Start X
Discussion in 'New Member Introductions' started by SammieZamboni, May 9, 2021.
  1. May 9, 2021 at 6:39 PM
    SammieZamboni
    SammieZamboni [OP] New Member
    Fontana, CA
    2020 2wd bright white SR5 crewmax tundra
    Newbie from So Ca here, been searching the threads most of the day and appreciate all the info... cannot seem to find much info on anyone installing start x remote starter tho. Having an issue with it on my 2020.4CD60DA9-5695-4AD0-9725-9FBD51B9B59C.jpg
    AZ Red Nek and Prostar 190 like this.
  2. May 9, 2021 at 6:43 PM
    Welcome from Ohio
    SammieZamboni[OP] likes this.
  3. May 9, 2021 at 6:45 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I remember seeing a couple of things about Toyota, and specifically the Tundra start circuit that takes special care when installing 3rd party remote starts. I don't remember the details but it was on this forum within the past month or so.
  4. May 9, 2021 at 6:50 PM
    SammieZamboni
    Fontana, CA
    Thanks, I’ll keep searching
  5. May 10, 2021 at 5:33 AM
  6. May 10, 2021 at 5:34 AM
    Welcome from NY.
  7. May 10, 2021 at 7:07 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  8. May 10, 2021 at 7:09 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  9. May 10, 2021 at 10:53 AM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska
  10. May 10, 2021 at 12:22 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  11. May 10, 2021 at 12:34 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    What's the issue?
  12. May 10, 2021 at 1:17 PM
    SammieZamboni
    Fontana, CA
    It states that for 2020+ you need to splice one wire but I can’t find out which wire needs to be spliced. When I remote start the truck I can’t use the clicker to unlock it, have to unlock it with the key.
  13. May 11, 2021 at 7:18 PM
    SammieZamboni
    Fontana, CA
  14. May 12, 2021 at 4:47 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  15. May 14, 2021 at 4:18 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Nice truck and welcome from Phoenix
  16. May 16, 2021 at 5:23 PM
    SammieZamboni
    Fontana, CA
    Love PHX, left there about a decade ago. Still visit often.
    AZ Red Nek[QUOTED] likes this.
  17. May 16, 2021 at 5:27 PM
    Handbanana
    Handbanana New Member
    2018 TSS CM 4x4
    Trd sway front Trd sway rear Trd shift knob Nitto ridge grapplers OEM LED FOGS
    What issues are you having? I installed one on a 2018 it was basically plug and play besides one wire I believe. The starter works great and it’s lasted me this whole time customer service though is probably nonexistent let me know what questions you have and I’ll try to help you
  18. May 16, 2021 at 5:32 PM
    SammieZamboni
    Fontana, CA
    It states I just need to splice one wire for 2020+ . I can’t find any info anywhere as to which specific wire needs to be spliced. It works great, only issue is that once remote started I can no longer use the unlock button on my key fob. Also cannot turn off the truck if I decide not to leave. Once remote started my remote is essentially dead.
  19. May 17, 2021 at 10:19 AM
    Penberrf
    Penberrf New Member
    2020 Tundra
    You need to cut the TPMS wire, had to do it on my kit from Accessorides. Locate the 36-PIN white plug at the ECU module in the drivers dash to the left of the 30-pin BCM connector plugged in earlier. Find the RED or PINK wire in pin 35 of the 36 pin connector. Cut this wire giving yourself room to reconnect to both ends
  20. May 17, 2021 at 6:24 PM
    SammieZamboni
    Fontana, CA
    Awesome, thanks for the info! I’ll give it a shot ASAP
  21. Dec 25, 2021 at 9:04 AM
    Akaklutz
    Akaklutz New Member
    Alan
    2021 Tundra
    New stock
    What did you discover.
    Just installed the same remote start and everything works but the instructions are not specific on the bcm bypass regarding the pin 35 splice
