2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2020 MODELS [V 2.0]
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Apr 21, 2018.
  1. Apr 24, 2021 at 2:22 AM
    #1111
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Looks good @1lowlife that is the exact style look I'm going for. I have an MGM Tundra also.
    So how hard was the install with splicing the wires and everything since you have the dimming LEDs? I want to do the same thing. I have zero electric skills but I can follow directions and follow along with a video. Just may take me a lot longer to install.
  2. Apr 24, 2021 at 4:29 AM
    #1112
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    No experience and no splicing requires. It’s plug and play basically, really simple and easy to do tasks. It’s took me literally under 45 minutes.
    Damie Street[QUOTED] likes this.
  3. Apr 24, 2021 at 6:27 AM
    #1113
    JAZZY
    JAZZY New Member
    Discount code is Tundradude34. 5% off.
  4. Apr 24, 2021 at 6:30 AM
    #1114
    JAZZY
    JAZZY New Member
  5. Apr 24, 2021 at 9:55 AM
    #1115
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    If you want OEM twin led drls on bright during the day and dim with the lights on, @iHacker has a harness for that.
    I believe you have to run extra wiring into the cab to accomplish the diming down feature with the headlights on..
    All that info is in the first post of this thread.
    2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2020 MODELS [V 2.0] | Toyota Tundra Forum (tundras.com)
    If you want the OEM twin led drls on bright all the time, @iHacker has a harness for that too.
    I think that option is plug and play with no extra wiring.
    I could be wrong on that.
    The above link will answer a lot of questions you might have.
    As well messaging @iHacker directly.
    I also believe there is some kind of amber DRL delete mod, not sure how that works, it didn't interest me.
    Not sure where to find it.
    I don't like the bright OEM twin led drls on during the day, I prefer the amber DRLs.
    What ever harness he already makes, not sure which one, gave me what I wanted with no additional wiring or repining of sockets...
    My 2014 halogen headlights already had the amber DRLs, they would dim down with the headlights on.
    No LED strips in the headlights
    ov1edkmn_a34d5c55aa27f53bbfedc13ed49ca17dda293894.jpg y40tprnq_0ec56958cd88678a6dc2c2d55d3c525800c9432b.jpg
    I then bought the 2019 TRD Pro LED headlights, that have the OEM top and bottom LED strips, and @iHacker harness.
    Search Results | Sparks Parts
    Lights off amber DRLs, what I like on during the day.
    Parking lights on, LED strips come on dim.
    Headlights on, LED strips on dim.
    Amber DRLs dim down a bit too, just like the did on the 2014 halogens
    Also used these amber LED bulbs in the 2019 headlights..
    Amazon.com: Alla Lighting Super Bright T20 7440 7443 LED Turn Signal Light Bulbs WY21W 7440NA 7444NA 7440 7443 LED Bulbs High Power 2835 Chipsets 7440 7443 Amber Yellow Cars Trucks Blinker Lights Lamp Replacement: Automotive
    evydv5id_2ff78ffdc2a12e6c7570963dd8821c87341ce71d.jpg7xtbdzue_54f4973206be2e9ab9a05e97b9f74003c51284ab.jpg gk8itexz_05ccac5dc76dccb05e40b9a94650c436aaa00f0e.jpg 389ealpn_93fbf76900714999bd83c041bf1caf921c010db2.jpg
  6. Apr 24, 2021 at 3:25 PM
    #1116
    gedward
    gedward New Member
    Just installed on my 2017 Pro. Took me about 3 hours end to end, works great!
  7. Apr 24, 2021 at 5:28 PM
    #1117
    mike175gr
    mike175gr New Member
    Michael
    This project is much easier than I initially thought. My only regret is not doing it sooner! Thank you everybody for all the help!
    nhw544 likes this.
  8. Apr 24, 2021 at 11:42 PM
    #1118
    ScoopinTheDeuce
    ScoopinTheDeuce New Member
    2015 Tundra Platinum Black CM
    @iHacker Hi,new member but have been lurking these boards for years. Interested in ordering harness 2014-2017 1794/Platinum/2018-2021 SR5 (Trucks with single LED DRL and halogen headlights) $100 for my 2015 platinum.
    iHacker[OP] likes this.
  9. Apr 25, 2021 at 9:05 AM
    #1119
    mike175gr
    Michael
    That was the one that I purchased. Works great and super easy. I did zip tie them connectors together as suggested for the peace of mind.
  10. Apr 26, 2021 at 11:10 AM
    #1120
    Damie Street
    Edsel
    Hey everyone I have a used harness for sale. $80 shipped. This is the one I have:
    2014-17 TRD PRO/SR5/LIMITED Non-Dimming LED DRLs (Bright mode all the time) $110
    Non-Dimming Harness (Bright DRL All The Time), This option is 100% Plug n Play no wires to splice or mess with, no firewall wire or any sort of wiring under dash besides the Amber DRL Delete (optional) but the LED DRL turns ON/OFF with ignition and stay at full brightness all the time (not like factory functionality which dims the LED DRL). To power the LED DRL in this option we go to use a fuse tap to replace the 10A IGN fuse in the hood fuses box. Price for this option is $110 shipped to U.S. addresses.
  11. Apr 28, 2021 at 3:19 PM
    #1121
    paulbk
    paulbk New Member
    FINALLY got this done.
    I received my set of TRD Pro headlamps but, the right one was cracked on all the mounting points:cool:.
    Had to return the damaged one and wait almost 2 weeks for a replacement.
    I wish I had done this when I replaced my grill and surround. It’s not fun tugging at the grill:oops: In any case it’s done and everything works perfectly!
    Like others before me, the harness is better than OEM quality and is 100% plug and play. I wish the headlights didn’t require so much dismantling of the front end to remove and install them! Next are fog lights for sure!
    Don’t mind the dirty truck. It’ll be washed once the sun cools down!!
    THANKS AGAIN @iHacker
    5C1E04C7-7B8F-4D4E-A285-5AF54FE78FFB.jpg 9A29E8B3-39D2-4EF6-B072-12A0E4E86D6B.jpg 370B7D32-6820-4652-9ADA-6266BD633732.jpg FD9C56BE-D9F1-4D2A-B75A-200E9237E6E1.jpg
    Damie Street, TunBrun and iHacker[OP] like this.
  12. May 3, 2021 at 3:13 AM
    #1122
    Black
    2014 Tundra Limited CrewMax
    Shot you a PM.
    I have a 2014 Limited no LED DRLs. Swapping to 2019 TRD Pro LEDs.
    Just want the simple plug and play harness. Not worried about the dimming part.
    Been needing to freshen up these headlights!
  13. May 3, 2021 at 6:33 AM
    #1123
    VTProTundra
    VTProTundra New Member
    Vermont
    2016 Tundra Pro
    JL Audio , Rigid Lightbar, iHacker harness and 19 TRD Pro Black Headlight Mod
    ihacker is the man! so easy to deal with and responsive. i ordered the dimming harness and the trd pro blacked out headlights (Sparks). I took my time and don't have any electrical background - was nervous about working inside the dash with the wiring but with the pics/videos and patience was able to posi tap the grey wire to maintain the amber DRL with the LED (did not de pin the grey wire). I had ordered a mix of posi taps prior to the install ( https://www.amazon.com/POSI-TAP-Ass...gid=pla-882472888927&ref=&adgrpid=81184753169). Red one fit the grey wire tap and used the included blue one for the black wire tap (included with the harness). Thanks again to iHacker for doing this and thanks to others who have posted on the thread - very helpful! Cheers Brad
  14. May 10, 2021 at 11:39 AM
    #1124
    Black
    Got mine in the mail today! Looks like great quality. Headed to the cabin for the day tomorrow so hope to get the new headlights installed Wednesday.
  15. May 27, 2021 at 1:04 PM
    #1125
    Clifton63
    Clifton63 New Member
    Clif
    2014 Tundra 4x4 5.7 SR5 DC, Grey Metallic
    TRD Pro Grill
    Ihacker. I would like a harness for my 2014 Tundra SR5. I want the diming option. Mine came from the factory without the LED DRL.
  16. Jul 3, 2021 at 12:40 PM
    #1126
    Jlysaght
    Jlysaght New Member
    @iHacker Just PMed you for a harness.
    iHacker[OP] and Taco-Spike like this.
  17. Jul 3, 2021 at 7:05 PM
    #1127
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    @iHacker I just sent you a PM for a harness.
  18. Jul 4, 2021 at 12:16 PM
    #1128
    Leoking
    Leoking Leon-0
    Edward
    Minnesota
    '16 Toyota tundra CM Sr5
    I might be late to this party but here it is.
    I was in a hurry when i took the pictures but you get the idea. I'm very pleased with the results. Thanks to @iHacker for the very quality good product and great costumer service. It's still a work in progress, gotta make some time to go to the local shop to get the bumpershellz paint it and no more chrome. 20210704_140509.jpg 20210704_140341.jpg 20210704_140308.jpg
  19. Jul 11, 2021 at 8:55 AM
    #1129
    Gray223
    Gray223 New Member
    2014 Tundra Double Cab Limited
    Anyone know if you can make the led strip amber instead of white??
  20. Jul 11, 2021 at 9:31 AM
    #1130
    iHacker
    iHacker [OP] SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    It can be done if you find the LED boards replacement but let me tell you isn’t an easy task because this involves baking your headlights to take them apart and replace the LED boards.
    I recommend you to check for Morimoto or Alpharex headlights I think they made a headlights option with amber DRL instead of the classic white
    Gray223[QUOTED] likes this.
  21. Jul 11, 2021 at 9:33 AM
    #1131
    Leoking
    Leoking Leon-0
    Edward
    Minnesota
    Alpha rex? Or morimoto
  22. Jul 11, 2021 at 9:43 AM
    #1132
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    @iHacker, do you have any interest in producing a harness for the 2014+ trucks that would enable a "turn as tail" function?
    The aftermarket taillights are :puke:to me.. Anyway, I thought I'd ask if you have the know how and time to do something like this.
    Barrett50 likes this.
  23. Jul 11, 2021 at 11:45 AM
    #1133
    Gray223
    Gray223 New Member
    I've baked eBay headlights before for a 1st gen tacoma retrofit but those where alot cheaper then tundra headlights lol
    iHacker[QUOTED][OP] likes this.
  24. Jul 11, 2021 at 9:42 PM
    #1134
    iHacker
    Well if you find a LED board conversion you have the retrofit experience required to take your headlights apart.
    I haven’t heard of any available for the 2018-2021 headlights
  25. Jul 11, 2021 at 9:48 PM
    #1135
    iHacker
    Don’t have any plans for that but you probably can achieve that using a rectifier diode so the circuit can be isolated from the blinker signal but still receive the tail light signal (resistors might be required as well if a fast blinking is detected)
    GODZILLA[QUOTED] likes this.
  26. Jul 12, 2021 at 12:08 AM
    #1136
    Wyoming
    I appreciate the response, but I'm an electrical dummy. That was all kinda Greek to me. :sorry:
    I am still rocking the stock incandescent taillights and I was just hoping to be able to make both bulbs illuminate as tails. Stock setting makes it look like I've got a burnt out tail light.
    I know there was mention of somebody else working on a harness for this over in the morimoto taillight thread, but I don't remember who they said the company was. I thought our local Harness Guru might be a go to for a solution.
  27. Jul 12, 2021 at 7:47 AM
    #1137
    iHacker
    The problem to create a plug and play adapter is that we don’t have a specific plug to mate with the turn signal and what we have is just a dead end in the taillight assembly, that’s why the only way to do it is splicing directly into the factory wiring and most people including me try to avoid this at all costs if possible
    GODZILLA[QUOTED] and Y0TA PR0 like this.
  28. Jul 12, 2021 at 11:14 AM
    #1138
    Wyoming
    Ooooh. See, this is why I asked you! :bowdown:
    Bummer that it'd be something like that. I had hoped that, because the one bulb does nothing but the turn signal, it would be as simple as adding a harness between the two bulbs. Hacking up factory wiring is too much risk for a purely cosmetic change.
    Thank you, again, for sharing your knowledge!
  29. Jul 17, 2021 at 6:34 PM
    #1139
    iHacker
    RedRegCab and Barrett50 like this.
  30. Jul 18, 2021 at 7:56 AM
    #1140
    Dnastor
    Dnastor New Member
    Messaged you. Interested in the 2014-17 TRD PRO/SR5/LIMITED Non-Dimming LED DRLs (Bright mode all the time) $110 harness.
