  1. May 21, 2021 at 5:40 PM
    biebs96
    PA
    It’s funny that the two identical ports each have a different voltage displayed.
    ...this would kill me...
    also, what USB port is that?
    Fotnot likes this.
  2. May 21, 2021 at 5:40 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    2017 Limited Crew TRD, Ironman Pros with JBA uppers. Prinsu rack. RSI, RCI sliders
    Got the 295/70 18's installed. Yoko X AT's, only rubs on the skid plate. Also put on the Prinsu yesterday, what a pain in the ass that was..
  3. May 21, 2021 at 5:44 PM
    biebs96
    PA
    I have these tires, you’ll be happy...Once they are balanced properly. They can be tough to get perfect.
  4. May 21, 2021 at 5:54 PM
    SEM Trim Black. I have pics in my build thread.
  5. May 21, 2021 at 6:47 PM
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Which one exactly? Looked up SEM on Amazon and came across several finishes. Wasn't sure which one to get.
  6. May 21, 2021 at 6:50 PM
    39143.....I should have put that in the reply
    SchnauzerMan likes this.
  7. May 21, 2021 at 6:53 PM
    What's nice about it is that it is more durable than regular spray paint. It dries quick and does not have that strong or long lasting spray paint smell. I did 4 to 5 lights coats.
    TunBrun, Hightide and Djone27[QUOTED] like this.
  8. May 21, 2021 at 7:17 PM
    Angry Gunny
    Angry Gunny New Member
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    Mounted my ammo can.
    Wallygator, Ostrich, YotaBro and 6 others like this.
  9. May 21, 2021 at 7:22 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I like that alot, too bad my truck isn't a TRD.
    TucsonTundra1794 and batmandog like this.
  10. May 21, 2021 at 7:45 PM
    batmandog
    batmandog New Member
    Maryland
    2018 super white DC trd sport
    6" APS iboard running boards, Tyger 6" iBoard
    Tomorrow morning the Timbrens go in
  11. May 21, 2021 at 7:46 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    This^^^^
    Then vinyl wrap. Takes some time, but adds a little different touch. Here’s mine.
    nmjameswilson[QUOTED] likes this.
  12. May 21, 2021 at 8:23 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I know this has been covered a billion times buy I'll ask since your sharing. Does the paint need a matte clear coat to really look and feel OEM?
  13. May 21, 2021 at 9:03 PM
  14. May 21, 2021 at 9:06 PM
    SAGE63
    San Diego County
    I went with the Durobumps front and rear. seem to be good so far...
    Wallygator and batmandog[QUOTED] like this.
  15. May 21, 2021 at 9:37 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Industry secret.
    Ha!
    I actually used a construction marker that is meant to write on anything.
    I’ll try to snap a pic tomorrow.
    it’s held up really well and if ever in need of a touch up, it’s on hand and easy.
    https://www.lowes.com/pd/Sharpie-PRO-Chisel-Xl-Permanent-Marker/1000515179
    The tolerances are so tight I was not too sure about painting them.
    The marker was perfect.
  16. May 21, 2021 at 9:39 PM
    Hightide
    Abalama
    Magic School Bus
    This is the good stuff.
    It applies easily, adheres well and basically will correct itself when making a mistake.
    when painting my dash panels I over applied in one area leading to a run.
    I thought, surely I will have to wait for it to dry and sand it out.
    When I came back 20 minutes later it was gone.
    nmjameswilson and Jpd0144 like this.
  17. May 21, 2021 at 10:44 PM
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
  18. May 21, 2021 at 10:47 PM
    point08
    point08 New Member
    Kyle
    My 3dw window mod came in today... Wasn't expecting it. Guess I'll be putting that in this weekend.
    1UP likes this.
  19. May 21, 2021 at 10:49 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  20. May 21, 2021 at 10:51 PM
    point08
    point08 New Member
    Kyle
    Didn't realize these were two different vendors. Is there a quality difference in the front camera?
  21. May 21, 2021 at 10:56 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I just checked the FRAC kit - you need to supply your own with that one. I think between the lower cost on the Anytime kit, including the camera and better switch, I’d go that route. The FRAC kit is really good as well, and well documented on here, but the same can be said about the Anytime kit.
    point08[QUOTED] likes this.
  22. May 22, 2021 at 3:29 AM
    nmjameswilson
    nmjameswilson New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
  23. May 22, 2021 at 4:11 AM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Mine is a platinum, TRD only means Toyota Racing Development. Just a phrase. Just do it, oh wait that’s Nike! Lol
  24. May 22, 2021 at 4:21 AM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Thanks for the idea! How’s that holding up so far and did it effect the lighting of the button?
    Hightide[QUOTED] likes this.
  25. May 22, 2021 at 4:23 AM
    Punisher29073
    Punisher29073 New Member
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    At the rear, how high is this roof rack from top of roof? Trying to figure out if a roof rack will fit under the overhang of the AT Habitat.
  26. May 22, 2021 at 5:29 AM
    Newey
    Newey New Member
    2021 Lunar Rock TRD Pro, 2016 Tundra TRD CM, 2010 Tundra SR5
    80D8EBE7-FF00-4BAC-8C1C-FCDF71940F95.jpg Added 30” led light bar
  27. May 22, 2021 at 5:31 AM
    Taco-Spike
    Two Trucks
    What brand you go with? Combo / spot?
  28. May 22, 2021 at 5:41 AM
    No...it will look just like mine in my build thread.
  29. May 22, 2021 at 7:00 AM
    poheller
    Scot
    2018 platinum
    Also added hood decal
  30. May 22, 2021 at 7:03 AM
    Cthulhu
    Very unique. Toyt.
