Camaro stuck in a box, how to get it out- UPDATE: Camaro out of the box.
Discussion in 'Off-Topic Discussion' started by Dr Doobie, Apr 28, 2021.
  1. May 4, 2021 at 7:56 PM
    #61
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Fixed that for you. :D Good work. You’re a better man than I, this guy would have left that chevy in it’s coffin.:rofl:
    15whtrd, GODZILLA, Baja Mike and 3 others like this.
  2. May 4, 2021 at 8:05 PM
    #62
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Well that’s not the video we asked for.
    Good work none the less!
    Dr Doobie[QUOTED][OP] likes this.
  3. May 4, 2021 at 8:12 PM
    #63
    BlackSheep
    BlackSheep caffeinated member
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    held together by duct tape and baling wire
    Bravo! Happy ending to a completely avoidable saga. Lessons learned all around, I hope :thumbsup:
    Dr Doobie[OP] likes this.
  4. May 4, 2021 at 8:30 PM
    #64
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Glad it worked out but for the life of me I can’t figure out why anyone would care enough to try and protect a Camaro like that.
  5. May 4, 2021 at 8:32 PM
    #65
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    :thumbsup:
  6. May 4, 2021 at 8:34 PM
    #66
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’ve seen enough Camaros with 3 or less wheels on blocks in the front yard to know you’re not alone in that thinking. They were slightly older, but...
  7. May 4, 2021 at 9:35 PM
    #67
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I don't know why they don't do what their Cadillac cousins did for decades and hide the lock behind an emblem, or even behind the license plate.
  8. May 5, 2021 at 5:33 AM
    #68
    racerex
    racerex New Member
    Will
    Westchester County, NY
    2021 Limited CM TRD Off-Road
    If he plans on storing the car in the container again, he should really consider using a car cover and installing some type of exterior fresh air vent that will allow for air circulation in the container. Condensation can be a big issue with long term storage in shipping containers during the winter........and crazy heat in the summer. Those containers are pretty tight. The vent could be as simple as installing one or two of those roof-top spinning/turbine vents on the roof of the container.....just make sure he has a good watertight seal where the vent is attached to the roof of the container......so rain water or water from melting snow can’t find its way into the container. If it was me, I’d go with side vents on opposite sides of the container. With maybe a small solar powered fan to circulate the air. My friend uses a small fan to circulate the air throughout the interior of his shrink wrapped boat when it’s on the hard.....he also uses desiccant tubs. His fan is technically solar powered because he has a solar panel on the roof of the boat to maintain the deep marine batteries.
  9. May 5, 2021 at 5:41 AM
    #69
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Was hoping the OP's solution involved high yield explosives.
  10. May 5, 2021 at 8:33 AM
    #70
    Wallygator
    Again, pretty sure that lock is ONLY on the convertibles.
  11. May 5, 2021 at 7:18 PM
    #71
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Haha. Live and learn.
  12. May 5, 2021 at 8:15 PM
    #72
    Rubberdown
    Rubberdown Spilling my guts here.
    If you can’t open the trunk how do you access a tail light bulb?
    Cpl_Punishment and Dr Doobie[OP] like this.
  13. Oct 25, 2021 at 1:21 AM
    #73
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    3BB666BA-AA38-48A2-871B-1176E5F5762F.jpg Should put a large 4ft wide roll up door on the side of container for the future. So drivers door can open fully. ;)
    Wallygator and Dr Doobie[OP] like this.
  14. Oct 25, 2021 at 4:19 AM
    #74
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    21 SR5 TSS Onroad, 24 Camaro 2SS 6.2 L
    To much to list:)
    Glad this thread was woke up again I forgot all about it!! Glad y’all got er done!!! Now that it is time to pack it up again!!!:(. Can’t believe you hit a cooler after all that:). Hope y’all figured out something that is much easier for next year!!! All the best!!!:)
  15. Oct 25, 2021 at 4:45 AM
    #75
    PJR202
    PJR202 New Member
    I'd have just called a tow truck to pull it out. Easy peasy.
