2021 Tundra Transmission
Discussion in 'Performance and Tuning' started by turbocrazy, May 4, 2021.
  1. May 4, 2021 at 10:59 AM
    turbocrazy
    turbocrazy [OP] New Member
    2021 Tundra 5.7L V8
    Guys, quick question, What is the 2021 Tundra Transmission Code?
    Anyone know of a transmission controller for it?
  2. May 4, 2021 at 11:11 AM
    What are you referring to when you say transmission controller?
  3. May 4, 2021 at 11:17 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    What is a transmission controller?
    Tundra234 likes this.
  4. May 4, 2021 at 11:29 AM
    turbocrazy
    2021 Tundra 5.7L V8
    If we eliminate the stock Engine ECM that probably is the one that controls the transmission, we need a separate transmission controller, like for example USshift sales for the FORD auto transmissions.
  5. May 4, 2021 at 11:31 AM
    I have never heard of anything like that and you can't just eliminate the ECM.
  6. May 4, 2021 at 11:38 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I mean...someone was going to post it eventually...:p If you want to change how the transmission shifts, et al. You're going to have to wait until one of the tuners cracks the ECU/TCU.
  7. May 4, 2021 at 12:18 PM
    turbocrazy
    2021 Tundra 5.7L V8
    Thanks for all of the input.
    Please if someone understands what I asked and care to answer it will be appreciated:
    Question #1: What is the 2021 Tundra 5.7L Transmission code?
    Question #2: If this one has been already been used by earlier models or platforms, maybe someone knows of a transmission controller for it?
  8. May 4, 2021 at 12:27 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    1) AB60E/F
    2) Nope. Tuner.
    JohnLakeman likes this.
  9. May 4, 2021 at 12:36 PM
    turbocrazy
    2021 Tundra 5.7L V8
    Awesome, thank you, my doubt started with this code as it is in the Tundra since 2007 and using Google I saw many other newer models like the A760E/F and thought it should be one of the newer versions...
  10. May 4, 2021 at 12:41 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    AB60E = 2WD, AB60F = 4WD
    A760E/F is for the 4.6L. Not necessarily a newer transmission (except in the Tundra). Probably the same transmission used for the Lexus application.
    If you have a Tundra, the transmission code is on one of the stickers on the driver side door jamb. I believe it's on the white sticker, down along the bottom edge.
    Wynnded[QUOTED] likes this.
  11. May 4, 2021 at 12:44 PM
    turbocrazy
    2021 Tundra 5.7L V8
    Correct E=2WD and F=4WD and thanks for the clarification on the "newer" codes, I will use AB60E or F for our controller quest, thank you!
  12. May 4, 2021 at 12:46 PM
    Danman34
    Danman34 New Member
    Danny
    The transmission is controlled by the ECM. There is no tuning capabilities/nothing available to modify any of the software components of the ECM 2021 trucks.
  13. May 4, 2021 at 12:54 PM
    turbocrazy
    2021 Tundra 5.7L V8
    Yes, exactly, thank you
