucky18 likes this.
  6. Apr 12, 2019 at 10:16 PM
    #156
    salmonator
    salmonator New Member
    Tigard, OR
    2019 Tundra SR5 4x4 DC
    Post 91
  7. Apr 16, 2019 at 1:20 AM
    #157
    glowblue
    VA
    Thanks - looks like that set up could block the HU screen? I was trying to avoid that. I’ve got it adjusted better to minimize the interference with the shifter. It’s a solid mount - works great.
  8. Apr 16, 2019 at 6:20 AM
    #158
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    I'm excited to see how that looks.
    Watt maker likes this.
  9. May 13, 2019 at 6:50 PM
    #159
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    This has probably been asked an answered so sorry if I missed... can you still adjust the vent with that?
  10. May 17, 2019 at 12:19 PM
    #160
    PapaGrizz
    PapaGrizz MGM CRÜE
    Derek
    Spokane Valley, WA
    2016 MGM Tundra TRD Off Road Crewmax
    Yes, you can, but only up and down, not side to side.
  11. May 17, 2019 at 12:35 PM
    #161
    ktmhauler
    ktmhauler New Member
    GA
    2019 SR5 Dbl 4wd 5.7
    I have a ram mount suction cup setup right now but the blocking of the eyeline is kind of annoying to me vs. when I used that setup in my 4Runner. The hondo garage thing looks promising so think i'll give it a shot.
    Just wanted to add for the actual holder I love these: http://www.slipgripcarmounts.com/ i use them for my motorcycle as I've seen to many of the ram mount holders cause phones to go bye bye. It's made specific to your phone and case so you can just pop it in and out really quick without having to deal with the squeezing bars or release buttons etc. Also holds at the corners and doesn't block access to buttons
  12. May 17, 2019 at 4:13 PM
    #162
    NorthWoodsTundra
    NorthWoodsTundra Hehehe, you said 'member'...hehehe
    2021 GMC 3500 SRW Gasser
    Many airlines (including mine) use the Ram mount to hold our iPads which are now used instead of paper charts. Here is an informational video on how to properly mount one to a window. Hope this helps.
    https://m.youtube.com/watch?v=ByyFYFu6q2I
  13. Jun 25, 2019 at 10:52 AM
    #163
    P-Factor
    P-Factor New Member
    NEW CupFone™ Extension makes
    your phone easier to see, and reach! $10.00
    Limited Time Offer - Save 33%
    For our customers, we are offering the extension piece for $10.00 with FREE Standard Shipping versus the regular retail price of $11.95 plus $3.00 Standard Shipping. With this limited time offer you will pay $10.00 (plus tax where applicable) with FREE Standard Ground Shipping within the 48 contiguous states.
    https://www.weathertech.com/weather...778615992241571304855065093643485914756152403
  14. Jun 26, 2019 at 9:21 AM
    #164
    TylerDurden311
    TylerDurden311 Paper Street
    2018 Tundra CM
    Screwed in and has held up well.
  15. Jun 26, 2019 at 10:27 AM
    #165
    fundra_goes_west
    Evan
    2022 SQ8
    I like that placement
  16. Jun 26, 2019 at 10:36 AM
    #166
    TylerDurden311
    2018 Tundra CM
    Nice and out of the way and faces you for changing tunes and GPS.
  17. Jul 16, 2019 at 5:27 PM
    #167
    dalejunior
    dalejunior New Member
    2018 BBP TRD Limited Crewmax
    Sorry I know this is an old thread. Have you tried or do you know if this mount can be mounted on the lower part of the vent vs the upper portion that most seem to go with?
  18. Jul 16, 2019 at 5:40 PM
    #168
    PapaGrizz
    PapaGrizz MGM CRÜE
    Derek
    Spokane Valley, WA
    It can be mounted on any section of the vent.
  19. Jul 16, 2019 at 5:58 PM
    #169
    dalejunior
    Thank you for the quick response.
  20. Jul 18, 2021 at 10:18 AM
    #170
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    This! Slim, simple, works!
    hi_rawb[OP] likes this.
