Tundra A/T and M/T Tire Options - Let's hear your reviews
Discussion in 'Wheels & Tires' started by csuviper, Feb 18, 2014.
  1. Apr 13, 2021 at 6:57 PM
    #271
    NAFlash
    NAFlash New Member
    Randy
    Tundra TRD Sport 4x4
    Still working on how much tire pressure to run. 42 psi right now
    Mjrpa likes this.
  2. Apr 13, 2021 at 6:59 PM
    #272
    NAFlash
    NAFlash New Member
    Randy
    Mjrpa[QUOTED] likes this.
  3. Apr 13, 2021 at 7:14 PM
    #273
    BluegrassPro
    BluegrassPro New Member
    Jeff
    2021 TRD Pro
    Yikes. Mine are 33-35 cold.
    Oey12 likes this.
  4. Apr 14, 2021 at 6:01 AM
    #274
    NAFlash
    NAFlash New Member
    Randy
    Yeah, 42 might be to much, just started experimenting with different pressures. Gonna do the chalk test today and see how that works.
  5. Apr 14, 2021 at 6:21 AM
    #275
    BluegrassPro
    Jeff
    2021 TRD Pro
    I honestly am not sure. I need to research it more too. That’s just what the tire store did. I usually try to keep my tires around that because it’s a smoother ride. As long as you keep it above 30 I think tire wear will be fine.
  6. Apr 14, 2021 at 10:05 AM
    #276
    NAFlash
    NAFlash New Member
    Randy
    Well the stock tires that came on the truck were passenger tires and the Ridge Grapplers are load range 117T rated at max 50 psi. I'll let you know how the chalk test turns out.
  7. Apr 19, 2021 at 3:26 PM
    #277
    Trabs00
    Trabs00 New Member
    Travis
    Seattle, WA
    2012 Black Tundra CM
    7" BDS lift King 3.0 Performance series with RR and adjusters 37" Yoko Geo MT Front bumper Demello Offroad Rear Bumper Expedition 1 ATC canopy AMP power steps Alu-cab RTT Alu-cab shadow awning Alu-cab shower cube
    Those E-rated?
    I run 42 Front, 44 rear until I air down for trails. But my truck is heavy AF. You can definitely feel ALL the bumps at 40+ but handles great on highway
  8. Apr 19, 2021 at 7:41 PM
    #278
    NAFlash
    NAFlash New Member
    Randy
    Yeah, E rated, and max 50 psi. Says XL as well, which means extra load. But it's not an LT tire. I've been running 42 and the chalk test looks like that's the right pressure, or close to it.
    Trabs00[QUOTED] likes this.
  9. Apr 26, 2021 at 11:28 AM
    #279
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    Have about 300 miles on these Maxxis Razr MT so far. I've been extremely happy with them. There is a slight hum at highway speed, but it is extremely mild compared to old school mud terrains I've had, and heard roaring down the street in the past. Honestly these are unlike any other mud terrain I have driven, it's fantastic.
    No complaints driving around the road, and they tore the grass right up and cleared out easy when I got in some mud.
  10. May 7, 2021 at 12:37 PM
    #280
    Skold
    Skold New Member
    Can someone recommend a good alternative to a Goodyear Duratrac? I like the aggressive look and tread life but they are very noisy and don't perform well enough on wet surfaces. Does anyone have a recommendation that is a good value, has a good aggressive look, tread life, and wet pavement performance? I do not go mudding or any serious offroading but do occasionally take it places like the beach and on tame trails. THank you in advance!!!
    DBLTRBL likes this.
  11. May 7, 2021 at 12:44 PM
    #281
    LarryDangerfield
    LarryDangerfield Put me in coach! Staff Member
    Tyler
    Northern Wisconsin
    Cement 2020 Trail Limo off-road Tacoma
    Tuxmat floor mats, Bilstein 6112s and 5160s
    Give the Kenda Klever AT2 a look. Very affordable, good aggressive look, 60,000 mi rated tread in standard load and 50,000 miles in e-load. I have them and I'm very happy with them so far.
    Skold[QUOTED] likes this.
  12. May 7, 2021 at 12:45 PM
    #282
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Check out the new Mickey Thompson Baja Boss A/T's. They look pretty sweet and a 50k warranty. I'll be switching out my Duratracs when Discount has these Mickey's available.
    Skold[QUOTED] and Trabs00 like this.
  13. May 7, 2021 at 12:57 PM
    #283
    Trabs00
    Trabs00 New Member
    Travis
    Seattle, WA
    This. I ran MT Baja ATZp3s and at 30k miles they were at 9/32nds (18.5 brand new) And this was with some pretty rough trails / off road, rocks etc. on a heavy truck.
    On my previous rig (4Runner) I ran several sets of Cooper ST/Maxx and loved them. Probably my favorite tire. MTs a little more aggressive, ST Maxx a little more towards A/Ts.
    Note: ST Maxx looks more aggressive in person
    Skold likes this.
  14. May 7, 2021 at 1:02 PM
    #284
    Fepony
    Fepony New Member
    2021 Tundra TRD CrewMax Silver Sky Metallic
    I used to use Cooper, but I found Milestar Patagonia to be a far superior tire off road. I have Cooper SST on my F150 but they are very noisy on the highway. I have Cooper ST Maxx on the F350 and they are quiet and do well, they are not as good as the Milestar.
    Skold likes this.
  15. May 7, 2021 at 1:03 PM
    #285
    Trabs00
    Trabs00 New Member
    Travis
    Seattle, WA
    To me the ST Maxx were better on wet pavement.
    FYI both tires have amazing sidewalls
  16. May 7, 2021 at 6:47 PM
    #286
    Skold
    Skold New Member
    Thank you all for the input! I will be researching these.
    Keep the suggestions coming!
  17. May 10, 2021 at 11:17 AM
    #287
    bigo6627
    bigo6627 I like to play in dirt
    Anthony
    Phoenix Metro Area. East Valley
    2012 Tundra CM LP 4X4 4" lift on 35s
    -FlowMaster Cat back exhaust -K&N® - 33 Series Panel Red Air Filter -Tonneau cover -Blind spot mirrors -Shorty antenna -Window Tint 20% all around -"Frankenstein" Lift 4.5 in x 2 in (Truck settled to 4"): -3.5” RC coil overs -RC UCA 2”- 4” Lift -RC Rear shocks 0-3” -Coachbuilder shims correcting “Tundra lean” - 2 - left front - 1 - Right front -2” rear shackle lift - Protune Suspension -Diff (front) drop kit - Protune Suspension -Front Skid plate drop kit - Protune Suspension -Front sway bar drop kit - Ready Lift Suspension -Driveshaft Carrier bearing drop kit - TuffCountry -Bump stop extensions - Protune Suspension -Rear brake line extension - Protune Suspension Wheels and Tires: -18x9 Method MR701 Matte Black Wheels +18 Offset, 6” BS with Bead Grip Tech -MAXXIS Razr MT 35x12.5R18 Lights -32" LED Light bar -3" Ditch SpotLights -Ditch Light Hood bracket mount LED Light Upgrade -Headlight & High beam - Sealight -Fog Light - Sealight
    Like HugeMoose, I have about 3k miles on Maxxis RAZR MT in 35x18. They do have a slight hum but they are unstoppable Offroad. They have great city and highway manners as well. I lost about .5 mpg mounting these from stock 20s. Here's what sold me after months of research. RAZR Mts are the only MT tires with a 50k mileage warranty. 799D9FF0-A63B-4A7F-817D-66A6ADDBEF3B.jpg
    Hugemoose[QUOTED] likes this.
  18. May 10, 2021 at 2:02 PM
    #288
    Skold
    Skold New Member
    After some research and deliberation, I've decided to go with the Kenda Klever RTs. I would have gone with the Cooper ST Maxx but could not justify paying about $120 more per tire. I hope they perform well. I should post a pic when they're on.
  19. May 11, 2021 at 5:24 AM
    #289
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    I'm glad to hear you like them as well. The slight hum they make, to me at least, is amazingly tame compared to other MTs. They definitely worked some magic with these. And yes the mileage warranty is a huge perk as well, however I do think it is 40k miles. The 50k miles I think is for the AT Razrs, which also looked pretty damn good! Even though I don't need MTs every day, they are there for when I do occasionally need them. My last tires for the Cooper ST Maxx, and I vowed to never get something less aggressive every again lol. Those were great tires as well, but just didn't come in the size I wanted, 285/75r18.
  20. May 11, 2021 at 5:26 AM
    #290
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    I think you'll be very happy with those; they have a great reputation so far. My friend just put a set, stock size but E rated, on his stock 2019 Ram. He's been very happy with them so far.
  21. May 11, 2021 at 6:48 AM
    #291
    Skold
    Skold New Member
    Yeah, I'm actually kind of excited to get them. I'll let everyone know what we think once they're on...next week.
  22. May 12, 2021 at 10:07 AM
    #292
    bigo6627
    Anthony
    HM - You're right about the 40k mileage warranty. I got them partially because in my neck of the woods, everyone has Nitto Ridge Grapplers and I'm not a follower. I like my mud lugs and and I'm not afraid to jump a few curbs mall-crawlin! In all actuality, this pic is the only curb I've jumped recently - right after cleaning the rig. What's wrong with a little fun?? :D:D:D8C5093B2-F218-474C-8979-F10862964241.jpg
  23. May 12, 2021 at 10:22 AM
    #293
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    Haha I know, Ridge Grapplers are everywhere around here too and I also wanted something different. I actually smacked a curb leaving work 2 days ago, and I was definitely pleased to have beefy tires lol. I wasn't paying attention, and had I still had those stupid P rated stock tires I might have taken it out. The sidewalls on these are awesome too, I can't wait to put these to the test more.
  24. Oct 4, 2021 at 6:42 AM
    #294
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Well its that time again. Need to make a choice soon.
  25. Oct 4, 2021 at 6:54 AM
    #295
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    I have about 50 miles on my 295/70r18 Mickey Thompson Baja Boss A/T. Been very very happy with them. Very chunky but good pounding pavement too. Heavy, but I haven't noticed the weight like I thought I would.
  26. Oct 4, 2021 at 6:57 AM
    #296
    csuviper
    Broomfield, CO
    Dang I have had these tires for over 4 years and on two different trucks!!!
  27. Oct 4, 2021 at 12:55 PM
    #297
    csuviper
    Broomfield, CO
    Cooper Discoverer AT3 XLTs are looking pretty good
    552879d1552241142-cooper-discoverer-at3-_a9490e87fddbded27586fd683305cde5ff11ffa3.jpg
    Red Sonja and Muleycrazy13 like this.
  28. Oct 4, 2021 at 1:02 PM
    #298
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    I considered those too, but they aren't very aggressive besides the sidewall. I saw a few in person and was a bit disappointed. If you want another AT/hybrid type tire like you have before check out the Maxxis Razr AT. I have the MT version and love them, but I was very close to getting the AT. It has a 50,000 mileage warranty, and I think look pretty damn good too! The Razr MT is lightyears better than any other MT I've had before, so I'm sure these are equally impressive.
  29. Oct 6, 2021 at 7:10 AM
    #299
    csuviper
    Broomfield, CO
    Incase anyone needs some current info on 35s
  30. Oct 6, 2021 at 7:39 AM
    #300
    DondeContente
    DondeContente New Member
    Nathan
    2014 Tundra
    Hey guys, opinions on best rain/snow tire?
    The rain is back here in the PNW, and these KO2's have got to go.
    Totally useless in the rain, and road force balanced twice, but still shake like Michael J Fox.
    I loved the Duratracs I had on my Tacoma, but wanted to try something new.
