Power drivers seat - pop/slight movement
Discussion in '2.5 Gen Tundras (2014-2021)' started by GT87, May 14, 2021.
  1. May 14, 2021 at 8:10 AM
    GT87
    GT87 [OP] New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Hey guys. I have a '21 crewmax SR5 TRD/OR with about 1500 miles on it.
    I've noticed that when I stop and then accelerate I can feel almost a slight 'clunk' or 'pop' in the drivers seat. It feels like it's coming from the seat but I can't really tell if its from the bottom of the seat connected to the floor or if its the back of the seat. It only moves slightly (maybe 1/8") but it is getting to be VERY annoying. I've adjusted all the positions (front/back, down/up, and lumbar) and that hasn't helped, still does it. I even tried to rock the seat back and forth and there really isn't any movement in the seat. Seems to only happen when I'm actually sitting in the seat and accelerate. I had a '20 before this one and never had this issue.
    Has anyone ever experienced this issue before? I plan on taking it to the dealer soon but wanted to check with the experts (you guys) first.
    Tileguy and TundraLyfe like this.
  2. May 14, 2021 at 8:14 AM
    LarryDangerfield
    LarryDangerfield Put me in coach! Staff Member
    Tyler
    Northern Wisconsin
    Cement 2020 Trail Limo off-road Tacoma
    Tuxmat floor mats, Bilstein 6112s and 5160s
    I also have the same issue. It will pop, and then I try to recreate it by wiggling around and it won't do it again. It doesn't do it constantly, just once a trip or every other trip.
    GT87[QUOTED][OP] likes this.
  3. May 14, 2021 at 8:19 AM
    GT87
    Greg
    Western NY
    Sorry to hear you are having the same problem but glad to hear its not just me. If I'm really easy on the gas it doesn't do it but any other time it will do it. This shit is driving me crazy. I know it sounds minor but paying $45k for a truck I expect the damn seat to not move.
  4. May 14, 2021 at 9:01 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Try putting a wrench on all the mounting bolts and see if they're loose before you go to the dealer. Could be a very simple fix. If that doesn't do the trick then I'd take it to the dealer.
    GT87[OP] and LarryDangerfield like this.
  5. May 14, 2021 at 10:18 AM
    GT87
    Greg
    Western NY
    That was the first thing I checked and unfortunately they were all tight and secure.
    Sumo91[QUOTED] likes this.
  6. May 14, 2021 at 10:25 AM
    Sumo91
    TN
    Maybe its something with the tracks? Loose bolts elsewhere under the seat that hold the tracks on or something. Just spit balling here. It'd be worth a look. I'll take a look at mine later today and see if I can see anything that might cause what you're experiencing
  7. May 14, 2021 at 10:33 AM
    GT87
    Greg
    Western NY
    That would be great. I'm going to really get in there again and check everything out again before I take it in to the dealer.
  8. May 24, 2021 at 10:52 AM
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    Yes I've experienced the same on my 2020 Tundra. Dealer said it was normal as always
    KingsAustin and GT87[OP] like this.
  9. May 24, 2021 at 11:02 AM
    GT87
    Greg
    Western NY
    Normal my ass. I've never heard of a seat actually moving while driving be considered normal lol. My '20 never did this which is why I was surprised when my '21 started doing it.
  10. May 24, 2021 at 11:05 AM
    GeeWhiz
    GeeWhiz New Member
    My dealer told me the same thing. "we could replace the seat, but it would just do the same thing". As mentioned, it's very annoying and disappointing for a brand new truck.
  11. May 24, 2021 at 11:14 AM
    dittothat
    dittothat New Member
    SD
    2016 MGM Platinum
    My ‘16 does it but I feel it in the lumbar area. I posted up about it when I first joined here but never got any solid answers
  12. May 24, 2021 at 11:40 AM
    itsmerh85
    Gilbert, AZ
    2020 Black TRDPro
    agreed, pretty frustrating. I sometimes feel it in the lumbar area like @GeeWhiz said, but sometimes I feel it in the seat (I think?). It might be a bolt or something connecting those two, I'm not sure.
  13. May 24, 2021 at 11:45 AM
    GT87
    Greg
    Western NY
    I feel the exact same thing. Sometimes it feels like the inner-lumber support moving but then something if feels like the whole seat itself. Very frustrating for that to happen on a new $45k vehicle.
  14. May 24, 2021 at 11:53 AM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Dumb question, but I am assuming this is a power seat? I have a manual seat and havent had this issue, except when i adjust, sometimes i get it between positions and it will settle into the closest position. Never does this if i am not actively trying to adjust the seat. Anyone have the same issue as OP with a manual seat?
    GT87[OP] likes this.
  15. May 24, 2021 at 11:56 AM
    GT87
    Greg
    Western NY
    Yes, this is a power seat. And I know exactly what you are talking about when you are in the "in-between" position on a manual seat and then it kinda pops into place when you move or start driving. My old Taco did that all the time when I went to adjust it.
  16. May 24, 2021 at 12:00 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    My power seat in my 21’ does the same thing. Dealer told me it was normal and I told them to show me another truck on the lot that did it. We checked the other trucks and the rest were solid. They said I could bring it back for warranty but I just haven’t had the chance to so so yet.
  17. May 24, 2021 at 12:16 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Mine does it as well. It feels like the pivot is loose as I can feel it most on my lower back when I am adjusting myself in the seat.
  18. May 24, 2021 at 12:25 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    The plastic anti-vibration washers are probably worn.
    Bammer likes this.
  19. May 24, 2021 at 12:37 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Thanks for clarifying.
  20. May 25, 2021 at 9:39 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I'd make them prove that theory by replacing the seat.
    Then I'd make them show me the new seat before installing it so they don't just say they put a new one in.
  21. May 26, 2021 at 6:25 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Just turn up the stereo, if the wheel falls off you will know, aside from that change the oil
    periodically and fill the gas frequently.
  22. Jan 3, 2022 at 10:13 AM
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
  23. Jan 4, 2022 at 7:57 AM
    ziggy04
    ziggy04 New Member
    Eric
    2021 Tundra
    I have the same exact problem with my '21 Pro and my friend has the same thing with his '21 1794. Drives me crazy sometimes.
  24. Jan 4, 2022 at 9:18 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Same issue with mine. 99% sure it comes from the lumber support - seems to be a horizontal movement from front/back. I just try to ignore it now.
  25. Jan 5, 2022 at 12:38 PM
    War
    War New Member
    War
    21776
    2021 Tundra Limited Nightshade
    4" Ready-Lift Suspension Lift Kit 285/60 R20 or 33's BF-Goodrich All-Terrain K02 Tires Fuel Off-Road D694 Covert Wheels Bush-wacker Fender Flares, Painted to Match with Black bolts Duel Exhaust Front and Back Sway Bars (TRD) All LED Interior Lighting (what an amazing difference) WOLFSTORM Smoked LED Tail Lights with Sequential Turn https://amzn.to/3Y9JIpX LED Lighted Power Window Switch Control (auto up/down for all 4 windows. (blue lights) https://amzn.to/3DFPSXU !!!!! Work great. Here is the video I went off of. https://www.youtube.com/watch?v=ziQULigoBkQ https://www.sparksparts.com/p-2014-toyota-tundra-grab-handle-kit-gray-pktungrabb0
    Has anyone found what the problem is? Same thing here on my 20, drive Power Seat. Passenger seat is nice and tight.
  26. Jan 5, 2022 at 12:49 PM
    GT87
    Greg
    Western NY
    I took mine in to the dealer and had them drive it and of course they said they couldn't feel anything. I was already running late so I didn't have time to argue with them.
    That being said, I'm almost positive it has something to do with the adjustable lumbar support area. As you said, the passenger side is nice and tight, probably because that side doesn't have the adjustable power lumbar option.
    I actually spent about 20 mins of constantly messing with all of the adjustable seat dials hoping that it would cause something to "settle" into place and it actually seems to do it less often now. But still does it nonetheless.
    War[QUOTED] and GREENwithENVY like this.
  27. Aug 25, 2022 at 8:30 AM
    TundraLyfe
    TundraLyfe New Member
    2020 Toyota Tundra Limited
    My ‘20 Limited just started to do this a few days ago. I can recreate it stand out side of the truck and lifting up on the seat base every time. I can feel it coming from the floor of the truck like is a weak spot in the sheet metal. Definitely not happy with it. Will be taking it to local dealership. I demand answers.
    RilerOfDogs likes this.
  28. Sep 16, 2022 at 7:31 PM
    Mbh1970a
    Mbh1970a New Member
    I went to the dealer today with my 2021 1794 to have seat frame replaced. It has gotten worse lately i figured it was the multi movement of the seat and I’m a big man and I’m not sure the next one will not do the same thing. But I see some on here have sr5 , that i don’t
    think have the premium seats, it started with just a slight movement on take off but couldn’t recreated after it did it. Sounds a little like sheet metal flexing pop. It got where the lumbar would move By shaking it. Anyway the lumbar was all that came in today after back order for a moth. the bottom frame didn’t come in.
    Did get new leather on passenger seat today , front strap that connects it to front of seat would not stay attached from day one.
    19k
    No problems with warranty and tech said they was definitely movement in multiple points
  29. Nov 9, 2022 at 10:34 PM
    vman82
    vman82 New Member
    2021 Toyota Tundra Crewmax Limited
    Bump...
    Any updates on what the issue is...or fix for the problem?... I have the same problem my 21 Limited Crewmax and don't want to take it in if I can help it.
  30. Nov 10, 2022 at 4:47 AM
    Mbh1970a
    Mbh1970a New Member
    They ordered a new drivers seat for my 21 1704 edition, back and Bottom , but while it was being shipped i got t boned and truck has been in shop since September 26, so haven’t had new seat frames installed yet. But it was covered under warranty.
