Just came home with my new (to me) 2008 Limited!
Discussion in 'New Member Introductions' started by MiRo, Apr 23, 2017.
  1. Apr 23, 2017 at 7:14 AM
    MiRo
    MiRo [OP] New Member
    2008 Tundra Limited 5.7
    None yet...
    Hello fellow truckers with unparalleled taste in brand loyalty! I've owned nothing but Toyota since getting my license 25 years ago. I just bought a 2008 Tundra Limited with 95,000 miles and this one owner truck was pampered! The perfect combo of luxury and practical utility. For those times with I cringe at the gas station, I also have a Prius for when I need simple fuel efficiency over power and it helps balance out practicality at both ends of the spectrum.
    I'm not into crazy mods and to be honest, this truck has pretty much everything I want and need. I would like to replace every single exterior light, even parking and turn signals, to the latest and greatest (and brightest) off-road LEDs. I have the bulb numbers from the owners manual and I'm not looking to replace entire headlights, just the bulbs. It doesn't mention what this model currently has installed. Can I buy LED bulbs for all the lights or do I need those conversion kits?
    Any help is appreciated!
    With thanks,
    MiRo
  2. Apr 23, 2017 at 7:17 AM
    Welcome from CO! Head over to the lighting sub-forum.
    MiRo[OP] likes this.
  3. Apr 23, 2017 at 7:28 AM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Welcome from CA!
  4. Apr 23, 2017 at 7:29 AM
    TXRailRoadBandit73 YOTAS,RAILROADER,RÖKnRÖLLN',BEER,MAX/GEMMA
    Bienvenidos de Tejas!
  5. Apr 23, 2017 at 7:33 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Welcome from TN! Congrats on the purchase!!
  6. Apr 23, 2017 at 7:58 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado!
  7. Apr 23, 2017 at 8:05 AM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Bienvenido
    Bienvenue
    Welcome
    :canada:
  8. Apr 23, 2017 at 8:21 AM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  9. Apr 23, 2017 at 8:59 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from Ca. You'll likely find people flashing their High beams at you when you replace the headlight bulbs. The stock headlights produce a lot of scatter which tends to annoy on coming traffic. Brighter bulbs will likely exacerbate the issue. This is what lead me to retrofit headlights. Best of luck whatever you decide.
    joonbug and MiRo[OP] like this.
  10. Apr 23, 2017 at 9:09 AM
    TheBeast
    TheBeast The Beach
    welcome !
    check vleds.com for all sort of lights.
  11. Apr 23, 2017 at 9:33 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Welcome. You can certainly replace your headlight bulbs with either LEDs or HIDs. There are downsides to either.
    LEDs tend not to have the "punch" on dark roads as do halogens. Signs and road markers will light up like christmas trees, but the actual ability to see non-reflective hazards will be diminished.
    HIDs are hella bright, but the scatter will drive other drivers batty, and the uneven distribution and shadows will drive YOU batty.
    Retrofits are your best option here which involves the installation of projectors which are specifically designed for HIDs.
    15whtrd and MiRo[OP] like this.
  12. Apr 23, 2017 at 9:53 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Welcom from eastern CO!
  13. Apr 23, 2017 at 10:47 AM
    TheBeast
    TheBeast The Beach
    pictures not showing for me
  14. Apr 23, 2017 at 10:58 AM
    MiRo
    None yet...
    I haven't had any of that yet. What comes standard on a 2008 Tundra Limited? Does anyone know? The headlights are "aimed" perfectly and are level. So I haven't had anyone flashing me yet. I was going to try brighter bulbs and I'm assuming they're halogen. Do I need any kind of adapter for LED? Hopefully I won't get flashed. What's involved with retrofitting?
  15. Apr 23, 2017 at 10:58 AM
    MiRo
    None yet...
    The last thing I want is any reflective signs, road markers, etc being lit up like a Christmas tree. I can't stand that. Obviously I'd rather reduce that and increase the visibility of non-reflective hazards first and in doing so, not blind oncoming traffic.
    Halogens, LEDs, HIDs, the type means nothing to me so long as I can achieve the goal of the brightest and whitest light with as much horizontal visibility and depth as possibility without blinding oncoming traffic or myself with reflections from signs and road markers. I'd obviously like to keep the costs down too so if I don't have to retro anything, that's preferred.
    I'd also like to replace the reverse/back up lights, brake lights, parking lights, turn signals, etc (basicslly every external light source) with the brightest option available (LED?)...
  16. Apr 23, 2017 at 1:03 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    TheBeast has a good suggestion for a source. I don't know anything about LED bulbs, though I've switched out a few of mine. For reverse lights I'm gonna install:
    https://www.amazon.com/Light-Flush-...5&sr=8-1-fkmr2&keywords=offroad+town+Led+pods
    I'm waiting for the bumper recall "fix" before I install 'em. While I was trying to find the above link, I saw a lot of new pod styles.
  17. Apr 23, 2017 at 4:12 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome to the forum from Las Vegas!!
  18. Apr 23, 2017 at 4:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Welcome bud
  19. Apr 23, 2017 at 6:00 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx
  20. Apr 23, 2017 at 7:07 PM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    Welcome from another 08 limited owner with 43500 miles and counting ..If you want to keep it simple and cheap . Try Sylvania silver star bulbs in hi/lo and fogs. That is what I have now. I have put them in all of my vehicles. You can always go a different route down the line.
  21. Apr 23, 2017 at 10:36 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Brighter, Whiter, cheaper. Pick any 2 :)
  22. Apr 24, 2017 at 4:23 AM
    MiRo
    None yet...
    I did check out the suggestion TheBeast gave at vleds.com and found some decent reverse and brake lights but it was iffy for turn signals and headlights. I'm going to look more though.
    I like your suggestion so I'll add those to the rear bumper as well. I'd like a second set to go up with the cargo/bed lights are. Mainly because I can manually flip the on from the switch inside the truck. I like that option for those wonderful folks who love to tailgate me with their brights on. I can flip those beauties on in their face for a little instant revenge and hope they get the message.
    Thanks for the link!
  23. Apr 24, 2017 at 4:28 AM
    MiRo
    None yet...
    Thanks for the tip. Do you know if they offer an off-road version? JC Whitney used to sell off road bulbs but I don't see any now. If not, I'll take a look at the bulbs you recommended in their brightest and whitest version. Do you have a link for the ones you installed?
    How did you manage such low miles? I thought mine was low! There were several for sale with lower miles, but now we were talking over $25,000 and for that kind of money, the truck must be perfect. I found the perfect color scheme inside and out, the 6.5' bed, and with the limited, every option under the sun.
  24. Apr 24, 2017 at 5:05 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Welcome from TN!
  25. Apr 24, 2017 at 6:22 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Negative
  26. Apr 24, 2017 at 6:43 AM
    JerseyTundra1260
    Marc
    New Jersey
    I fi
    I found it at a dealer in PA. Had 31115 miles or so when I purchased it. Paid $25000 for it. Here is a link for one of the bulbs on https://www.amazon.com/gp/aw/d/B000...=ZENZRSA5CSF5HVB7T03V&dpPl=1&dpID=81D2DcCvhiL Check Ebay as well. How it used to look and how it looks today....... Good luck
  27. Apr 24, 2017 at 6:53 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Welcome and congrats. 2008 Limited was the top dog back then, so it came with all the luxury items (Platinum was introduced in 2010).
    If you want functional improvement in illumination, halogen bulbs are difficult to beat. I have Philips CystalVision and led DRL installed. They look to be equally bright from the front. But illumination doesn't even come close. Even the LED replacement bulbs are not stellar in illumination.
    From the front:
    Illumination just with the LED.
    Illumination with CrystalVision (Low beam)
