Come on Toyota...a little lazy are we?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ScenicRoute, May 4, 2021.
  1. May 4, 2021 at 11:24 AM
    ScenicRoute
    ScenicRoute [OP] New Member
    2021 Tundra CM Nightshade
    Eibach stage 2, SmartCap, Ride Rite, Bora spacers, 35” rugged ridge tires.
    I think they missed a spot.
  2. May 4, 2021 at 11:25 AM
    biebs96
    PA
    No someone took your bed rails off to install the cap.
  3. May 4, 2021 at 11:26 AM
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    Wow... was that factory or done by the dealer?
  4. May 4, 2021 at 11:26 AM
    ScenicRoute
    yeah that was me. They took the time to mask the rails vs install the rails after they bedline it?
    jewsNbrews likes this.
  5. May 4, 2021 at 11:28 AM
    biebs96
    PA
    It’s purposely left unsprayed underneath the rails to ensure a flat fit.
  6. May 4, 2021 at 11:29 AM
    G10dra
    G10dra Not a New Member
    Let me see the back of your bed
  7. May 4, 2021 at 11:29 AM
    ScenicRoute
    I don’t buy it. It sits on 5 high spots. Not the whole length.
  8. May 4, 2021 at 11:30 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I would rather have the rails against the paint than bedliner myself. Many pics ive seen on this site have been sprayed like that
    those rails cost $160. The cap installer should have used toyota specific clamps that used the rail system so you still had the tie downs avail
  9. May 4, 2021 at 11:30 AM
    biebs96
    PA
    It looks identical to my 2010 that I took the rails off of to install a cap. I sold it otherwise I’d post a photo.
  10. May 4, 2021 at 11:31 AM
    ScenicRoute
    I’m sure they do it the same for all trucks. Mine wasn’t really missed. I just think it’s lazy.
  11. May 4, 2021 at 11:34 AM
    My 2020 was Line-X'ed when it arrived from the port and I have Line-X behind my rails. My 2013 was the same way.
  12. May 4, 2021 at 11:35 AM
    CurtisLemansky
    2017 SR5 CM TRD OR
    Glad to hear this, I was about to go check mine because I would not be happy to see that once I drop the rails for a tonneau.
    IndianaGeologist likes this.
  13. May 4, 2021 at 11:37 AM
    Elduder
    Elduder New Member
    Toyota seems pretty lazy with this option. If you get bed liner w/o the rails they leave the holes filled with the paper they stuff in the hole to prevent it from coating the threads. Some people get theirs with the rails and they dont remove them and coat over them. Ive also seen a few beds with the back tie down uncoated and a few with them coated.
  14. May 4, 2021 at 11:48 AM
    ScenicRoute
    My front tie downs are coated. The backs are painted.
  15. May 4, 2021 at 11:50 AM
    Elduder
    Elduder New Member
    Same as mine, but I sold some parts to a local about a month ago and all of his were coated.
  16. May 4, 2021 at 11:51 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Is this something that is done at the build site, or is it contracted out?
  17. May 4, 2021 at 12:02 PM
    Elduder
    Elduder New Member
    After port arrival from my understanding. When I ordered it was listed under port options.
  18. May 4, 2021 at 12:04 PM
    FrenchToasty The Desert rat, 6 lug enthusiast
    The SoAz
    None
    I smell a claim with corporate!!!
  19. May 4, 2021 at 12:13 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm not certain what "port" suggests, sorry. I'm under the impression that the vehicles are made almost entirely in the U.S., or that the cargo boxes are. Is it known if they're shipped to an assembly plant and lined there, or is that something that's done after the box is on the chassis...or even later? I'm trying to decern if this process is done under Toyota's watch, or if it's done after leaving final assembly yet prior to a dealer. Perhaps a distribution point? I'm trying to determine if maybe there are several non-Toyota companies that are doing this. That could account for the inconsistencies.
  20. May 4, 2021 at 12:19 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Put the rails back on and use some of these to mount the cap to the rails instead? https://www.amazon.com/gp/product/B07K2J79TR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
    Also I agree that's very lazy and shouldn't have happened. Helped my buddy install an OEM Toyota tri-fold tonneau a few weeks ago and there was liner behind his rails but I believe it was aftermarket and not factory.
  21. May 4, 2021 at 12:37 PM
    Elduder
    Elduder New Member
    Port typically means after it is built and before it reaches the dealership. The Tundra is probably delivered entirely by fleet trucks and not by ship, I could be wrong there, but port is usually a term used with the vehicle arrives by boat at a port. So, it has already been built and then the accessories are added. If you look up the 4Runner Pros in shipment there are pictures of them without the TRD wheels and badges, as those are all installed after it arrives stateside.
    Wynnded[QUOTED] likes this.
  22. May 4, 2021 at 12:40 PM
    Elduder
    Elduder New Member
    Here, apparently its called post production options.
    From my order:
    Wynnded likes this.
  23. May 4, 2021 at 12:40 PM
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    2020 Platinum - Super White
    Elka DSC Suspension, Ray-10s, MaxTrax, Dirt King UCA, 295/70/18 Toyo AT3, TRD Skid + Intake, .25 Bumper Shim, UnderCover UltraFlex Tonneau, RoadActive Suspension, Tuffskinz, etc.
    I noticed that when I was purchasing my truck as well. If its a factory liner, that's how its done vs liners done at port / dealer. Another indicator is the factory has the "TUNDRA" stamp added to the cab / front side of the bed. Not a fan of how the factory liner went around the rails and also have the front tie downs sprayed but the rear painted, I thought it looked inconsistent especially on white. I decided the better option for me was to save $ omitting the factory liner and go Line-X or similar down the road with the lifetime warranty.
    Wynnded likes this.
  24. May 4, 2021 at 12:47 PM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    My truck has everything sprayed, including all the fasteners. If you buy a naked truck and take it to LineX they'll remove everything first, then reinstall it.
  25. May 4, 2021 at 12:52 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Opinion: the problem was the canopy installer cheaping out and not using the track system brackets.
    Huck23, A-A-Ron, stuckinohio and 5 others like this.
  26. May 4, 2021 at 1:10 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Mine was naked and done via Line-X dealer. They did NOT remove all the bolts and tie downs, but did remove the Rail System.
    CurtisLemansky likes this.
  27. May 4, 2021 at 1:33 PM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Mine was sprayed on as a “port” option and was not sprayed behind the rail system. The front tie down hooks were sprayed while the back ones, near the tailgate, were removed prior to spraying and are white.
    I don’t really give a shit either way as the rail system won’t be coming off.
    BravoDeltaRomeo likes this.
  28. May 4, 2021 at 1:33 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    "Port" is the distribution center for each region. Although not necessarily a ship port, the word port refers to point of entry. Toyota is unique in that they have the country divided in several regional distribution areas (franchises actually), such as SouthEast (FL, NC, SC, AL, GA), Gulf States (OK, TX, MS, LA, AR) etc. All vehicles are transported from the factories to these ports. and then from there to the dealers. The ports install options, such as bed liners. Sometimes if the port did not install a bedliner, the dealer might decide to install it, but the Toyota Factory does not install bedliners.
    Wynnded, Elduder[QUOTED] and ezdog like this.
  29. May 4, 2021 at 2:00 PM
    ScenicRoute
    I also happen to be the canopy installer
  30. May 4, 2021 at 2:08 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    Even better then!?
    I dont think Toyota sprays on that liner at all.
    I think the term Bedliner means the drop in plastic liners and they are then removed by Line-X or whoever sprays the bed later at whatever time it is done.
    At that time they either remove the rails or not but this is the sad result of someone clearly not removing them at all.
    I bet it takes as long to mask them off well as it would to remove them to do the job correctly too.
