Tow mirrors - white light to bed switch
Discussion in '2.5 Gen Tundras (2014-2021)' started by NTXFishing, May 29, 2021.
  1. May 29, 2021 at 7:29 AM
    NTXFishing
    NTXFishing [OP] New Member
    C
    Denton, TX
    2019 Tundra SR5 4x4 Cement Grey DCMB
    Floor liner, driver side grab handle, Kenwood DMX760S w/ Maestro kit, BakFlip bed cover, Boost Auto tow mirrors.
    I hope y’all are having a good weekend. I am mid-install on my Boost tow mirrors.
    I have already run the single wire for the white rear-facing LEDs into the cab and am looking for advice on how best to hook it up to the cargo light switch. Any thoughts?
    I appreciate the help,
    - CD
  2. May 29, 2021 at 8:09 AM
    Taco-Spike
    Two Trucks
    Plug n Play Rock Light Harness with Courtesy Mode By DSIM Solutions (Now in Stock) | Tacoma World
    Something like this, but without all if the rock lights.
    I have a cargo light pig tail adaptor to illuminate other switches (below) but not sure it would be enough amp / volts to power those from the existing current draw. Also not the application for your solution as it doesn't control on / off
    Some info in the below as well -
    Plug-and-Play Switch Illumination Harnesses (Ordering temporarily closed) | Page 11 | Tacoma World
    edit: Maybe this OP could think of something. he can do a lot more than brake taps.
    Plug and Play Brake taps | Toyota Tundra Forum (tundras.com)
    Probably have to tap into a different location for the function your wanting.
    NTXFishing[OP] likes this.
  3. May 29, 2021 at 2:18 PM
    NTXFishing
    C
    Denton, TX
  4. May 29, 2021 at 2:29 PM
    NTXFishing
    C
    Denton, TX
    @Taco-Spike I think I’m looking for a simpler solution. I’m hoping to find the right wire to tap. I’ve seen some folks on the forum say pink is the wire I’m looking for, and others say brown. Do you know which wire it is? I suck with schematics too.
  5. May 29, 2021 at 2:46 PM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Hit the wiring diagram thread in my signature. I’m not where i can pull them up right this minute…if you’re looking to just grab the hot (power) heading to the cargo light so they are on whenever you have cargo lights on, then it is a specific wire out of the 3K connector (should be pink, but that’s not as guaranteed as the specific terminal number).
    I answered the same question a little while ago - connector 3K, pin 28
    https://www.tundras.com/threads/wha...d-gen-tundra-today.713/page-1924#post-2241280
  6. May 29, 2021 at 2:55 PM
    NTXFishing
    C
    Denton, TX
    Hot damn, @RainMan_PNW . I think that’s exactly what I’m looking for. Much appreciated.
    Will wait report back after the sun dips a little. I’ve had enough sunburn for the day.
    RainMan_PNW likes this.
  7. May 29, 2021 at 7:07 PM
    NTXFishing
    C
    Denton, TX
    @RainMan_PNW I’ve taken two pictures of the harnesses in the dash. It doesn’t look like my colors line up with the pin positions. I even tried to meter at the switch and (seemingly) all of the wires, but I could never hit 12v. The bed switch was on.
  8. May 29, 2021 at 9:15 PM
    RainMan_PNW
    Casey
    Clark County, WA
    OK - here’s a snip from the cargo light EWD - the wire is supposed to be pink in 2018+, and lavender/red in 2017/2016, but colors aren’t always right.
    Here’s what the connector looks like. When seeing these diagrams, the view is looking at the connector face, not the back where the wires are entering it.
    So, in your first photo, the top connector is 3K. And the circled wire is in terminal 28. That should be your power to the cargo light from the cargo light relay.
  9. May 30, 2021 at 7:31 AM
    NTXFishing
    C
    Denton, TX
    Let there be light @RainMan_PNW !
    Here’s what was throwing me off:
    1. I was looking at the plug wrong.
    2. I’m profoundly colorblind.
    ...I mean, maaaaaaaybe #2 played a factor, but who knows.
    You have made my first post on this forum a success. Thanks, dude. Toyota folks are the best.
    Sumo91 and RobertD like this.
  10. May 30, 2021 at 7:33 AM
    RainMan_PNW
    Casey
    Clark County, WA
    :hattip:
    :headbang:
    that’s why we’re here.
    RobertD likes this.
  11. May 19, 2022 at 8:47 AM
    Wjaadams
    Wjaadams New Member
    Wes
    @NTXFishing
    How did you tap into that line? Vampire?
