BODY MOUNT RELOCATION KIT FOR TUNDRA
Discussion in 'New Member Introductions' started by dvrlndr, Sep 24, 2020.
  1. Sep 27, 2020 at 5:46 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    What thickness is the steel? Also I would suggest adding a plate support plate to the frame to help support all of the flexing that the body has Offroad.BFEE4D8C-941E-43C9-8C5B-DF3E1BEAFD15.jpg
    5.7TRDProm and Stainlesst like this.
  2. Mar 25, 2021 at 10:01 AM
    Hunterx2000
    Hunterx2000 New Member
    Hunter
    2020 Tundra
    DUDE! that’s AWESOME! I’ve been looking for a body mount relocation kit for a while!
    how can I get ahold one of those kits?
  3. Mar 25, 2021 at 12:17 PM
    MurrayYvonne
    MurrayYvonne New Member
    Murray
    have to agree with you
  4. May 14, 2021 at 9:41 PM
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    What’s up with that above design.
    i’m looking into a body mount shop or relocation.
  5. May 15, 2021 at 4:45 AM
    ptat
    ptat New Member
    Look into a relocation kit. It gives a significant amount more than even the most aggressive bmc. You might as well do it right the first time.
  6. May 15, 2021 at 4:49 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I encourage anyone looking at this to watch the small front overlap crash test of the tundra. Just so you know what you potentially may be getting yourself into. Specifically note where the drivers front wheel ends up. Then ask yourself if this is going to make that issue better or worse.
    Saltyhero13 likes this.
  7. May 15, 2021 at 4:52 AM
    Aurora CO
    Yep...see post #27 too.
    ZappBrannigan likes this.
  8. May 15, 2021 at 5:11 AM
    TXTundra2722
    2015 Black Tundra
    I think the negative comments have already been made about this relocation part. Can we move on now to how after the negative (or possible negative) portion of this is considered, how much of a benefit this is for anyone that offroads? I agree, if you're a mall crawler then really don't need this, but anyone that has already "modded" there truck can benefit from this. If you're really concerned about issues with an accident then weld some support plates in there while you're already welding. Just my two cents.
    :burp:
    831Tun likes this.
  9. May 15, 2021 at 6:11 AM
    Aurora CO
    Been almost 8 months since any pics or updates with this mod. Seems that not too many folks have done it that are members here. We know what the worst case scenario could be if not done properly. The additional bracing would be a good idea and should be done.
  10. May 15, 2021 at 6:27 AM
    5150bronco
    Justin
    Bay Area, Ca.
    Yes I get it and thanks everyone. I would absolutely reinforce the body and make it stronger than stock. I did do this in my Tacoma. Overkill build everything.
    Black Wolf likes this.
  11. May 15, 2021 at 8:35 AM
    Elduder
    Elduder New Member
    Yeah a body lift on a truck that has the bumpers mounted to the frame. Not going to look good.
  12. May 15, 2021 at 8:42 AM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Seen a lot of relocating work like this without a proper plating support on the frame... and seen some damages done to the frame with it not being plated as well.
    Ltaco17[QUOTED] and Saltyhero13 like this.
  13. May 15, 2021 at 8:56 AM
    Elduder
    Elduder New Member
    Care to share some examples of the damages?
    Ive seen quite a few Tacomaworld guys do this exact mod, haven't seen any issues with it yet. Not saying it wont be a problem, I just keep hearing how it will be without any actual experience or proof of those statements.
  14. May 15, 2021 at 9:42 AM
    5.7TRDProm
    Dara
    I do not have proof of a screenshot of the damages because where I saw it from is from a few account I follow on Instagram that post it on their story and of course they only stay on for 24hours. I wouldn’t even mention or say this if I never saw it.
    but then again if people are doing this just for daily driving to clear tires and not truck it then I suppose they should not have an issue.
    I’ve been wanting to do the relocate and still plan to, just more supported with the frame plated up before the mount kit.
  15. May 16, 2021 at 7:37 AM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    The cab has more stress than you can imagine especially if you Offroad any at all. No matter how good of a welder you have they can not prevent the weld from having stress cracks eventually. I have seen it time after time and most end up redoing them and adding a plate.
    ZappBrannigan and 5.7TRDProm like this.
  16. May 29, 2021 at 9:48 AM
    5150bronco
    Justin
    Bay Area, Ca.
    Thanks for the ideas!
    Any other ideas out there or designs?
    definitely plate the frame, box in mount etc.
  17. Sep 29, 2021 at 1:28 PM
    Diesel_dave
    Diesel_dave New Member
    So where can I buy this
    Tundra4x4Offroad likes this.
  18. Oct 25, 2021 at 10:55 PM
    Tundra4x4Offroad
    Tundra4x4Offroad #somenewshitz
    Sam
    Los Angeles, CA
    08 Tundra SR5, 18 Tundra Platinum
    Too many mods to list right now for both Tundra
    Looking to develop one. Mechanical stress and deformation amount from the cab just need to be design into the part and I believe a 1/4” wall thickness plate with relocation and brace will brings a factor of safety of more than 5x. Look for my design soon to be release.
    Cosmo10, reywcms and TXTundra2722 like this.
  19. Mar 7, 2022 at 4:19 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I'd be interested in this bracket with some frame mount reinforcement plating as well
  20. Apr 4, 2022 at 8:11 AM
    #50
    Ragecage92si
    Ragecage92si New Member
    Josh
    17 blue TRD
    7" BDS lift kit,3” body, King 2.0’s, Mammoth Guards, Custom powder coating, Nitro 5.29, D.A.P. Tuned, Coachbuilder shims, Coachbuilder Steering kit, Wether Tech vent visors, and hood protector, spray in bed liner, Bakflip, Fuel wheels, 38” TOYO tires, Bushwacker fender flares, Dirty deeds exhaust , TDK front bumper, Rigid light bar/floods/spots. Husky fronts, Weather Tech rears, ESP under seat storage, PowerX2 battery, Android Tesla unit, AJT chrome delete, Horn Blasters, Custom switch cluster, Interior leds, Revere leds, 19 pro headlights, Rocklights, Custom MAYHEM projector
    Yes, I’d buy
  21. Apr 13, 2022 at 8:35 PM
    #51
    Cosmo10
    Cosmo10 New Member
    2010 Tundra Rock Warrior
    Soooo any finish product? Cause I’m needing it lol. I have done the BMC already to clear 35” tires with a 0mm offset BUT the driver side tire rubs when going reverse turning the wheel left at full lock. TAKE MY MONEY!
  22. Apr 13, 2022 at 8:49 PM
    #52
    Ryuu
    Ryuu zoom
    Oscar
    SouthEast, TX
    17 TRD PRO Barcelona Red
    NTK kit seems to follow everything tundra4x4offroad mentioned if you look at the description.
    https://ntkfabworks.com/products/tacoma4runner-cab-mount-relocation-brackets?variant=41413348163772
    EFE01AFA-A44E-4563-ACA1-C8020F84868A.jpg 41D08A59-6750-4223-B983-9995F21A0491.jpg
    my buddy bought the Tacoma version from NTK and it’s seems to be pretty stout. He just waiting to get it installed whenever he has time.
  23. Jul 7, 2022 at 5:44 PM
    #53
    ADSequippedtundra
    ADSequippedtundra New Member
    2011 Tundra Crewmax TRD
    ADS Coilover front shocks with MCM Fab mid travel upper A-arm, ADS piggyback bypass rear shocks with Deaver U748 leaf springs, flowmaster exhaust
    Do you happen to remember the specific part number of these bushings? Also, did you purchase them straight from Energy?
  24. Jan 24, 2023 at 1:29 PM
    #54
    Legend33
    Legend33 New Member
    Middlesex Massachusetts
    Bringing back this thread, anyone pick up this NTK Cab relocation kit? Thoughts? I saw the other post regarding Kit relocation. I think Ray's mention LCS Fabrication, what's the difference between these two? Any others out there worth mentioning?
  25. Jan 24, 2023 at 5:19 PM
    #55
    Ryuu
    Ryuu zoom
    Oscar
    SouthEast, TX
    I think someone here has the LCS kit or maybe I saw it on the FB groups, but if they're here hopefully they chime in. Thinks it's @khooiii actually.
    Buddy of mine that got his NTK kit installed last year on his Tacoma hasn't had any issues with it. Shop messed up though and didn't weld the load plates on the frame first so his mounts are straight to the frame but everything still looks good, not sure if he'll get that sorted later on.
    Differences I'm seeing is the NTK has the load mount plates that weld to the frame first, the LCS kit has reinforcements plates that go on the bottom of the mounts but no load plates so welded straight to the frame.
    DRT Fabrication also has a kit in the works for the Tundra but saw somewhere its not a priority to them since they haven't seen a large interest in them from Tundra folks. I like the DRT kit since on their Taco kit they have both load plates and the reinforcement plates
    Legend33[QUOTED] likes this.
  26. Jan 25, 2023 at 4:23 AM
    #56
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  27. Mar 13, 2023 at 7:38 PM
    #57
    Mrf1987
    Mrf1987 New Member
    2020 Trd sport tundra
    Guys,
    I talked to Drt fabrication and he informed me that his pre orders will go live in the next few weeks. This kit looks to be the strongest of all the other kits on the market as it offers the most well rounded beef mount and a base plate for the frame the same as the Tacoma kit. “Pictures are of the Tacoma mount but should be similar” I made a thread about it on the 2.5 gen page, I will update as I get an update of when the pre order is live!
    Legend33 and Ryuu like this.
  28. Mar 13, 2023 at 8:17 PM
    #58
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    About time. I reached out to him awhile back he had no plans but good to hear it’s changed
  29. Mar 13, 2023 at 8:20 PM
    #59
    5150bronco
    Justin
    Bay Area, Ca.
    if you cut the entire ear off, you should be good.
    I would definitely be interested in this mount set up especially for 37’s
  30. Mar 16, 2023 at 3:03 AM
    #60
    Mrf1987
    Mrf1987 New Member
    Update......Talked to drt yesterday and he informed me that the drop may go live friday! :fingerscrossed:
    TXTundra2722, reywcms and Legend33 like this.
