DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Jun 4, 2021 at 4:46 PM
    #1591
    Armycop2
    Armycop2 New Member
    James
    2018 Cement TRD Crew
    6" ProComp lift, 37's on 20's
    Dirtyseven's under a ProComp 6" lift kit.
    Alaska's a challenge for thicc trucks...
  2. Jun 14, 2021 at 12:46 PM
    #1592
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    I hate/love this thread. Too many sick builds
    Mountun Goat and Zero One Actual like this.
  3. Jun 17, 2021 at 10:19 AM
    #1593
    Semperfi5th
    Semperfi5th New Member
    Bamuffler Pro comp 7 inch lift 37x12.50r18 4.88 nitro gears Amp research steps King shocks all around Icon uca Nfab bumper Rigid pods Method nv305 18x9 wheels Prinsu roof rack Baja designs 40 inch light bar Coachbuilder steering Coachbuilder rear lift shackles Boss front bumper shims
    Went from 20s to 18s on 37s..they feel so much better
  4. Jun 17, 2021 at 5:55 PM
    #1594
    68vert
    68vert New Member
    AZ
    2011 Rock Warrior
    After much hesitation, resistance was futile......
  5. Jun 21, 2021 at 9:29 AM
    #1595
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    How are you liking those tires?
  6. Jun 21, 2021 at 12:15 PM
    #1596
    TXTundra2722
    2015 Black Tundra
    I've got about 15K miles on them so far and zero issues. They are pretty quiet too. I rotate them every 5k just to make sure they are wearing evenly.
    jewsNbrews likes this.
  7. Jun 21, 2021 at 12:16 PM
    #1597
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    How well do they perform offroad? Dirt, sand, rocks?
  8. Jun 21, 2021 at 12:19 PM
    #1598
    TXTundra2722
    2015 Black Tundra
    I've only been in dirt and mud and they aren't MTs.... but work very well for an AT tire. Zero complaints so far. I have 5 of these tires and want to buy a 6th as soon as they offer another rebate or discount.
  9. Jun 21, 2021 at 12:20 PM
    #1599
    TXTundra2722
    2015 Black Tundra
    I've either been in the dirt, mud or gravel roads so far.
  10. Jun 22, 2021 at 6:44 AM
    #1600
    canadianguy
    Kevin
  11. Jun 22, 2021 at 11:14 AM
    #1601
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    I'm not, but do it if you're on the fence. Have read great things about Mickey's. I doubt you can go wrong. Visually, they look awesome too.
  12. Jun 22, 2021 at 1:50 PM
    #1602
    HuntTruck
    HuntTruck New Member
  13. Jun 26, 2021 at 8:14 PM
    #1603
    BlackSheep
    BlackSheep caffeinated member
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    held together by duct tape and baling wire
    So…I went and did something I never thought I’d do…I had 5.29s installed this month. I did it thinking they’d allow me to put 39s on next time I need new tires, but @Cruzer has had a time with his, and I’ve been reading that it’s smart to go SAS with tires that big, and I don’t know what that means, so I probably will not be going up in tire size again.
    BUT…The 5.29s make a huge difference in the experience of driving this truck. It was easily the most expensive mod I’ve done so far, but I’m really glad I did it since I never plan to go down in tire size.
  14. Jul 4, 2021 at 7:52 PM
    #1604
    Vang530
    Vang530 New Member
    Just got this installed today after waiting 6 months for my Fox 2.5 to arrive. JBA UCA, 17" Fuel wheels and 37" Maxxis Razr AT
    OwcUvxZe4PdKZ1eaqTpUIHJnaCtSw1qKBckUsBka_a63643530f7d7eab4df262e4b6521bcffc034ef7.jpgyt2-KkEKa_ru3KOvXWRJXVh_HgrU2TwuAW7InmfM_820c98fbe04546d86fcdd3e44decfff7e9cb419a.jpg
  15. Jul 6, 2021 at 7:02 PM
    #1605
    Vang530
    Vang530 New Member
    Here's my alignment settings and how close I am to my BMC. I was rubbing at already 3 degrees caster. Maxed it out to near 5 degrees positive caster and no worries now. The wheels pushed out in front and with my high clearance bumper, it was no problem. Wheels are +1 offset. Now I only rub just a tiny bit on my TRD front sway bar at hard full lock reverse, not bad at all. I think dialing it back a little to 4-4.5 degrees positive caster would be perfect to fix this, but I wanted max clearance away from the BMC. I'm calling it good for now.
    2owzcloSldfdD0oMSFxUetx3Dx2NtpWcWcA1Z0sw_4f05f4e2f6df69366208cc995f0b897012576797.jpg
    iGFPZcx41UqoSimhg1S5SbmL5y5heS_wrQpfPYoW_bee0a33078511b08b84824758ef1a8b599cc6822.jpg
    6cliAfS-ruBIrwxtPCPMKHnIwmzAkfKlazjpqdj5_be9abf6209e2b3a119dc7d6b44f0b95ff7efc0ad.jpg
  16. Jul 7, 2021 at 1:49 PM
    #1606
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    Not sure at this point.
    How’s the outline on this? I’m going to be plating it with Relentless Fab plates.
  17. Jul 7, 2021 at 1:50 PM
    #1607
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Good to go! Bevel the edges slightly and throw a fat bead down and you're set!
    Vang530 and eccracer104 like this.
  18. Jul 7, 2021 at 1:55 PM
    #1608
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    Stupid question, but I should bevel it like this: \ right? So that way the bead can sink into it? Just got a welder from HF too, so I'm going to practice a few lines on some coupons before I tack the plate and drop some lines.
    Mountun Goat and eccracer104 like this.
  19. Jul 7, 2021 at 2:04 PM
    #1609
    snow_trd
    snow_trd New Member
    IG: @snow_trd
    Bay Area, CA
    2020 Platinum
    i have read through this entire thread multiple times so that i know what i'm getting into. finally made the jump to 37's.
  20. Jul 7, 2021 at 2:05 PM
    #1610
    TheBeast
    TheBeast The Beach
    nice !
    Vang530[QUOTED] likes this.
  21. Jul 7, 2021 at 2:06 PM
    #1611
    snow_trd
    snow_trd New Member
    IG: @snow_trd
    Bay Area, CA
    2020 Platinum
    another angle. tires are 37x13.50x17 with +18 offset wheels.
  22. Jul 7, 2021 at 2:10 PM
    #1612
    TheBeast
    TheBeast The Beach
    nice rims. kmc ?
  23. Jul 7, 2021 at 2:14 PM
    #1613
    snow_trd
    snow_trd New Member
    IG: @snow_trd
    Bay Area, CA
    2020 Platinum
    yup yup. KMC KM717.
    t4r2tundra and TheBeast[QUOTED] like this.
  24. Jul 11, 2021 at 9:46 PM
    #1614
    so_juanderful
    so_juanderful New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
    9th month update with 37x125 at 0 offset, so far so good. Had to grind down the BMC on the driver side a couple times after wheeling. Now it barely kisses after a hard run. Passenger BMC never touched at all. Rear liner kisses a little at full tuck, but nothing concerning.
  25. Jul 12, 2021 at 5:37 PM
    #1615
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
  26. Jul 12, 2021 at 6:01 PM
    #1616
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Good lord that's sexy.
    @snow_trd I noticed you are not running front fender liners, are you not concern with dirt/debris going in there? would the tires go into fenders under full compression?
  27. Jul 13, 2021 at 8:23 AM
    #1617
    snow_trd
    snow_trd New Member
    IG: @snow_trd
    Bay Area, CA
    2020 Platinum
    this shot was taken in front of the shop that was going to perform my body mount chop and flatten out my pinch welds. I figured i would remove the fender liners to make it easier for him. I plan on putting the fender liners back on.
    I still have yet to go off road with this setup, so haven’t tested yet if the tires can fully tuck into the fenders without rubbing anything. hoping to get out in the next couple of weeks.
  28. Jul 13, 2021 at 8:45 AM
    #1618
    Downytide
    GTA
    makes sense, keep us posted!
    snow_trd likes this.
  29. Jul 13, 2021 at 8:46 AM
    #1619
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    What fenders are tjose
  30. Jul 17, 2021 at 5:11 PM
    #1620
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA to Austin,TX
    '19 Tundra TRD SPORT, ‘21 Trail Edition
