Maestro question
Discussion in 'Audio & Video' started by BrianH4x4, Dec 27, 2020.
  1. Dec 27, 2020 at 3:08 PM
    BrianH4x4
    BrianH4x4 [OP] New Member
    Shelby, North Carolina
    2015 silver sky metallic
    USB plug added for backseat 6 circuit fuse holder added Amp power steps Bed lights Bumper led ( anytime) lights Amp reasearch bed step Focal three way components up front Focal 165 in rear Jl xd200 amp for front stage Jl xd 300 amp for 10 W3 -D4 sub Maestro rr for steering wheel control
    Recently installed the Maestro rr on my 2015 tundra. I have it hooked up the the OBD connector. I have the gauge screen and the screen where the tire pressures show but it just says N/A for the tire pressures. Is this something I should have? I’ve looked all through the menu on the head unit and I don’t see anything else to turn on in the menus. Just curious if anyone had run into this too. It is a 2015 crewmax limited. Thanks
  2. Dec 27, 2020 at 5:45 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    What H/U do you have the Maestro connected to? Are you running the latest firmware on your Maestro (ie, did you download the correct update for your vehicle and H/U and flash it before installing)?
    Saltyhero13 likes this.
  3. Dec 27, 2020 at 5:46 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2017 Sequoia LTD
    Rx350 retrofitted, Morimoto Led fogs. interior and exterior leds swap. TRD drop in filter. Carbon filter delete. Led DRL panels. TRD Shift knob.
    What radio are you using?
    BrianH4x4[OP] likes this.
  4. Dec 27, 2020 at 6:24 PM
    BrianH4x4
    JVC KW-V960BW, yes I went through the set up and flashed it. I’m assuming when it’s flashed it would get the latest firmware update for my vehicle.
  5. Dec 27, 2020 at 6:42 PM
    BrandonL812
    Brandon
    2017 Sequoia LTD
    I read some where, cant remember exactly, something about reinitializing the tpms setting inside the kenwood radio. Kind of like refreshing the data. Then it would show again. I tried to search for the thread but cant remember. See if you can play with the menu and find a way to refresh or initiate the tpms sensor setting.
  6. Dec 27, 2020 at 6:44 PM
    BrianH4x4
    I will give it a look tomorrow. Thanks for the idea.
    BrandonL812[QUOTED] likes this.
  7. Dec 27, 2020 at 7:41 PM
    preacher35
    I have a Maestro RR connected to my Kenwood H/U, which has a "master reset" for the Maestro. I know that the Pioneer H/U's also have the same option. When activated, the Maestro will reset and the TPMS data should display. That being said, I have ZERO experience with JVC products. All else fails, contact iDatalink. They are pretty good about responding to tech support issues via telephone.
    1lowlife and BrianH4x4[OP] like this.
  8. Dec 28, 2020 at 8:59 PM
    Corranhorn4406
    Corranhorn4406 New Member
    Brad
    2015 Black Tundra SR5
    I have a 2015 also and just installed a kenwood unit a few weeks ago. Can’t get any reading for tpms either. I’ve tried resetting the maestro through the head unit with no luck. I’m installing an amp and plan to reflash and see if that will work.
  9. Dec 28, 2020 at 9:44 PM
    I'll have to look at mine, but make sure the OBD is enabled. Do the performance gauges work? Also, if you are using the data cable, you do not need the OBD port connector.
    1lowlife likes this.
  10. Dec 28, 2020 at 10:27 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'm on my third aftermarket HU also using the Maestro in my 2014 SR5.
    2 Kenwoods and 1 Pioneer.
    I've never had a problem with TPMS coming up or acquiring engine data from any of them..
    33F770E9-EF76-4B54-9B0A-CB5F47F82489_zps_485861167f1c1fa285cef1420e5baf879766127a.jpg
  11. Dec 29, 2020 at 12:08 AM
    Txmgm
    Txmgm New Member
    2017 mgm crewmax tss sr5 4x4
    Mgm vinyl wrap chrome delete Trd shit knob Fortin evo remote start Full tacotunes sys 1 plus sound deadening Trd pro grill Wireless charging mod
    I had this issue but with an ilx309 alpine. I ended up calling idatalink. They had me cut a resistor out of the t02 harness and reset from the settings screen. I highly recommend troubleshooting with idatalink on the phone especially if you have a remote start. My thread is below.
    https://www.tundras.com/threads/alpine-ilxf-309.76813/
  12. Dec 29, 2020 at 7:32 AM
    Corranhorn4406
    Brad
    I get all of the engine data. Fuel and tpms won’t read however.
  13. Dec 29, 2020 at 7:41 AM
    Txmgm
    Txmgm New Member
    That is odd. My undertanding is the fuel data is sent over canbus with all the other guages and the tpms data should be the only info sent over the obd connector.
  14. Dec 29, 2020 at 7:49 AM
    Corranhorn4406
    Brad
    I also have a remote starter installed if that makes any difference.
  15. Dec 29, 2020 at 7:52 AM
    Corranhorn4406
    Brad
  16. Dec 29, 2020 at 10:21 AM
    Txmgm
    Txmgm New Member
    1st Are you 100% sure you have the OBD single wire harness connected properly to the obd port and the T02 harness? i have a fortin evo remote start installed as well. I would start by resting the maestro unit through the head unit. Then I would drive around to see if it wakes up the TPMS. If either of these does not get the reading you need to probably call idatalink to troubleshoot.
  17. Dec 29, 2020 at 10:52 AM
    Corranhorn4406
    Brad
    Yes and I did all that. Reset everything I could through the head unit. I’m in the process of installing amps so I have to pull the head unit out anyway and I plan on reflashing to see if it corrects.
  18. Dec 29, 2020 at 11:37 AM
    As I said earlier, unplug the OBD connector if you are using the data cable. Its in the instructions. The TPMS goes through the data cable.
  19. May 1, 2021 at 4:37 PM
    btole79
    btole79 New Member
    Bay Area, CA
    2017 Limited Crewmax
    Icon Stage 6 Fuel Trophy Wheels 35's on 20's
    I know this is an old thread but I thought I would post how to resolve this issue. I just installed an Alpine Halo9 with Maestro rr in my 2017 tundra and everything worked except tire pressure read out. Lots of searching on the web and really found nothing. replaced harness from the halo and meastro, new OBD plug resets and flashes of the unit and still nothing. I had to bring the truck in for oil and fluid change so I had the dealership check that the TPMS sensors were working and they gave me a print out from their diagnostic machine with tire pressure reading. Called crutchfield, who I bought the unit from, and they had no ideas.
    After all that I called maestro support and they listened to my story and quickly said yes we know of this issue, there was an old harness that had a resistor between the main red power wire on the maestro and the obd wire that would make the maestro read TPMS, they found that in some applications this would cause no sensor read outs so they removed it. Support said to put in a 2000k resistor and it would solve my issue. Since their are no more radio shacks in my area I order a 100 pack from Amazon for $5, soldered it inline and put everything in the truck. I did a master reset and turned the truck on and to my very happy surprised the tire pressure popped up.
    So there is the answer, $5 resistor and about 30 min or work to make the read out of tire pressure work. Hope this help anyone else who is facing this issue and looking for resolution.
    :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
  20. May 1, 2021 at 5:58 PM
    My tire pressure shows on my Pioneer through the Maestro. My problem is that it will not show pressures on the dash display.
  21. May 1, 2021 at 6:47 PM
    btole79
    btole79 New Member
    Bay Area, CA
    My 2017 never had that option. Only the indicator light.
  22. Jul 13, 2021 at 7:49 AM
    lsumatt1514
    lsumatt1514 New Member
    2008 Tundra Crewmax Limited
    I soldered in the resistor several weeks ago. The tire pressures showed up on my Kenwood for a few days, then went away again and have not come back. I pulled the head unit out this weekend to look at another issue and all connections were still solid. Anyone found another smoking gun…maybe a setting somewhere that is disabled? Thx!
  23. Jul 13, 2021 at 9:40 AM
    btole79
    btole79 New Member
    Bay Area, CA
    you can try reseting the Maestro unit, on my Alpine, in the sub menu there are two reset options, master reset and PID reset. I do both and it usually solves the issues. Had to do this twice and haven't had an issue since.
  24. Jul 13, 2021 at 10:24 AM
    lsumatt1514
    How do I drill down to PID reset (what’s it under)? I’ve seen the Maestro Master reset but not PID reset. Thx!
  25. Jul 13, 2021 at 12:16 PM
    btole79
    btole79 New Member
    Bay Area, CA
    Just went out to the truck and took a look.
    on the Alpine: Settings->System-> Maestro Module -> Maestro Settings -> Gauges -> Validate PIDs
    hope that helps.
  26. Jul 13, 2021 at 12:22 PM
    lsumatt1514
    You nailed it! Mine are working again. Thanks for the help!!!
  27. Jul 13, 2021 at 12:27 PM
    btole79
    btole79 New Member
    Bay Area, CA
    NICE, I know when I was dealing with it I would get pretty frustrated when it would stop working and then thinking I would need to pull the head unit again to resolve.
    Glad I could help.
  28. Jul 19, 2021 at 1:23 PM
    lsumatt1514
    ...and they stopped working again. I've done the Master Reset and the PID reset and they aren't coming back. So frustrating...
  29. Jul 19, 2021 at 2:17 PM
    btole79
    btole79 New Member
    Bay Area, CA
    Is your OBD connection loose by chance or possibly the + or - connection to the unit?
    I called maestro support when I had the issue. That’s how I found the resistor info. Might try that also. They are pretty good
  30. Jul 19, 2021 at 3:07 PM
    lsumatt1514
    OBD2 isn’t loose. I contacted Maestro a couple months ago and they had me solder in the 2k resistor. Their tech guys haven’t come up with a reason why it’s coming and going in my truck.
